Looks like you got the last one for a while too, nice catch![]()
They estimate more in tomorrow
Yay! Bought one on the Egg! Finally.
hey guys,
i didnt read thru all the pages but I wanted to ask if anyone has seen any sites with reviews on this unit.
I am itching to get one to complete my media pc, (sans my need for an HTPC case)
http://img58.imageshack.us/img58/7807/tvviewpo7.jpg
so close!
What sort of review do you need? It kicks ass.
haha
the concept kicks ass,
but application matters, such as how loud is the drive, does it spool up loudly.
the quality, speed of startup.
Ha, yes the drive kicks ass, but the software i've found lacking. I couldn't get transformers to work so I tried using AnyDVD, which then broke playback of Spiderman 3. I finally ended up upgrading PowerDVD to a beta version and that fixed things but it was still quite disconcerting that Cyberlink can't keep up with new BD and HD releases. Oh well.![]()
It is not a loud drive at all. Granted I have a door on my case, but I don't hear it spin up hardly. Its quicker for blu-ray than for hd-dvd naturally because its read speed is faster in that format. From when i put a disc in, and when i get it to play I would estimate 15-30 seconds. As far as I can tell this thing is top notch quality. Time will tell of course.
I had to scour the internet for the latest PowerDVD to play Spiderman 3. I do not yet own Transformers so I can't say but I couldn't play any of the Spiderman Trilogy until I upgraded. I have to say that CyberLink has a crap update system. I essentially had to get the new one by torrent even though I legally own (or have licensed anyway) the software. I simply couldn't either find a legit update, nor get the software to update itself to the latest. Aggravating to say the least.
haha
I had the same problem. Why wouldn't Cyberlink just put up the 3391a beta instead of making everyone contact their customer service? I don't understand the reasoning at all. I didn't know that helping your customers had to be so difficult. If there was competition (which from what I remember there might be soon) I would switch.
You must not have owned a LG drive before. LG always uses riplock and rarely makes its firmware available for download. Because of this, you won't find many modified LG firmwares with riplock removed. For example, try to find the factory firmware for LG's other SATA burner, the GSA-H62 which has been out for 6 months. You won't find it for download, nor will you find a modified version.
I'm just curious how low LG restricted the read speed on this unit. Software like AnyDVD is only able to defeat region coding, not riplock. If you don't know what riplock is, here is a primer:
http://www.afterdawn.com/glossary/terms/riplock.cfm
on ncix.com it says "O.H. Quantity = >10." What does "O.H." stand for?
Transformers used ISO-500 film, so there is nothing you can do about grain and sharpness in some scenes. It is a great transfer, and it would look the same whether it was on BR or HD DVD. However, if you are using a ATI 2xxxHD or 8500/8600 card, the hardware decoding and filtering technology does a much better job with applying de-noise filters to the picture. On my 8600GT hooked up to the 1080p projector, Transformers looks simply amazing.edit:
Got it to play in PowerDVD and Ratatouille looks amazing! No surprise there since it's a render. I'm a bit disappointed with Transformers because it's not a good transfer at all. A bit grainy and blurry and not sharp at all. Very grainy. I thought Transformers was shot in digital? 1 for Blu-ray 0 for HD.
