hakkafusion
- Jan 2, 2008
I would second the removal of the headphone/mic, in favor for more USB, but I might be in a minority. In all honesty, I'm perfectly happy with the way the case is designed as is(+ the 1/4'' length adjustment), and I'd buy one in a heartbeat if it were available.
+1 more usb the better. superspeed definitely. usb mic/headphones definitely.
You can do as much, you just have to be determined. If I modded the case to fit a PSU in the same way Lan-Gear's mITX does, I'd have all the same options. On mine, I sanded down the face, and filled in the drive bays, and added 2 usb ports instead of having the mic/headphone. It's a very flexible case if you like to mod. The point if this mITX case is that they're attempting to achieve the smallest possible footprint while maintaining long video card support and ATX psu compatibility, whilst not sacrificing cooling. I don't know why anyone would want a larger case for an mITX build. The whole point is that it's a smaller form factor. Besides, changes as drastic as you're suggesting would mean even longer QC time, and we probably wouldn't see this thing for sale for another few months at best.
i tried.but can't fit standard atx psu inside the damn nsk1380 without removing the front usb pcb. or it gets in the way of the video card. or have to cut the top rail. all in all, doesn't rly work.
as long as u say the h5o can fit, i'm in line =D
