AFD
- Aug 7, 2013
Yeah I guess it's easy to forget about it but indeed, we need it for pulling the top panel off.
You can also start at the front, instead. Remove the front panel, then gently apply pressure under the front ODD slot overhang of the top panel (grabbing on the sides near the frame, not the very front), and then work your way back.
I can't remember exactly, but I think that's how I've been doing it. Though there's probably less chance for bending the panel or breaking clips if you can get all four mounts to pop at the same time (don't think I've ever been able to).
