- Nov 16, 2005
I’m proud of you.
Small house, a little over 900 sq ft so it's able to hit everywhere it needs...but it's range is definitely reduced being in there. I figured if I needed to I could mount it on the side but so far so good.Nice! That is sweet and simple! How does the wifi work in that rack? Looks like you've got it in a faraday cage.
Thanks that was my old job, I'll grab a pic of the really nice setup I did at my new one (here's a preview of a couple of layouts we tried).I’m proud of you.
Nice! That is all that matters!Small house, a little over 900 sq ft so it's able to hit everywhere it needs...but it's range is definitely reduced being in there. I figured if I needed to I could mount it on the side but so far so good.
Ignore the hdmi over ethernet adapters and such, this was 6" cables.
We had LEDs in the cable management at one point but those were taken out for whatever reason.
Each cubicle gets 1 port so all'ofem need to be hot, voip phone passes through to computer.
Red is executive offices and no touchie ports, green is APs, white is conference phones
The nice thing is even when it gets messy like the above it still looks nice, plus tracing and cable replace is a piece of cake.
As I mentioned all the ports are hot, ie) every single patch port is live to a switch, we wouldn't need to add more, or if we did we'd need to add a new patch panel and switch anyway so we could have it spaced and organized accordingly if we did.That looks really nice. But, what do you do when you need to add another switch? You’ll have to move everything to keep it evenly spaced.
If you can get the USG Pro. The standard USG can be grossly under-powered depending on your connection and what goodies you have turned on.
yes for the submerged rack pics. Never seen these beforeI have a VERY small network set up at home finally.
The ancient Dell on top is handling firewall and adblock duties via pfsense and pfblockerng
it connects to an inexpensive dlink fully managed gigabit switch to provide network connectivity for the R710 and my home PC and trendnet mesh wifi hub
The R710 on bottom is running ESXi 6.7 and runs a few VMs that contain plex, emby, nextcloud and a few other things.
Once we move I plan on getting a rack and adding more hardware.
I'll post up some pics of our submerged racks from work tomorrow if I remember to get some pictures.
I like the idea of using that small temp/humidity/clock thingee to have a quick monitor of the environment--where did you get it and how much was it?Cisco SG250-26P powers the other 6 IP cameras as well as the AP's in the shop and extra garage (2 x UAP-AC-IW)
Backup Netgear ReadyNAS RN102 with external enclosure to back up my Netgear ReadyNAS RN516View attachment 151893
Whoa! That is unreal! I thought they would be custom servers or something. What is the liquid being used? That can't be water, can it?
Thats some serious fucking gear. What does your company use the GPU farm for?The liquid is called Electrosafe dielectric liquid coolant. It is both electrically and chemically inert. It has the consistency of mineral oil. The server chassis are custom made but the hardware is nothing special. Normal motherboards, ram, nvme, ssd and GPU (for the GPU nodes, we do have a lot of cpucompoute nodes that are not in oil) The second two pictures those servers have 4 RTX 2080 ti's in them. 3 quads (4 tanks per quad) 42 chassis per tank (168 GPU per tank) = 504 GPUs The first picture those tanks are pretty much all 1080 ti tubs.
they all run 10GB network (the black cable) and dedicated IPMI (the white cable) PDU and switches are mounted on the back of the tanks, but we have submerged switches in the past as well.
Not related, but I got this sweet led backlit blanking panel today.
That is awesome. Where did you get that?The liquid is called Electrosafe dielectric liquid coolant. It is both electrically and chemically inert. It has the consistency of mineral oil. The server chassis are custom made but the hardware is nothing special. Normal motherboards, ram, nvme, ssd and GPU (for the GPU nodes, we do have a lot of cpucompoute nodes that are not in oil) The second two pictures those servers have 4 RTX 2080 ti's in them. 3 quads (4 tanks per quad) 42 chassis per tank (168 GPU per tank) = 504 GPUs The first picture those tanks are pretty much all 1080 ti tubs.
Seriously. I've got 3U that need to be blanked thanks to rear-facing top-of-rack networking stuffs. I'd LOVE something like that for my rack.That is awesome. Where did you get that?
I’m running a regular usg on a gig isp connection (940/50) with no issues.I even have the DPI data inspection turned on. That being said it does run very hot sitting horizontally with the status light facing up (even in open area). It runs about 15 C cooler now sitting/mounted vertically. The no fan passivle cooling is great too, it sits on my desk or in my closet.I was considering doing that, I will look into it, thanks.
What are temps like in that thing?
Small, but potent little sucker this one is.
I'd at least sit the cover on top of it as the cpu needs those fans at the back to pull air across it to cool.Power supply in pfsense server died. Had to rig this up until replacement comes in.
