I don't know about you, but I've been wanting a proper gaming TV for a long time. I ain't rich, but I'd drop the cash to play 120hz 4K games on my couch.65" is really stupid. People don't have their gaming PC's in their living rooms and use them sitting on the couch. 40" would have been a massive hit. This screen size literally eliminates like 99% of PC gamers.
However, I am still really happy they did this, because they are finally bringing the focus to larger monitors. Honestly, anything under 40" isn't taking full advantage of 4K. I can't imagine going back to a 27" or even a 32" now. So I hope this will prompt more 40"+ monitors. My LG 43UD79 isn't the best, but the options at this size are very limited, so I had to settle. I hope this time next year there will be a lot more options and I can update to something with 120Hz and HDR that's not a TV.
I just move my head around to see the different parts of the screen, so it's like a multi-monitor setup, but it's just one monitor.
I can't see it being more than around 4k (get it?). 5 grand for a VA monitor when you can buy OLEDs for 2500 is pretty ridiculous. The G-Sync tax doesn't make up for that. Really, if LG wasn't stupid, they'd be slapping G-Sync on an OLED panel and selling a display for like 3k.
I too sit in my couch (though i use a 27" monitor vesa mounted on an arm from the wall that i fold out), and I can sit there forever, more comfy than any chair.Can you do that for hours on end? No back support, no forearm support, legs for desk. I never understood this. This isn't your main PC or your main monitor I'm guessing. If I drop $4K on this monitor, it's going to be my main monitor.
Linus estimates in the $5k ballpark range. Seems a little high but still. Damn.
My ballpark estimate is around $5k, as well, considering the extra tech in it. An OLED doesn't need full array backlighting to do HDR, for one. But I'd honestly take a BFGD over an OLED at this point.I can't see it being more than around 4k (get it?). 5 grand for a VA monitor when you can buy OLEDs for 2500 is pretty ridiculous. The G-Sync tax doesn't make up for that. Really, if LG wasn't stupid, they'd be slapping G-Sync on an OLED panel and selling a display for like 3k.
The extra tech is a gsync module which isn't terribly expensive (should be identical to the one used in x27), and some extra leds. Creating a production line to make FALD is tricky and expensive. Once its up, the extra cost of extra leds is next to nothing in this context. The cost of producing this is almost identical to the x27 + the extra shield hardware on top which realistically does not cost much more than a chromecast to produce.My ballpark estimate is around $5k, as well, considering the extra tech in it. An OLED doesn't need full array backlighting to do HDR, for one. But I'd honestly take a BFGD over an OLED at this point.
Current 4k 65" HDR 120hz units are what, $1200-$1600? so its $3400-$3800 extra for a gSync module ? lol
ok add another $150 for Shield
I thought Linus was saying that as a joke, or it sounded like it was meant to be a jab at how gsync mark up is a rip.
Native 4k 120hz 40-77" _panels_ exist yes. Plenty of tvs capable of 120hz at lower resolutions or in 3d mode. Slap a gsync module on them and they would work perfectly (The ONLY new thing here is the FALD controlled by gsync module with no input lag, everything else is old tech, although this panel will probably also have faster response time/overdrive).Native 120Hz 4K TV's exist prior to these? I don't think so. At least not ones you can readily buy.
https://www.samsung.com/us/televisi...vs/65--class-mu8000-4k-uhd-tv-un65mu8000fxza/
120hz is what the screen refreshes at, though I'm pretty sure, like most TVs it only takes a 60hz input.
It is the same thing. The input you can send to the controller has no relation to the properties of the panel whatsoever. More or less any 4k 3d TV panel would work in 4k 120Hz if you slapped this new gsync module on it.That's not the same thing. These new displays accept and display at 120Hz signal all the way through. No different than lower resolution PC monitors we have now. Only difference is this is at 4K.
This is all new.
This is all new.
So in your view, a displayport connector, gsync module and shield, are worth $2500?![]()
I left open the 1%.
Just curious, you like using a keyboard and mouse like that for hours on your lap?
In my testing, for 4K resolution you want your eyes to be about the same distance from your screen as the diagonal of the screen. IE: 32 inches away for a 32" 4K monitor. 65" display is in a bad position. 65" is too far away for a desk scenario and too close in for a living room/couch setup. So in reality sitting that far away from a 65" display is less immersive.
There are exactly zero 120 Hz 4K input displays of any kind as of right now. DP 1.4 and in 2019 HDMI 2.1 is what will enable that. Those will come with development/bleeding edge tax.
I think display port 1.4 in current nvidia gpus can do 4K at 120hz without any problems , So why we wait for HDMI 2.1 to do the same purpose which display port 1.4 does ?
Uh, how about the TVs this thread is about?Because TV manufacturers have no interest in putting Displayport on their products.
But this isn't a TV , it is a giant pc monitor so i think display port 1.4 will be enough to run 4K at 120hz at least for me without having to HDMI 2.1 .Because TV manufacturers have no interest in putting Displayport on their products.
