Hagrid
- Nov 23, 2006
So I was reading a bit and see that an IR illuminator works great since that what it uses. Anybody use one?
Never considered that before. Definitely interested.So I was reading a bit and see that an IR illuminator works great since that what it uses. Anybody use one?
I've got one of these: https://www.amazon.com/gp/product/B075ZYG89Dhttps://www.amazon.com/Orzero-Illuminator-Compatible-Disturbance-Sensitivity/dp/B08SHPKSSM
Like that I guess? If it helps, I am willing to try.
I wonder if I need more light? I have 2 bulb on and the sliding door blinds open. I am used to my Rift that did not care either way.
Light and contrast is important for the Quest 2. The cameras map out your surroundings by placing virtual markers on areas of contrast to aid in tracking your position. Playing a Quest 2 in an empty black/white room with perfect lighting might sound like an ideal VR space, but without contrast, the HMD will struggle to place useful tracking markers.
That’s true.Light and contrast is important for the Quest 2. The cameras map out your surroundings by placing virtual markers on areas of contrast to aid in tracking your position. Playing a Quest 2 in an empty black/white room with perfect lighting might sound like an ideal VR space, but without contrast, the HMD will struggle to place useful tracking markers.
Also need to keep in mind that the cameras aren't RGB -- they're B&W without an IR filter. So if you're using IR illuminators as your primary light source, you're going to want to sanity-check in passthrough mode that your contrast markers are as contrast-y as you think they are.That’s true.
Quest 2 doesn’t handle facing a featureless blank wall very well (e.g. empty unfurnished room with no windows and only a single light fixture above), and goes dramatically worse with dim light in featureless rooms.
So it helps if there’s at least a textured floor, computer tower, etc) within view of at least one or two cameras, but preferably all 4 at the same time for maximum accuracy. Even posters (or black tape) on bright blank walls, seem to help a fair bit.
Think of the 4 camera sensors on a Quest 2 is sort of like equivalents of redundant mouse-tracking sensors, but without their built-in light source.
So the right contrasty/textured room is just like selecting the right mousepad — jitterfree mouse, jitterfree Quest 2.
If you optimize correctly for it, I haven’t seen any VR headset do “hands-in-front” tracking as well as a Quest 2 can at three-figure prices, while simultaneously keeping you extremely accurate in a large RoomScale at the same time. It’s pretty uncannily accurate in a high-contrast well-lit room, especially with your hands/controllers contrasting from the background.
If you hate bathing a room in bright light — then even three pieces or four pieces of well-lit furniture/RGB decorations/nightlights/christmas lights (preferably PWM-free)/etc makes a big difference in a dark room — Quest 2 just need to hone onto some high contrast reference objects.
For example; If you like playing less-precision-important VR Sierra Quest games (e.g. Down The Rabbit Hole) while lying down on a sofa or bed, then a string of christmas lights along one wall is all you need — there might be some jitter, but produces enough light to activate Quest 2 tracking without room-too-dark notifications. (IR illuminators also work too — another good tip)
But if you’re wanting surgeon-quality tracking right down to the exact millimeter — bathe the room in contrast and light!!
If your computer monitor is at front, that’s probably already automatically a Quest 2 tracking reference (because the monitor is a bright object to the Quest 2 cameras) — so, instead put the IR illuminators to the sides (left/right) instead.Ordered 2 IR lights. One for front and one for the back. They will be here Sunday.
Since I got the good wireless router, I can do my VR in the living room with a much bigger space than the VR bedroom.If your computer monitor is at front, that’s probably already automatically a Quest 2 tracking reference (because the monitor is a bright object to the Quest 2 cameras) — so, instead put the IR illuminators to the sides (left/right) instead.
That said, if front is completely featureless at night with no glowing sources, yes, go for it — an IR illuminator right at front.
Everything that glows becomes a potential tracking reference at night; spread them out a bit so at least three, or more bright contrasty “visible things” or “glowy things” (light sources or contrasty objects) are glowing in your pass-through view during a 360-degree rotation test.
Are you using the 5GHz band? If no, that is your solution.Yep and Airlink is fantastic, though I still have severe wifi interference issues in my room some days even with a relatively powerful & dedicated router and messing around with the settings for hours. FML. Maybe it will be better in the apartment I just bought but I'm not certain.
Make sure you’re using 80 MHz width. Try changing channels. If both 42 and 155 have issues you can try DFS channels if your router supports it. I’d also probably use dynamic bitrate and possibly do an iPerf 3 test in your play space to see what kind of throughput you’re getting.Of course I am. 2.4ghz I'd dare call that unplayable for VR5ghz and Wifi 6 (but the latter is mostly just extra bandwidth).
It's very random and I have zero other wireless devices at home (besides my phone but it's never connected to Wifi, my laptop I practically never use it while home so it's never turned on during my VR sessions).
I only notice those interferences in VR but yeah I am a perfectionist and extremely sensitive to the slightest smoothness issue.
If you live in an apartment, you may have issues with some of the bands being congested because neighbors have a bunch of wifi devices on the same band. In addition, there can be devices used by others that interfere with wifi (think, microwave ovens, or any other kind of power hungry appliance)Of course I am. 2.4ghz I'd dare call that unplayable for VR5ghz and Wifi 6 (but the latter is mostly just extra bandwidth).
Microwave doesn't interfere with the 5GHz band and even in an apartment, shouldn't be hit with too much interference on 5GHz as it doesn't reach too far. Though switching channels can help with the closer by 5GHz networks, to avoid those. Just use a Wi-Fi analyzer and you know what channel to use.If you live in an apartment, you may have issues with some of the bands being congested because neighbors have a bunch of wifi devices on the same band. In addition, there can be devices used by others that interfere with wifi (think, microwave ovens, or any other kind of power hungry appliance)
MacBook pro 2012 really wouldn't help as it doesn't meet the minimum requirements for the program you want to run. You need something like a 970 or 1060 in terms of GPU performance.Hi there Im new here, I just need to ask if I can run Gravity Sketch with Oculus Quest 2 through Steam or something on a Mac Pro mid 2012 --> Mac specs here (https://everymac.com/systems/apple/...re-i7-2.3-15-mid-2012-unibody-usb3-specs.html)
I know its possible to have a processor(?!) externally connected to run the software...
Hope to get some help here
Thanks
https://www.bbc.com/news/technology-57997112Facebook also announced it was "pausing" Quest 2 sales and from 24 August all Quest 2 headsets would come with the new silicone cover.
The revamped headset would also have twice the internal storage, for the same price.
There's a recall on the Quest2 foam padding for the headset. (not quest 1) You can sign into your Oculus acount and request a silicone one.
https://www.oculus.com/quest-2/removable-facial-interface-alert/
Also:
So just got the 128gb today and will get it tomorrow.... do I need to open a Facebook account, use and old (very old account), or start fresh with a new Facebook account or can I still make an Oculus account? Just using it for American Truck Simulator and maybe kids playing some games.....
It’s very old and not my real information…… never did trust them. I used an old yahoo email for it…. Sounds like I may have to make a new account. I thought I remember reading you can still create an Oculus account somewhere.If you have on old account (and not a fake one) then use that. Facebook frowns on multiple accounts anyway.
I got a 128GB Quest 2 this weekend - really enjoying it as I set it up for my 11 year old. I got in with an HTC Vive right when they launched however many years ago and found it to be too gimmicky for the $$$ (sold it) - at $299 this is really fun and a perfect entry point to see if my son ends up digging it. We can always graduate up. What really impresses me is just how awesome it is to simply sit and enjoy media (YT, etc.) from within the unit. Very cool.
So coincidentally my same experience. My son has the original Vive and they just seem so fragile; his original wand controllers fail to pair.. we got him the Index controllers.. and one of those developed drifting and then the thumbstick started to loosen up over time.. the lenses started developing dark black spots inside of them recently... for the $$... it should last forever unless dropped and purposely broken.
Dark black spots. Sunlight damage? The lenses are essentially magnifying glasses, they have to be protected from sunlight at all cost or they will start frying the panel inside
I always put a towel over mine for extra protection just in case.
I just cleared out a whole room to dedicate to VR. I was playing in the basement before but would occasionally hit the ceiling because they're only 8 ft down there. And now it's become a home theater and office so there's too many things to worry about breaking.
It's nice not to have to worry about hitting anything, it kind of breaks the immersion having to think about it. It's so much better with no cords or worries.
You can login with whatever Facebook credentials you have. It also supports multiple accounts (i.e. family). Honestly, once you do that (and you disable Messenger) - it doesn't even seem like Facebook is connected to it, at all. Although certainly they are tracking everything you do and monetizing it.Is it allowed to use a family member's facebook account if you don't have your own ? Just asking. If not no big deal.
