Same is true of mirroring. Mirroring works fine across multiple databases, too.Clustered because there are quite a few databases running on the cluster. Second, I only need one license of SQL Enterprise if they're clustered.
Corge, that is BEAUTIFUL!
You enable mirroring for each database, yes. It doesn't take long.I thought to mirror you have to setup each mirror
Then mirroring needs to be set up dynamically. Just as scriptable as the database add itself.what if databases are added dynamically (its odd but I have seen this)
I finally got to the end of this post and thought it might be time to share.
When I started, this building had a half dozen different switches with whatever patch cords they could find thrown into the rack. just draping the cables in front of everything.
Things were going great with the new install until...
The 4506-e did not have enough switch modules for the number of drops. Then the second switch ran out of ports because we could not remove the AD controller like the server team was hoping.
Then the only fiber we had in stock for the uplink for the two switches was this massive bundle.
Also no brackets to mount the 2811 which added to the pain.
Then the finally slap... the cable order was shipped 3/4 blue and the last 1/4 this ugly purple color.
wish I had a before picture, but oh well.
Where did you find those rj45 ends/boots that your using that are sorta clear looking. I saw these once and have never been able to find them since.
i would pull them all out, get a spool of cat6 and make all the same color and cut to length what you need and buy a bunch of velcro straps, it would look alot more professional and save some headache in the long run of tracking stuff down
That's a shame... who would let a cable job look like that? lol
That's how the real world looks a couple months after a new deployment.
What do you guys think of the Panduit cable managers?
also
What the hell should I do with this mess?
There is no space between patch panels for more tidys, there is no opening at the sides of the rails its just a solid front!
Pull every wire out and do this:
Or how about "doing it the "[H]ard way"?
Why? How do you justify the downtime and expesne?Pull every wire out and do this:
how long does it take you to troubleshoot a bad line or to add a line, because you have to sort through the mess.
Your explanation doesn't tell me how the slightly longer conditional time to diagnose or change a circuit is justified by the certainty that the system will be down for an extended period while it is re-wired.Is this your client or your own office? If its a client (or even your own office) you justify it as this... how long does it take you to troubleshoot a bad line or to add a line, because you have to sort through the mess.
