- Jul 5, 2012
Hmm, it seems the pixel shift feature has some bug that causes blurry picture especially at 4K 120 Hz 4:2:0. If you toggle pixel shift on, the picture becomes blurry. Toggle it off, picture is sharp.
LG has still not fixed the issue where despite pixel shift being disabled, it will re-enable itself when the display is restarted but the UI still says its disabled. Toggling it on and back off again fixes this.
Ah yes I forgot to follow up with the solution on that when I complained about it earlier last week...lol can't believe the solution was as simple as turning it back on then off.
