seanclayton
- Oct 25, 2008
Fk u nerd fite me irl!
Seriously though. Even if I can't perceive any difference in the image, the higher resolution image is always going to be the better one simply because there's more data. Something recorded and viewed in 4k will always have more detail in it than 1080p. Higher res means that microscopic freckle that wasn't able to be seen before can now be seen. I don't care if I'm standing 10 ft back and cant pick it out with my bare eye. The image has a whole is more detailed therefore has to be a better image in entirety. I'm not convinced that the brains ability to discern an image can be completely reduced down to distance/resolution etc. The closer we can get to matching IRL the better, I don't care the distance. ( and yes I know we dont see in pixels ) .
Liars.
I'm 46 with shitty vision and I could see the 4k difference from 25' away the very first time I saw a 4k set back in 2011 or 12' or so.
I made my decision whether to keep it or not....
Pictures is not great qality, taken with a iPad camera,
I can feel the PWM like I did with the Philips![]()
You can see the effects that I'm talking about yourself at the test I linked to. I can certainly see it. I'm not talking about fast motion. See the test for what I'm referring to.
> (the motion makes the flaw more obvious when there's nothing else on the screen, again quite artificial). Due to the contrast variation it probably works all the way down to best case scenario.
Bummer. How how does PWM make you feel? Fatigue or headaches?
Have you tried any games on it? How's the motion on it?
I feel that my eyes is getting more tired then when I was using my BL3201PT. Wih the Philips I used to get headche, but haven't got it yet with the Sammy.
Have no game installed now, but will try tomorrow, need to sleep soon.
I will try to remove the stand and have the display on the desk directly, because right now I can't push the display all the way back so it's a bit too close, if I remove the stand I should be able to push it + 16 cm back.
How's your blacklight? Hopefully it's not at 20! Try lowering it to 10 to see if it's PWM, or if it's because it's too bright. Also, since you have the BL3201, can you do a quick comparison on the clarity, blacks, color, etc. between the two? Thanks!
I'm glad you see the effect that I'm taking about.![]()
Hey, question.
I have a vast collection of MKV's ripped from my Bluray collection.
In Windows, obviously, you don't get the upconvert to 4k from 1080p. What method are some of you guys using to get the upconvert?
Yes, but it's not a res test, and it's quite artificial.
Ironically I pulled a similar "trick" on someone when the tables were turned in this argument (I was claiming super high res does give a benefit on the desktop) some years back.
The reason why it's not a res test is that usually those test to a typical MTF (a certain contrast between points or whatever), whereas this this works down to almost no contrast (while the lines are full contrast).
When my backlight was above 10, I can feel the fatigue after a few hours.
Lowering the backlight to 5 eliminated the fatigue. YMMV.
Since i seem to be screwed for choice, which of these is the actual better model as they are the only two below 50-inch i can find that will work in Australia.
http://www.samsung.com/au/consumer/tv-audio-video/television/uhd-tv/UA48HU8500WXXY
or
http://www.samsung.com/au/consumer/tv-audio-video/television/uhd-tv/UA40JU6400WXXY
If i import a UK or US model then it would give me an invalid country selection i am guessing?
Is there any Country settings that current owners of US or UK models can see that let you change it to Australian?
Here are my settings in PC Mode:
Picture Mode - Standard
Backlight - 5
Contrast - 70
Brightness - 45
Sharpness 50
Color Tone - Standard
Black Level - Low
I use this for productivity in low light. No strain on my eyes.
Interesting. That supposedly goes against the logic that is PWM. More PWM = less backlight, vice versa.
I use your settings now and it feels good. It seems like it's better for the eyes.
All computer players do scaling and the "upconvert" is built into the scaling alg. Standard bicubic looks pretty decent, and it's not easy to do that much better.
So is it PWM or are you susceptible to the brightness which is known to cause fatigue? If it's not PWM, well, congrats!![]()
I notice some weird effect when I move around Windows, in Windows 7. It's like the window that I am dragging around is "shaking", and if I drag a window with text the text becomes fuzzy.
Is it some setting on the TV causing it?
I use Windows 8.1 and do not see that issue. That's a strange one. I wonder if it's because Windows 7 can't handle 4K resolution?
Disagree. There's a reason why Samsung leads consistently in image quality. Their software, coupled with the way they design their panels, were designed to delivers better results than a "generic" bicubic upsampling. If that were the case, the Vizio should look as good as the Samsung, and that clearly is not the case. However, it's pretty easy to test this theory out. Anyone with a Samsung hooked to a PC can test A/B and see the results for yourself.
Sure windows can handle that res, and I did not have such problem on my Benq.
Higher res will reduce the effect.
Samsung looks better because it has better colors and other processing. Most video processing is about adjusting those curves, sharpness, noise reduction, etc.
I'm also talking about computer scaling where it's more or less a solved problem. If you believe samsung does something superior, please demonstrate it.
PC Mode, UHD Color?
Spent some more time with the display. Played some Pro Evo Soccer. No noticeable lag for me. And if I don't notice it in this game, I won't notice it.
I did see some ghosting though, but I think that was the game. Played some Witcher 2 and noticed nothing there. So must have been something with PES.
Do you have a Samsung?
I've been to stores that sell TVs. What I've noticed is that Vizio or other lesser brands tend to have less aggressive dynamic video processing which don't stretch out the colors/constrast and all that stuff which makes video look "good" (and desktops look hideous).
I calibrated my display using my Spyder3. It looks much better now. It would probably be much better once I get a card that support 4:4:4.
Sounds like you agree that Samsung uses a superior video processor.
