I just received my unit. Well packaged, quality stand, beautiful panel. Hooked it up and was playing with the settings and after a few minutes the touch buttons become unresponsive and the right side of the screen goes crazy. Checked the cables and everything is good so I power off and back on again. Same thing happens. Any one else having this issue? Doesn't matter whether or not I have dp 1.2 enabled, changing any other of the display settings doesn't seem to do anything to help. Also, I noticed a single bright/stuck pixel in the center area of the screen. Am I just unlucky or what?
I lost any interest I had in this display the minute I read it's a 16:9 display.
I just want to add that I have had the split screen problem that you have had. I have a replacement monitor inbound from Dell as we speak but my gut tells me it is more to do with my video card(s) handling MST. I've been in contact with EVGA as well. I'm running SLI 780 Ti's btw.
I've had my bios screen spilt, windows 8.1 desktop split into 2 separate resolutions. Early adopter problems....
I've tried multiple cards, cables, drivers, bios's.... now gonna try a different screen. Something tells me that card partners are going to have to send out updated bios's
Did the Dell representative give you a hard time when you explained the half screen issue? I had trouble explaining that particular problem to them (in India) but they went ahead and set me up with a new monitor since I had a bright/stuck pixel. I hope our next panels fair better than the ones we're sending back.
MSI GeForce GTX 780 OC Twin Frozr IV
With 2,160 vertical pixels, is not having 16:10 that big of an issue?I lost any interest I had in this display the minute I read it's a 16:9 display.
With 2,160 vertical pixels, is not having 16:10 that big of an issue?![]()
But it's still a 24" display. You can have 2.160 vertical pixels but in practical uses like reading a MS-WORD document in two pages mode (side by side) in order to have a letter size comfortable enough for reading said 2160 vertical pixels don't mean anything.
That's only if you assume you need to pixel double this display. I doubt you do. The default 1920x1080 ppi is very low, only 92 or so. "effective PPI" of up to 125 should be reasonably comfortable for anyone, something like a 150% scaling setting in Windows. So you do end up with more effective real estate on this display... unless you really want pixel doubling for some reason.
Oh man, just when I thought I had a perfect display. At low brightness settings, I've noticed the screen start to randomly flicker.
The monitor can go nice and dim, but obviously there is some issue with the backlight control at low brightness settings. Will play around with it a little more before returning it.
This might be a weird question. Am I suppose to turn off the monitor after used or leave the light pulsating?
What's the AG like? I've got a Dell 3011, and a Crossover 27Q, I don't know if I'm interested in purchasing another Dell with their AG.
Can anyone turn their monitor brightness down to zero and use it for a few hours and see if you see any slight backlight flickering (slight changes in backlight brightness)? Just wondering if I have bad sample or if there is a design issue with it.
Ok cool. Remember, the brightness change/flicker is very slight.
On another note, does anyone know how to get chrome to not look like ass with 4K? Windows 8.1 looks awesome on this monitor with proper high DPI scaling, but chrome text looks abysmal.
EDIT: Just tried IE 11, looks awesome. Can't believe Chrome would be handling high DPI so incredibly poor.
So what DPI setting are you using for the Dell monitor?
It's doing the flickering on the left 2/3rds of the screen at low brightness levels, not just zero. It's a shame, as this monitor is pixel perfect and is absolutely gorgeous to view. I can confidently say this is the best looking computer display I've ever seen. Look's like there is some troubles with the back-light circuit. I will try the normal sizes DP port instead of the mini-DP input, but I doubt that will change anything.
