I'ma be a nice person before anyone else comes and tell you not to quote *all* the screenshots when you only have a question about one.
And Main Menu > Achievements > there should be "Show progress in HUD"-marker or something.
looks good.what mods are you using?
this is back from when the medic update was first released
I'm using ultra mode with a few distance and .ini tweaks. The main visual difference is with the View distance mod v.2, and the Clear Skies mod combination, with HDR on. I'm also using some high resolution texture packs, but I don't like the modified 'landscape' files, so those are just standard.
This is on a GTX285, but it did run on a 8800GTS before I updated. Of course not on the highest settings.
No wonder that hotel closed....
It's not that bad, actually. I hardly notice the divisions anymore.Dude, those DMC4 pics are CRAZY. Too bad with 3 monitors you'd still have panels blocking it from being one actually view.
There are two ways to set it up. The first solution is the Matrox TripleHead2Go, which splits up a single DVI output into three. Problem is, the box costs about $250 and it's limited to a maximum resolution of 1680x1050 @ 57Hz per-monitor.Three monitors is the way to go though. No division in the middle. Only on the periphery. Is there a guide around for setting up 3 monitors on a nvidia card? I imagine you need two graphics cards (non-sli) to do this, no?
This is the only shot I felt worth posting. It's from years ago when Oblivion first came out.
