Yes it works in 4k120 4:2:0. I favor it over 1440p scaled, but try for yourself.Does gsync work with 4k120 at 4:2? At work all day and won't be able to test for a awhile.
I stick to 1440P for gaming. I think the picture is amazing, but YMMV.
Is the drop in chroma noticeable?Yes it works in 4k120 4:2:0. I favor it over 1440p scaled, but try for yourself.
Can anyone give ma a report on how this is for productivity tasks (such as document production and reading academic/legal sources on the web)?
Or just four 1080p IPS screens on monitor arms... probably easier on the eyes and to arrange in a useful fashion.It will work but you can have similar sized displays much cheaper if that is your main use case.
I wouldn't use an OLED for work that involves leaving static images on screen for long periods of time.Can anyone give ma a report on how this is for productivity tasks (such as document production and reading academic/legal sources on the web)?
Damn that's slick, never thought i'd like something that big as a monitor but with it being against the wall it doesn't look too bad.
My main use will be gaming. I do 90% of my work at the office but there may be a weekend or a night I pull an all-nighter. So long as it’s not just wretched to use for that.
I am in the same situation were I use my C7 for gaming/movies 90% of the time and occasionally for work (well more than occasionally last few months). The OLED can be used for this purpose but it is not an ideal work display. The most annoying thing can be ABL. Just scrolling text around in a window is not enough "change" so every few min your screen dims and you have to move some window to get it to undim.
Also for work you tend to have a lot of static screens (at least I do with VNC) so it is not ideal for OLED.
In my case I wound up creating a smaller (typically 1440p) VNC window to use for work on the OLED with the rest being a frequency changing Windows background image slide.
Just played a round of Killing Floor 2 on the 55" CX....Yup...Zero regrets moving from my PG348Q - 3440x1440 UltraWide. Was worried I'd miss the ultrawide aspect ratio - nope not at all. I sit about 5ft away from the screen and its just enough where I dont have to move my head to see everything on the screen. I've gamed on a OLED before (I have a C6 in my movie theater room). This is pure bliss - everything that OLED brings to the table and GSYNC...Love it. I also like how it has Freesync support too - no longer bound to GeForce GPU's...
From the Rtings C9 Review, regarding SDR settings concerning ABL:
"If ABL bothers you, setting the contrast to '80' and setting Peak Brightness to 'Off' essentially disables ABL, but the peak brightness is quite a bit lower (246-258 cd/m² in all scenes)."
Yes you can save this as a preset and it would probably be reasonable to have one for desktop and another one for gaming or movies. You will probably have to tweak presets to make them match.I don't know the OSD of the LG OLEDs enough to know if you could save those settings to a simple named mode that you could switch back and forth from on the same input like I can on the vizio FALD TV in my living room, but if you can it is very handy. I do settings on my Vizio tv for day, night, animation/anime, extra-dark content, pc, game/console which can be switched between on any input. In my case currently these are a nvidia shield, ps4, blu-ray player, and a laptop hdmi when I connect it once in awhile.
This sounds like a configuration issue because I have noticed no issues with the way my C9 is setup regardless of what is connected.Anyone with a CX, is the colors washed out it in PC Input / Game Picture mode like on the C9? It's easy to tell; just switch between all of the picture modes on an colorful image and see if the other picture modes look much more color vibrant.
Just mounted my CX 55". Fucking amazing!
Great looking setup. What's your impression of image quality, and black level issues when you're using Gsync? Are black levels really impaired, or is the difference overblown?
G-SYNC works with HDMI 2.0, but it's only available with Turing and up (RTX 20- and GTX 16-series) on LG OLED televisions.Tonight I've decided to play with the HDR settings, and try and understand how G-Sync will work. I've managed to:
1. In the display adapter, set the display to 60Hz (if not, the following doesn't work in 120Hz for me)
2. In Windows 10, set the display settings to HDR
3. On the TV, go into the picture settings and set to HDR - Game Picture Mode
At this point, should HDR become accessible in those games that support it, right? I'm downloading Hitman 2 as a write this, but it's about 100GB
Regarding G-Sync - Nvidia control panel shows no G-Sync option - I'm using a 1080. Is this definitely because we need next gen 30xx series cards, to support G-Sync over HDMI 2.1? I'm assuming so, and I've always had it on my radar to buy one.
It doesn't really have either; it has HDMI Adaptive Sync, which is it's own 'thing'. AMD ported Freesync over to HDMI, but unlike with DisplayPort, their version isn't what the standards body adopted. And then Nvidia put out support for HDMI Adaptive Sync with Turing (16-- and 20--series) GPUs, while we're still waiting on support from AMD.I also like how it has Freesync support too - no longer bound to GeForce GPU's...
16-- and 20--series support Freesync over HDMI and DP, as well as HDMI Adaptive Sync that LG is using.Regarding G-Sync - Nvidia control panel shows no G-Sync option - I'm using a 1080. Is this definitely because we need next gen 30xx series cards, to support G-Sync over HDMI 2.1? I'm assuming so, and I've always had it on my radar to buy one.
I dont notice a difference in black levels between gsync on and off.
Honestly my c6 I had before the c9 I uesed for 90% PC/gaming lots of web browsing etc. When I upgraded blast year I took the time to do color slides it had the faintest bit around the task bar but under anything other then a dark room and uesing slides it wouldn't show up at all. So honestly it's basically a non issue because if it can hold up though years of 10+he a day PC usage what more could you ask for?I am in the same situation were I use my C7 for gaming/movies 90% of the time and occasionally for work (well more than occasionally last few months). The OLED can be used for this purpose but it is not an ideal work display. The most annoying thing can be ABL. Just scrolling text around in a window is not enough "change" so every few min your screen dims and you have to move some window to get it to undim.
MC warranties are the best.I briefly had the 55" CX and moved to a 55" C9 that was only $999 at Microcenter.
I didn't realize that the C9 does not have 4K @ 120Hz @ 4:2:0 ...... This is only a feature for the CX.
At any rate, very happy with my C9.
I went ahead and spent the $130 for the extended warranty which allows me to return the TV for up to 2 years. This will give me $1100 credit toward the 48" or just maybe I'll wait for the C11 in 2021 and put the $1,100 credit toward that set.
I should be able to get 4:4:4: @ 4K @ 120hz once I install my nVidia 3090 this Sept.
My CX 48" got delayed from this Monday to "5-7" days so might get it at the turn of the month. Hopefully.
EDIT: Now delayed to start of next month![]()
