Zarathustra[H]
Extremely [H]
- Oct 29, 2000
And one more question : do you guys, use HDMI 2.0 cables, for 4 K ?
Is there any advantages vs 1.4 HDMI cables @4K ?
The truth is, that there is no difference in the overall cable design between HDMI 1.4 and 2.0. There is no such thing as a HDMI 1.4 cable vs. a HDMI 2.0 cable. The overall cable specification remains the same, EXCEPT for the bandwidth requirement.
Before the launch of the HDMI 2.0 spec, cables were simply tested to the old spec (10.2Gbps). Since the release of the 2.0 spec, many manufacturers have simply taken the same cables coming off the same production line and instead now test them to the new spec (18Gbps).
The difference is they simply throw away a few more cables at the end of the line, so their yield goes down. (or maybe they just bin them and label them as 10.2gbps cables, who knows)
Many of these same cables previously labeled at 10.2gbps, are fully capable of 18gbps, there simply is no guarantee.
Now, what do you need for 4k?
It depends on your display.
If you are looking to output 4k to a TV over HDMI you should ideally have a cable capable of 18.2gbps.
If the cable (or gpu) is not capable, one of three things will happen depending on the auto-negotiation between the GPU and TV.
1.) You will max out at 30hz instead of 60hz when at 4:4:4 chroma. (I tried this, even on the desktop it sucks)
2.) You will drop down to a lower chroma level and it will not look as good, especially on colored text (blue/red/purple appears to be the worst)
3.) You will get no signal at all.
If you have a 4k monitor with DP inputs, just keep using DP, it should work.
Furthermore, people in this thread have found that long cables - even when labeled as 18gbps - tend to not work well if you want 4k 60hz at 4:4:4. 6ft (2m) & 10ft (3m) cables tend to work, but once you get to 15ft (4.5M) cables it is hit or miss, and I ahve yet to see anyone get a cable over 15ft to work.
