thw webpage could be doablediablo111 said:Anyone make any headway on a page/site? Do we need to everyone PM or email a central person to make a list of members?
1. (cf)Eclipse - [B]425[/B]
2. robberbaron - [B]410[/B]
3. tsuehpsyde - [B]330[/B]
4. Borgschulze - [B]325[/B]
5. CCUABIDExORxDIE- [B]300[/B]
6.
7.
8.
9.
10.
(cf)Eclipse said:thw webpage could be doable
and if you're gonna pm someone, tsue would be the man to talk to.. being the pr guy an all![]()
though i'm convinced 2.0 would work better... if it actually workedrobberbaron said:A word of advice... use the 2.5x LDT multi for best results.
that sounds like a good plan. i'll discuss and possibly assign someone to the webpage. they would have to have good html skills, possibly php if you wanna go that far, and be willing to update every time tsue updates his listdiablo111 said:Doesn't have to be anything fancy. Just a list of members...maybe the name could be a link to their [H] profile? That way if someone needs help or would like to contact other members, they wouldn't have to sift through this thread (which with all the crapping that's going on and off topic stuff, is kind of a mess now) trying to figure who is in or out of the club...they could just check the list.
Borgschulze said:http://valid.x86-secret.com/show_oc.php?id=18549
I can donate 10mb of webspace for the website, access through FTP.
It will link as www.home.cogeco.ca/~USERNAME
Yep.robberbaron said:Would you be able to make the uploading, etc available to the officers of the club?
YGPM.robberbaron said:Done![]()
that's about where my neo tops out too..tsuehpsyde said:Highest HTT I've gotten is 317MHz on stock chipset voltage
this is true, i kinda forgot about thisBorgschulze said:And the Revision E have not hit store shelves. Well the slower ones haven't.
Borgschulze said:It's revision D...
There are no Rev C S754 Semprons as far as I know.
Nuc_E said:Not going so well. The most I can get prime95 stable on the stock cooling is 8*281 at bios setting of 1.6 volts. Either the Epox overvolts the core a lot or incorrectly senses the voltage because CPUZ and Epox's included monitoring utility reported the voltage as 1.7.
I am wondering if the culprit could either be the motherboard or the power supply. I have an Enermax Noisetaker on the way, but I guess I am a little impatient and wanted to play around I used a cheapie 430watt Coolermaster (19A 12v+) I had that was going into a machine I was building for someone else.
Summary:
8*281 = 2248mhz
HT Link Multi = 3x
Core Voltage = 1.6v in the bios (1.7v in CPUz)
Temp = 46c under load
yup, on air, ambient was around 14-15cashmedai said:Didn't you get like 3.1 or something because of lower room temp at the time?
CCUABIDExORxDIE said:yes you can. youve already added it to your sig. thats quite the rig you have. a gig of mushkin redline. i like that ram
