Monstieur
- Jun 10, 2011
Unchecking the Enable settings for the selected display model checkbox fixes this. You can test for stuttering by looking at the Hz value in the FreeSync Information screen on the CX when running at a constant framerate capped below 120 fps. If the Hz value changes while the frame rate is constant, G-SYNC is stuttering.Nope. Definitely see some stuttering around 100-120 FPS. My test case is Battlefield 1.
Does anyone know a fix for this? The display seems fine from what I can tell, so I dunno.
