Unknown-One
- Mar 5, 2005
All recent processors are upwards-multi-locked (with the exception of the overpriced Athlon FX series). You can turn the multi down, but not up. This is to prevent manufacturers from raising the multi and selling it as a higher class chip.MOC said:I need help ,This chip is from March 2004 ,but never installed untill today ,new in box
Was installed in a DFI 250GB UT-NF3.Modded xp-90 ,G.Skill ram.
First boot I went for it ,after going into bios first ,booted right up @ 2814Mhz, HTT=255, HT.04 ,1.6v ,2.9v ddr.So after letting it go for 3 hrs. running OCCT ,all stable.
I decided to change multi ,but no go ,cannot leave 11x under any combo of voltage or
multipler ? tho when in 11x I can go up and down at will ,even had it at 2919Mhz ,but then got out of it to try other settings! So at least it clocks pretty good ,But why can't I chenge the Multiplier..thanx for any help.
Specs are : 3400+ Clawhammer
AMN3400BIX5AR
Version 2.6
Revision SH7-CG
