- May 5, 2006
Apparently there is a HDR brightness slider so you could experiment with turning the HDR brightness down , using a dim viewing environment in your room, and seeing if Dynamic Tone Mapping looks better than HGiG or not. Also try putting black level on low instead of auto.
https://www.rockpapershotgun.com/how-to-enable-auto-hdr-in-windows-11
How to enable Auto HDR using Xbox Game Bar
Step 1: Press the Windows key + G at the same time to open the Game Bar. You can do this anywhere, any time, including if you’re not actually playing a game. Presumably “Xbox Game and Everyone Else Bar” didn’t focus test as well. Anyhow, click on the cog icon in the central bar to open Settings.
Step 2: Click the Gaming features tab on the left, and make sure both the “Use HDR with compatible displays” box and the “Use Auto HDR with supported games” box are checked.
Step 3: Optionally, you can click Adjust HDR Intensity and use the slider to make the image brighter or darker. I found the degree to which this makes a difference varies from game to game, but you can see any changes in real time as you move the slider, so just find your desired level of intensity and click Done to apply.
