Ouch. Somehow missed first 4K monitor >32" release then and auto-assumed that it's UHD TV.Firepc said:What do you mean "use it as a PC monitor"? It is a PC monitor.
Yeah I don't blame you. 40" is more of a TV size. Personally love my VA panels and I really want to see this one in person.
Seems very interesting, but I prefer to wait for 50" or 55" monitors.
You will have to wait for a while..
But there is already Panasonic UHD TV's at 50" and 58" which has displayport.
How much are they, because I think I'd prefer a 50"
Panasonic TX-50AXR800 (50")
Panasonic TX-58AXR800 (58")
Panasonic TC-L65WT600 (65")
A friend of mine bought the 50", but I can't afford to pay 1500 for a 4k TV.You will have to wait for a while..
1500, give or take.How much are they, because I think I'd prefer a 50"
Do you all think that a 780GTX 6gb would be enough to power this monitor at native res and 60hz?
DEFINITELY looking forward to this, could well be 'the one' I've been waiting for,Currently I'm using a Sony 40" TV as my 'monitor', which is a great size for immersive gameplay. Even with the best AA though, the pixels can easily be seen. 4K at 40" is gunna be awesome. I sit about 3 feet away. Some of my friends call me crazy, but unless my field of vision is properly filled, I just don't get a decent level of immersion.All the games I play run at 4K easily via downsampling/dsr on my hilariously overclocked 780ti, so I'm not concerned with performance.
Bottom line: If the input lag on this thing is at least sub 16ms, then I'm buying one, no questions.
Do you intend to sit closer when you get 40"@4K?
Input lag is way below 16ms on this monitor according to specs.
According to the spec sheet linked in the first post, they only list panel response times, but make no mention of input latency. Have you found additional information elsewhere?
Sorry, not. There is no reason why input lag should be high, this is genuine monitor not TV.
Have you ever owned a high-res monitor? 2560x1600? Almost all of them have high input lag, only the 3007WFP-HC had low input lag. For me I'll use this monitor for work and singleplayer games, while a ROG Swift will be for online gaming.
Since both size 40":27" and number of pixels 3840x2160 : 2560x1440 scale in proportion 3:2, resolution in terms od dpi is the same for both and the 40" inch picture will look the same as in the 27", just the overall area is bigger. With proper scaling of text and icons I have no problems on my 27".If a 40" UHD has similar PPI as 27" 1440p then text and icons will appear same size as that or will they really be smaller?
[08E1_Analog.AddReg]
HKR,"MODES\1920,1080",Mode1,,"30.0-99.0,56.0-80.0,+,+"
HKR,,MaxResolution,,"1920,1080"
HKR,,DPMS,,1
HKR,,ICMProfile,0,"BDM4065.icm"
[08E1_Digital.AddReg]
HKR,"MODES\3840,2160",Mode1,,"30.0-99.0,23.0-80.0,+,+"
HKR,,MaxResolution,,"3840,2160"
HKR,,DPMS,,1
Only over HDMI. DP and mini DP do 60hz.
What's encouraging, is that the monitor has a game mode. Hopefully, this mode has low input lag. Game modes often have.Have you ever owned a high-res monitor? 2560x1600?
how far away from it do you have to sit for it to be comfy? I want one too
If it has a similar dpi like the 27" 1440p monitors you'd sit just as close, but 40" might require a bit more distance to take it all in.
I'd say that 4:4:4 image format also must be tested/proven to work fine if one intends to use it as pc monitor. Otherwise what can be gained from 4K-ishness, if it wouldn't display clear text without soaping up due compression. PC monitors are not used just for watching movies. I wouldn't bother/consider to buy it prior extensive test/review.
Those are made artificially expensive because margins and custom panels.How in hell is this monitor so cheap(going by over seas pricing) at 1k? Something has to be up, maybe its a TV, maybe 30hz, maybe it sucks.
Every single large 4k monitor is 2k+, how is phillips getting a 40" 4k that cheap
