i5 8400 with 1070 or i5 8600k with 580 ?
Discussion in 'Video Cards' started by Swagata, Nov 19, 2017.
  1. Swagata
    Swagata n00b
    54
    Jan 9, 2013
    isnt nvidia gonna launch new product on ces 2018 in january ?
  2. Communism
    Communism Limp Gawd
    165
    Feb 24, 2013
    I highly recommend against getting any 1440p monitor that is smaller than 27 inches.
    It's the same problem with people using 4k monitors smaller than 40 inches.
    Having super high PPI for PC simply wastes compute power to render what you cannot fully see.
    A 23.8 inch 1440p monitor has the same PPI as a 17.85 inch 1080p monitor.
  3. geok1ng
    geok1ng 2[H]4U
    2,132
    Oct 28, 2007
    for 1080p 60Hz i believe your i5 4570 does not need an upgrade, unless you plan live stream your gaming sessions.
    You will not be CPU limited at 1080p 60hz in most games.
    So your entire budget can be diverted toward GPU and storage. RAID 0 SSDs still pack quite a punch, M2 is great, but not as good for gaming as a brand new GPU.
    Now if you start talking about going 2560x1440/3440x1440 ULMB monitors, future proof options are outside your budget.
    I would consider keeping your build and looking toward a 34x14 100Hz freesync monitor + vega 64 upgrade. maybe squeeze a raid 0 SSD as well. 34x14 freesyncs offer great value right now.
  4. DF-1
    DF-1 2[H]4U
    2,585
    Jun 17, 2011
    it sounds like you REALLY don't want to buy anything.
  5. Simmonz
    Simmonz 2[H]4U
    2,506
    May 14, 2008
    I'll take a more powerful GPU and less powerful CPU 100% of the time. Every game will run better with a better GPU but not every game will give a good boost to having a better CPU. If it was between an I5 and an I3 or I5 and an I7 then maybe but two different I5's won't be a big enough difference, not like going from an RX 580 to a 1070.
    DF-1 likes this.
  6. Swagata
    Swagata n00b
    54
    Jan 9, 2013
    vega 64 is pricy here; out of my budget. i am thinking of getting a 144hz 1080p model with 1070ti and hope my old cpu does good. not really interested in ssds now.
  7. Swagata
    Swagata n00b
    54
    Jan 9, 2013
    money doesnt come cheap or frequently. certainly i dont want to buy a 1070ti while nvidia releases 1170/2070 in one month.
  8. Swagata
    Swagata n00b
    54
    Jan 9, 2013
    i see ur point.
    Simmonz likes this.
  9. Stoly
    Stoly [H]ardness Supreme
    6,442
    Jul 26, 2005
    And you know this how?
  10. kirbyrj
    kirbyrj [H]ard as it Gets
    25,176
    Feb 1, 2005
    10XX cards are deep into their lifecycle, but you're not going to see a new card in a month.
  11. primetime
    primetime [H]ardness Supreme
    6,134
    Aug 17, 2005
    Been very pleased with my rx580....and YeA the extra vram is nice!
    Simmonz likes this.
  12. Simmonz
    Simmonz 2[H]4U
    2,506
    May 14, 2008
    I'm happy with my RX 580 as well but I won't pretend it's superior to a GTX 1070. The 1070 has 8GB of VRAM anyway so there is no VRAM difference between the two. I'm thinking you may have thought the OP said 1060.
  13. Swagata
    Swagata n00b
    54
    Jan 9, 2013
    i dont know; thats why i am asking. it will be too painful if i spend a fortune on 1070 now and they announce 1160/2060 to make it obsolete in a month... perhaps that wont happen. they just launched 1070ti; they have everything to counter amd at every resolution or price point.
  14. Stoly
    6,442
    Jul 26, 2005
    By now its very likely that nvidia will skip volta for gaming and go straight to Watt (as it seems volta was basically refined pascal + AI + half precision/double precision stuff). So unless AMD stikes back with NAVI, we may not see a next generation nvidia gaming card until late 2018.
  15. Sodapopjones
    Sodapopjones [H]ard|Gawd
    1,862
    Aug 22, 2012
    If you're that worried, seriously just buy a 1060 already for the 2nd time..
    kalston likes this.
  16. crazycrave
    crazycrave Gawd
    628
    Mar 31, 2016
  17. Swagata
    Swagata n00b
    54
    Jan 9, 2013
    i thought it was Ampere...
  18. TaintedSquirrel
    TaintedSquirrel [H]ardForum Junkie
    9,613
    Aug 5, 2013
  19. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,879
    Dec 23, 2001
    Listen to all the voices of reason. Get the 1070 and be done with it. I just went from a 290 to 1070ti with 2500k @ 4.2ghz and I am blown away. I game at 1440p and it runs everything I throw at. I would even say don't waste money on more ram. With ram prices they way they are it be silly on an aging platform. Wait till you can Do a full refresh and carry over the 1070
