- May 18, 1997
I am laughing at the statement you posted.Are you making fun of me ?
He , his site and his privilege above my head . Lolno I think he was laughing at your comment. but even if he was, its his site, he gets that privilege….
what is the problem with using a big screen more than 3' away?
You'd keep the computer near the screen (like consoles and other media devices are) and run the usb cable around the back wall.
You could alternately deploy a no-trip floor cabling strip directly across to your seating position (at least pulling it out from under entertainment center when switching to wired gaming peripherals for gaming sessions).
I can run usb cables around the back wall in conduit or even down to basement ceiling and back up. The couch master couch desk setup comes with usb3 cables and a usb3 hub too.
Other than that, what is the problem with using a big screen more than 3' away? Visually it would work a lot better further away. At 8' away, my 70" is bordering on requiring me to tilt head to focus on the extremes. Unless you mean the video cables?
8' viewing distance to your eyeballs means you could prob run a 16' usb cable run, (maybe a bit more if not using no-trip strip directly across), and feed it around the back wall in some conduit or some sort of wire-management shielding through to under the couch. Or you could feed it down behind the wall behind entertainment center, through basement rafters and back up behind couch drilled through the moulding at the wall's bases or via a wall plate if you want to get fancy.
You can run another usb cable or utilize the hub for a g29 steering wheel and use one of those metal pop up stands they mount on .. You could also use a xboxone controller wired or unwired for a lot of fun games.
Not every game is extremely demanding on gpus, and some can dial down a bit without losing too much. I agree 4k is gpu crushing on demanding games though. See my previous posts about the 100hz @ 100fps average as a minimum target for gaming on high hz displays. In fact, for people with moderate gpu budgets, a high hz 1080p where you can crank up all the graphics settings is probably a much better idea. You could alternately run a lower rez on a high hz monitor like this for the most demanding games and rely on scaling if you had to, or even letterboxing depending how much smaller you go.
If u ask me , i'll tell u that gtx 1070 will be enough for many games at 4k 120hz and not just 1080 ti . You can play with the settings and turn some down until get the best fps and fast motion for your eyes .
But if you like big screen here is a 4K OLED 85"
That LG OLED is probably not 120hz native at 4k (though they are supposed to come out this year , not sure on price), and doesn't have G-SYNC Variable Refresh Rate technology (nor displayport) with game oriented input lag numbers. (It also can't hit 1000nit for HDR if that matters to you, but the black depth would be phenomenal). It could suffer the other OrganicLED trade-offs which make them questionable as monitors. Still pretty neat..
Yes it does.
You don't need to be able to hit 120 FPS with G-Sync.I think gamers are missing the point on this new Nivida Big format thinking 120hz on a single GTX 1080 TI card is not going to cut it, I think this 120hz is for a two cards or more setup not one because the 1080 ti @4k can only run 60hz even titan V but we will see when it comes out this summer.
Don't build up too much hope it all look very good on paper & with video graphics made by their marketing team.
Also I am all for the new technology only then they get it right or support it, But True 4K is 4,096 by 2,160 not 3840x 2160 Nividia
What is the issue with putting your PC near the display?i apologize if my post was not clear enough: curent cable techs struggle to deliver 4k 120hz over 1m spam. DP cables capable of this are few and far between, if they exist at all. This is one of points behind Zisworks dual Dp solution .
Everybody in this thread needs to watch this and expand their horizons.
This display will be amazing, especially when used more as a TV than desktop monitor.
So what's the advantage of having a 65" and putting it farther away vs. having a 43" at normal viewing distance? You're still seeing the same thing.
The only advantage of the 65 is that it sounds like they are going to produce it. I'm sure if they announced a 40, 43, or even 55 more people would be gravitating to that over a 65.
nVidia most likely thinks that they can capture both the living room market and desktop who are willing to adapt to that size with one product. Whereas if they were to launch a 40 it would have very little shot of capturing the living room display market.
Do u think guys we can achieve hardcore high ranks in shooter games like csgo , doom and overwatch perfectly on this size 65'' at 6 feet away ?
Lol what i want is RPG games and shooter games too but i prefer big size with much better clearity detail . I think 2m will be enough for this size 65'' whether for PC Gaming or Consoles and as a TV for movies .Well if that's what you want then you'd be better off with one of the 24 inch 240Hz monitors probably.
2.4/4.1m for a 65" that's if you got a big room to view/play games in peace.
I read the DisplayPort connection despite the fact that it uses variable refresh rate. But the new HDMI 2.1 specification, the HDMI inputs on the BFGD are version 2.0b, not 2.1.
I'm sure all the manufacturers know there is a craving by some of us for a 43"-49" version but I think they see us as a small minority. Obviously if they believed there was serious money to be made they'd do it. Apparently their research says there is more money to be made with a 65" model. Not that I'm agreeing with them nor defending them..
Local multiplayer with friends sitting next to you feels more comfortable that way. Everyone gets a good view of the action.So what's the advantage of having a 65" and putting it farther away vs. having a 43" at normal viewing distance? You're still seeing the same thing.
I have 5.1 speakers, so direct channel or TOSLINK from my sound card is good enough for me.Local multiplayer with friends sitting next to you feels more comfortable that way. Everyone gets a good view of the action.
And before you ask why anyone would do that on PC instead of consoles, I'll just point to stuff like Duck Game, Stick Fight: The Game and Screencheat. Ridiculously fun with the right friends... perhaps too much so when someone else in the house barges in and yells at everyone to quiet down.
If that's not AAA for your tastes, there's also CoD:BO3 (albeit sadly only two-player even if you have three or four gamepads). One of the few cases I can think of where split-screen doesn't just get axed on PC for no reason like with Halo and Borderlands, never mind that one gaming-grade PC is expensive enough and I can't just rebuy a bunch of games for my little bro's Steam account so we can just LAN up instead.
I also suspect that having more space allows for surround sound speaker systems to not suck should one opt to go in that direction. I've been thinking about branching out in that direction for the PC room ever since I picked up a TX-SR806 for all of $20 in working order, but I need speakers that work effectively in a roughly 15'x15' room and don't take up too much space; not quite nearfield, roughly bookshelf size (though vintage Smaller Advents are pushing the size constraints).
In turn, that also raises the question of how these new BFGD things handle audio. A/V receivers sure as hell aren't packing DisplayPort, and if someone wants to take advantage of surround speakers, it's likely that these displays will need to leverage the HDMI Audio Return Channel for PCs connected through DisplayPort to save the hassle of having to run an additional HDMI cable from the PC to the receiver.
I could do that already with my X-Fi Titanium HD, but I figure it's one less cable I have to worry about - and besides, LPCM 5.1/7.1 is preferred when available. DisplayPort can handle that, it's just that AVRs are HDMI-only.I have 5.1 speakers, so direct channel or TOSLINK from my sound card is good enough for me.
This monitor is for the living room where people have been pc gaming on tvs or would like to if they had a monitor such as this one so they wouldn't have to suffer the 60hz, no variable refresh rate, etc tradeoffs.
As for 40", a 40" 16:9 is the same width as a 38" 21:9 ultrawide. so that would be good for a desk if they made a 40" 4k 120hz FALD HDR g-sync since it would allow you to run a non-standard 38" ultrawide resolution like 3840x1440 or x 1600 1:1 pixel letter-boxed with bars top/bottom. This would allow you to view the monitor closer when gaming and you'd get higher frame rates to fill the higher hz, so you'd get more of the higher hz benefits. You could also run 3440 x 1440 with a letterbox "frame" border/windowed. The ultrawide resolutions would allow you to sit closer,using the ends of the wide aspect more for immersion and added game world real-estate. You could also run a smaller 16:9 rez letter-boxed/windowed 1:1, like 2560 x 1600.
So an option on larger, high resolution monitors could be to sort of downsize the game window more depending on how demanding the game is vs your chosen balance of graphics settings and gpu power. In any case, you would switch back to 4k for easy to render games and for desktop/app use of course.
