I just got my "repaired" monitor back. The repair report says "NO PROBLEM FOUND" for the horizontal lines. Are these people blind? Not only that, there's no indication they even checked for backlight bleeding or the power management problem. This is ridiculous. How am I supposed to get this fixed?
I bet if I were to get a 23" Apple and a 24" Eizo right now, the Apple will have backlight bleeding and the Eizo won't. Maybe I should considering the poor quality of this NEC.
The only talk of uniformity I've seen so far is brightness uniformity, which is not the same thing.
It's not like I tried one or two monitors. Explain to me how I keep getting monitors with the same problem if the problem is not common on those monitors.Tamlin_WSGF said:And thats your personal impression of this, based upon your experience and what you've read from others. I fully respect that. Generalizing upon this, claiming it to be a fact however, I would disagree upon.
What kind of evidence are you looking for? Several people in this thread have reported the same backlight bleeding. Even that Japanese review shows theirs has some backlight bleeding, although it's mild in comparison. I'm not saying they all have the problem, although I suspect most do, but if backlight bleeding wasn't common with this monitor, people wouldn't be getting replacements with the same problem.Tamlin_WSGF said:There is no evidence supporting either that backlight bleed is a general defect of the NEC 2690 or H-IPS panels.
Yeah, and many people have spoken highly of the gaming performance of the Samsung 244T and claimed theirs didn't lag, yet the lag turned out to be real.Tamlin_WSGF said:Reviewers have spoken highly of the backlight uniformity and also about the colorcomp function.
Of course backlight bleeding can happen on all panels. That's not the point. The point is how common is it?Tamlin_WSGF said:My experience is that I've heard reports of backlight bleed on almost all panels. Especially of consumer grade panels. I have gathered some links about different brands and backlight bleed besides the one about the Gateway. I can present them, or we can agree to disagree upon this.
I've seen the pictures of backlight bleeding on the 20WMGX2. It's not the same. It's not cloudy. It looks more like the panel was mounted too tightly in the corners. Another thing people mentioned is it improved significantly over time. That doesn't happen on the monitors with cloudy backlight bleeding. Something is definitely different about the 20WMGX2.Tamlin_WSGF said:Now we're getting somewhere.There are reports of the 20WGMX2 with backlight bleed too. Some of them seemed to be pressure related though (like painmans 2690WUXi). I'm open to that there can be variations as well between them and that this can lead to backlight bleed.
I should clarify. I'm not saying backlight bleeding is inherent with IPS technology. I'm saying it seems to be inherent with the way LG assembles IPS panels, so the same problem makes its way into many monitors with IPS panels. The problem is definitely fixable, but manufacturers don't seem to care.Tamlin_WSGF said:There are many causes of backlight bleed. That the 2690WUXi should be especially vulnerable to backlight bleed, I find hard to believe. This I would want to see proven first. Especially since this H-IPS panel have a different structure then standard S-IPS panels as shown in the Japanese review.![]()
No, not that I know of.Tamlin_WSGF said:Wasn't the Dell 2005WFP modified as well? I seem to remember that it had higher initial brightness and contrast then the panel default and similar panels on the market.
You make it seem like they're all equally vulnerable to backlight bleeding, which is definitely not true. Certain monitors have more reports of backlight bleeding than others, and certain panels have more reports of backlight bleeding than others.Tamlin_WSGF said:My point (as originally written to zoner3) is that all panels, brands and models are vulnerable to backlight issues. Backlight bleed has several degrees and causes.
ColorComp does not affect black, so it should not affect backlight bleeding.Tamlin_WSGF said:Colorcomp is a nice tool and help even out the uniformity of the panel, and so did zoner3 experience himself .
