Hold onto your horses! NCIX is selling its OEM version for $719.99 CAD:
http://www.ncix.com/products/index....WP-BN&manufacture=LG Electronics&promoid=1064
but this is incorrect. 178/178 (S-IPS) Ultra Wide Viewing Angle,
hmm, i'll have to do a comparison, i haven't noticed the sharpness bit
Sorry if this is too obvious of a question, but have you tried turning off ClearType to see if the text looks better to you? I find that it looks much worse on some monitors than on others. Since it tries to improve the smoothness of text by using subpixels, you can get some really obvious color fringing, which I think is what you're probably seeing when you refer to the black diffusing into the neighboring pixels. You're seeing individual sub-pixels of different colors being used at the edges of the text, and this can cause it to appear less sharp.for games the LG seems fine. but for reading text things seem a bit different. i use the ClearType text smoother in windows XP for everything. my room has relatively low light.
the text seems to be fuzzy especially black text, as if the black is diffusing into the neighboring pixels. on white background it gets worse that my eyes start squinting because the screen gets so bright all of a sudden and i have to turn down the brightness. but when the brightness is lower (between 14-17), the white around black text is not so white. but by then my wallpaper and pictures look so dark that i can't make out any detail in darker areas.
What settings are being used for this monitor?
i took some close up photos between the LG and my macbook pro 17" i'll post them but it was hard to hold some variables constant
I doubt this experiment would make it into any peer reviewed journal. Nevertheless, I find the LG to be very sharp for my purposes. Maybe the macbook pro isn't very sharp either and it could be relative. It's a pitty I don't have a 2407 to compare.
how is the backlight on the dell?
would this backlight issue be covered under warranty? also, does the 2407 remember what aspect was selected for each resolution? could you try going to 1600x1200 with 1:1 aspect and then going back to native and back to 1600x1200? does it hold the 1:1 aspect or does it stretch it now and you have to go back into the menu? do you use any aspect settings in your drivers? i have an ati card so maintaining aspect ratio with the drivers is.... not working.... can't remember when it did. thanks
When my computer has been turned off for an extended period, the monitor won't come out of suspend mode.
I have to turn the monitor off then back on.
Anyone else have this problem with the L246WP?
Another question how can the service menu be accessed?
Input lag actually refers to any latency a monitor has in addition to the response time of the panel. It has nothing to do with resuming from suspend. Panels with bad input lag have a perceptible delay between the user input and the screen's update. People who play fast-paced games (e.g. first person shooters) seem to be especially annoyed by this. By all reports, I don't believe input lag is an issue with the LG (in fact, in Jim's comparison with the Dell and BenQ, it actually had the lowest latency).I've experienced the same thing. This is known as "input lag," if I'm not mistaken, and is common on 24" LCDs, though some are slower than others.
Just out of curiosity, what's the reason you're returning it? Because of the text blurriness you mentioned previously? Or were there other issues?mine is going back too. i think i found a new love:
http://www.necdisplay.com/Products/Product/?product=75787ebd-557c-4900-9109-98880244779d
but at what cost???
Very strange. Just to clarify, though, when this happens you just have to turn the monitor off and back on? You don't need to restart the PC? I'm trying to understand whether this is a deal-breaker or just an inconvenience.so, to conclude, I can't use any device that sends a signal on or off to the monitor via component if I want to go into standby and resume in windows via HDMI.
