- Aug 31, 2009
I don't know who this processor is for.
Someone who likes.building water cooling setupsI don't know who this processor is for.
It's for people like me. Which is why I have two 10900k's.
Nice. Any luck with overclocking?
Yes, the ES chip can do 5.3 ghz all cores at around 1.310v-1.320v load or something. But I'm having some weird issue where it seems (at least from a few quick tests) that using a cache ratio of x50 makes the system MORE stable than a cache ratio of x49! I was getting CPU Cache L0 errors in Cinebench R20 at x53/x49 at 1.305v load. ES CPU bug? Or am I just cursed? idk...Maybe everything's going to hell because the load temps are above 90C...and we don't talk about fight club when your load temps are above 90C! But when I set cache to x50...it was stable? What...
My retail chip seems to need absurd volts for 5.3 all cores (like 1.4v at full load), but the 4.7, 4.8, 4.9 and 5 ghz voltages seem to be exactly the same load voltage requirement as my ES.
basically, the retail chip falls off at 5.2 ghz, and falls off HARD at 5.3 ghz.
Interesting. Perhaps your retail chip was a 'C' batch.
https://www.techpowerup.com/266741/msi-shares-fascinating-insights-into-comet-lake-binning
Where do you get the tuner software?
ok
- 7nm is not as mature a process as 14+nm
- 7nm means that the size of the transistors is smaller, therefore they produce less heat but are more densely packed thus more heat is produced in a smaller area which means higher temperatures under load
- It also means that it is harder to get heat away from the source.
- Higher temperatures are inversely proportionate to speed, the faster you go, the hotter you get, you can’t go as fast if you are hot.
- 12-16 cores are not necessary for the majority of use cases at this time
- 12-16 threads is optimal for gaming at the high end of the scale, 8 is sufficient, 12 is very good, 16 is .. probably overkill in general.
- 8-10 threads is adequate for the majority of games these days (Starcraft 2 uses up to 4 reasonably well, AC:Origins/odyssey use 10-12, Doom eternal uses 14-15 albeit not putting all under load most of the time)
- More cores is better for: Video rendering/compression, 3d rendering, compiling software, running benchmarks, deep learning/ai, Microsoft excel
- For the vast majority of users these days 6 cores is enough, heck most can get by happily on 4.
- Idling on the desktop and web browsing can be done happily on 2 cores or one core with 2 threads
- Streaming and gaming can be done with QSV or Nvenc
No, the key reason that intel is “still in the game” is because most software is compiled with their chips in mind first.
Thank you.
I guess another plus is AMD is affordable to people with a lot less money which would mean ... a lot of people. So I am glad kids with a lot less money can at least have AMD in their corner. Also, after doing some research, it turns out that one of the major reasons Intel can out perform AMD at a hight NM process is their CPU tech. Apperently, Intel has 1000's and 1000's of patents pertaining to inside their CPU's, tech that AMD simply does not have. I've been reading that Intel at 10nm will still out perform AMD at 5nm, let alone their 7nm. Brand prediction, data gates, a lot of way over my head crazy stuff that Intel has. This is what give them the ability to overclock, etc. Very interesting stuff if you start digging in and reading.
I am so happy that AMD woke Intel up. This is going to be amazing ride in the coming years for all of us.
I picked up an Intel 10900K today at Microcenter and an Asus z490 ROG Maximus Hero Wifi along with Samsung B-Die 4400Mhz DDR4 memory. Second place has never ever really been something I've ever wanted to settle for. I anticipate having one of the worlds fastest gaming PC's once I am done.
Come to think of it, I think I understand who the 10900K is for, it's for people who are serious about gaming and won't accept anything but the fastest gaming experience you can buy.
You must be trolling as their is way to much arrogance in that post.
It's like you are bitter that 'kids with less money' can get within 10% gaming of those with unlimited resources ... using a 2080ti at 1080p.
Then the node stuff. First off, nobody except you was surprised that AMD did not shoot up to 5 ghz with a node shrink. Smaller node does NOT isually mean higher clocks.
Glad you have been doing a lot of reading, but nobody believes that nonsense about 10nm Intel.
Your entire post does not seem genuine. "serious about gaming and will not accept second best":
Bro, tone it down a bit. Even the biggest nerds on here had to cringe some when they read that.
No real person talks like this.
Not sure why you thought the 3950x was for you if your primary goal is gaming. That said, if you found 80* hot and you bought a 10900k.and plan to overclock.... You either have some substantial cooling (which should have had no problems with a 3950x) or you are likely going to see as high or higher temps. The 3950x is for someone like me who plays games once i a while on a very GPU limited machine. I mostly do development work (compiling, databases), some transcoding and just screwing with machine learning and misc other stuff. It can be used for those that do other things besides just game... Some people leave their encodes running while gaming.. with 4/8 its really noticeable, with 16/32 you won't even notice. It's for sure not for everyone and I don't pretend like it is. 3600x and 10600k(f) are the chips to look at for most use cases. 10900k and 3950x are for different niches.Thank you.
He, but if your buying a 10900 for other work loads it's even worse. My point was the use case for 3950x and 10900k are different, but do have some overlap (aka, 3950x can game just a little slower, 10900k can do threaded workloads well, just a little slower in general). I also said the 3600x/10600k fits the bill for a more broad base than 10900k/3950x. If you need or have the $, you're not missing anything by going bigger. It's just; know what you're getting and why.If you're buying a 10900k for gaming, you're missing the boat and wasting a lot of money. For the vast majority of all-arounders out there, the 3900x/10700k is plenty with the 10700k for the gaming first, productivity second crowd and the 3900x for the productivity first, gaming second crowd.
I don’t know if that’s a bragging point.It's for people like me. Which is why I have two 10900k's.
I’d like to agree with you, but with the 10x series that isn’t the case
https://www.anandtech.com/show/15785/the-intel-comet-lake-review-skylake-we-go-again/4
I was in the EXACT same boat... I fell into all the "hype" created around that cpu upon launch and thought it would make a great gaming cpu along with a "do anything" pc, and it was great at multi tasking, not knocking that at all, but gaming...... Ill take a hard pass. I OC'd my 3950 to 4.6 on ccd0 and 4.4ccd1 and this 10900k at complete stock (for games) blows it away. Glad i went back to intel since for me, games are my priority, not having 67 chome tabs openYeah I returned my Ryzen 3950x ..... I mean, the productivity benches were kinda cool I guess, at the end of the day I'm a gamer so I'm not sure who that CPU is really for. I guess kids that stream and like to run render benchmarks over and over again. I also had a shit ton of issues with memory. I had to return 2 sets of 16gb because they just refused to work. Then, I found out you had to by "Ryzen Approved" DDR4 ... I mean, what the hell is up with that. Also, why couldn't I overclock the CPU to 5ghz like Intel? AMD is 7nm, Intel is 14nm? That makes NO SENSE to me. And under load, the heat was insane, Was hitting the high 80's. So returned it. Like I said, not sure who the Ryzen 3950x is for. Lots and lots of cons vs the ONE pro I could find and that was you get a few more cores. But, aren't most of us gamers?
Has anyone run the 10900k with HT disabled on the two or four best cores and they're at a higher frequency? Then a game has the screaming fast cores (Far Cry 5?) simultaneous with so many threads but maybe with less heat.
Thank you.
I'm not going to get "old techology" 14 nm components ...
Buying based on process technology is among the most irrelevant of reasons there is.
If AMD was selling 7nm Dozer derived parts, how much would 7nm vs 14nm matter to you?
I guess I'm not loaded enough to buy much of anything to full one purpose and one purpose only.Gamers. Intel is marketing the CPU directly to gamers as the fastest gaming processor in the world. Which it is.
But how much do you really do with your computer that's demanding enough to need more than 10c/20t, or 8c/16t for that matter? Unless your doing a lot of video editing, computer animation / rendering, or VM work, gaming is probably the most demanding thing you do. In which case, Intel has the stronger option for that purpose. It still does other things just fine. AMD does beat it at multi-threaded workloads, sure. But, the amount of cores and threads simply go unused much of the time.
It was a bit different earlier this year or late last year when Intel only had the 9900K and AMD had both the 3900X and 3950X. The aggregate difference in gaming performance was virtually meaningless. Now, Intel's increased it's lead enough to where some people with enough of a budget can build a machine with an emphasis on gaming as there is a larger gap between Intel and AMD on that front now. Although, there are a lot of variables there as some of the games I tested showed no difference at 4K, and other games showed much higher increases than just 5-6%.
You're probably right for those that really want the edge.
But even for me, that all my desktop does it game now; even if I thought about Intel I'd probably buy the 10700k which is 409 at microcenter. But then I look at the 3800x next to it for 309, and for me, for the extra $100, I'm not worried about 20 extra FPS. But that's just me at nearly 40. Maybe at 28 I would have thought differently.
And why would ANYONE mind if a CPU is made with caveman tech or today's tech if the "ancient one" is still outperforming the newer one? So when your game, photoshop, etc...are delivering less performance on the fancy 7nm(ish) AMD CPU, does it make you feel better that you can say, "but at least is not ancient tech".??? I don't care if AMD goes to 1nm to 100nm...if their performance is not able to match/beat Intel for what I NEED, then it has zero importance which tech is newer. Considering even at 7nm they still cannot beat Intel with their 14nm "ancient" tech at all they should be able to, when intel hits 10nm or 7nm, it will be a scary day for AMDThat's not correct. There are users like me who try to go for "best in class" components. Price is still important, but secondary. That meant that since the AMD Athlon I've been Intel since Intel technology was clearly superior. And yes, during that time AMD was for people looking to save a buck.
But it's now 2020 and that's no longer the case. I'm not going to get "old technology" 14 nm components cause Intel messed up their manufacturing and is stuck on 14nm. That means the 10900k is out of the question. I'm going with a modern 7nm CPU from the guys with the better technology. And I don't care about the price. Sadly, that means no Intel this time.
I suppose the 10900k is for two groups: "pure gamers" looking for the highest clock speed who don't mind CPU's built on older technology and are slightly less capable (as an overall CPU) and have plenty of money. And people who like Intel because they like the brand.
