managed to snag one of these at best buy today for 329. Can't beat it for a 24" price.
Now to find a dvi->hdmi adapter![]()
Yes, it was only available in Canada for $329.99 as an exclusive Boxing Day sale.
Monitor is amazing thus far. I'm going to examine #2 shortly and run some tests for you guys.
However, for those of you who just purchased yours. Do the following:
- Look in the upper right quadrant of your screen
- Compare it to the other 3 quadrants
- Do you notice any sort of graininess or do your pixels resemble little boxes?
It's quite subtle so look closely to see if you suffer from it or not. Also, anyone have the whine when brightness is below 100? I think I might have it but it's so quiet that I can't even hear it while I'm typing, let alone listening to music.
I'm thinking about upgrading form my Dell 2005FPW to this, seeing the egg has them in the mid 300s, which seems like a steal.
I know my monitor is rated at a 16ms response time, and this is an 8ms, a significant upgrade. But from what I've been reading, people are having ghosting issues? Is this 8ms not true, or is that just the specific individual? Will this response time be better than my dell, because I'm not bothered by any ghosting on that. Thanks.
A ripped movie or a dvd?
BB:
The Samsung is a downgrade, however, the LG might be considered an upgrade.
You realize the Samsung uses a TN panel I hope.
The Westy you have is MVA.
Ive actually read most of this thread and havnt found info how on this screen plays with xbox 360?
Thanks for the info and taking the time to take pics
One last question. Whats with the hdmi sleep issue I keep hearing about? If pc is hooked up to hdmi and it puts the monitor to sleep, does it really go to a blue screen? I will be using a 8800gts if that helps.
The monitor will preserve aspect ratios from all inputs except regular video (and maybe s-video?). It has two modes for HD content: Normal (preserves aspect), and Fill (which stretches every side of the image to fill the 16:10 aspect of the monitor. SD material also lets you use the Zoom mode.
There is no 1:1 pixel mapping mode that I've seen for the monitor, so 720p content that doesn't come from a computer will still be stretched even if the aspect ratio is preserved. If you are using it through a computer, you can just have your video card do the scaling instead of the monitor if you want true 1:1 pixel mapping from it.
Jedi - you are the man! Thanks for the detailed answer. Good to hear that 720p and 1080p can at least both be displayed in the correct aspect ratio. The colors seem a little different between component and VGA - what is your impression of the two? I would think VGA is superior, but how bad is component, comparatively?
InFeXiOn: You're using two DVI->HDMI cables?
What graphics card?
