I'm also having the same issue with logging in and the site not responding. I tried what xp3nd4bl3 said but unfortunately that didn't work. Any suggestions? Thanks!
So should we put it in the "shipping label" field or is the "phone number" field sufficient?
Normally I would write ...
Name
Street + No
ZIP + CITY
COUNTRY
... on the shipping label
Which begs the question of why the 'State' field is even necessary if not all buyers State's are listed and presumably the relevant data is required only on the shipping label? If it's not needed then why is it there? And if it is needed then I would like my 'State' in it.
Hi to all, the boxes are still available for sale?
I'm doing a dual boot- using a z77 gigabyte tho. I've got a nice new i7 3770k to pop in and just can't justify buying a haswell, so sorry I can't offer advice on the 8 series chipsets. Bummer for me is on the z77n-wifi board is that there are only 2 sata III ports, the other two are sata II. I've actually been looking at this http://www..com/prod/4-port-sata-iii-ii-i-switch-with-keylock-and-led-6gbps-compatible/254668062.html gizmo with the idea that I could remove the bezel and mount it to a pci slot, maybe having to change the switch and selector button... (sorry getting off topic here). tonymacx86 has some people hackintoshing the Asrock Z87E ITX board.... http://www.tonymacx86.com/search.php?googleSearch=Asrock%20Z87E%20ITX%20 you may have fool with differnent installs of nullcpupowermangement.kext, and occasionally using an older version of multibeast has been helpful for me in the past. You might also need a dsdt, check tonymac...
So with the phone number, does that need to be in the shipping label, or would having it in the details section be sufficient. Who is the number for? the shipping companies, or for your own reference.
Yes, the switch system might work, and interesting concept, still limits you to two drives, but I guess if your switching between different OS's, you can still maintain the same storage drive.
OSX is on 1 ssd, windows on another ssd, a 2 tb 3.5" storage drive for osx and a 1 tb 3.5" for windows, plus the ODD (which yes, I really use a lot)- so 5 SATA ports needed
How about the single 3Tb 3.5" drive, running macdrive on the windows side.
Was unfamiliar with macdrive- looking into it now... seems like a good solution, thanks!
I am totally adamant about separate physical HDDs for the os's though.
Thanks for the clarification update Wahaha:
The M1 package could arrive any time between mid NOV 2013 to end of JAN 2014, so please provide your permanent address.
With this in mind, since i'm moving in late November I'm not going to take any chances and went ahead and change the shipping address to a family member in town.
On a different note...
Regarding the build, how many here are intending to build a hackintosh, and has anyone had success with any 8 series chipset board yet? I have bought the Asrock Z87E ITX board because its got the closest to idea layout for this case in-terms of connectors, cpu placement, wifi and fan controls, but I still haven't managed to get sleep and shutdown working yet. Everything else, wifi, sound, speed step, everything else works nicely.
The gigabyte is the safe hackintosh choice, but the cpu layout kinda sucks jammed up against the ram and PCIe, and all the connectors for USB/front panel, sata ports are all on the top left, furthest away from where these connect to. And the other connectors are all scattered around the board. Cable management will be poo at best.
You don't even need macdrive. just put two partitions on a single 3TB HDD.
One 1TB NTFS or ExFat partition for Windows
One 2TB HFS+ partition for OS X
Last weekend I got the modular silverstone SFX PSU that everyone has been discussing. From the discussions, I was worried that it would be loud, but it is quieter than the random fans I already have and the intel stock CPU cooler. It is a lot quieter than a really cheap scythe 120mm fan that I used to have that was super loud and sounded like a hairdryer. I don't consider the PSU fan noise to be a big worry at all.
Sound is subjective. People can get really fixated on it. I have a buddy that is down right anal retentive about sound in his pc builds. I always chuckle at him because what I hear and what he thinks he hears is way two different things. Each to their own though.
