i5 8400 with 1070 or i5 8600k with 580 ?
Swagata
I want to upgrade my pc, My current spec is
i5 4570
Asrock B85 Fatility
G Skill Ripjaw 1600 MHZ DDR3 4GB x2
Cooler Master Hyper 212x with an Corsair fan attached to it
Cooler Master 700W Bronze
Corsair Neutron GTX 120 GB
Cooler Master Centurian 6 Case
Now I want to upgrade and I am thinking of 2 build. Please note that Im gonna be gaming on 1080p 60 hz.
Spec 1 :
i5 8400
Gigabyte Aorus Z370 Gaming 3
G Skill Trident Z 3200 MHZ DDR4 4GB x2
Gigabyte Aorus 1070
Keeping My Previous SSD and Cooler
Spec 2 :
i5 8600K
I am gonna keep my previous CPU cooler
HIS ICE COOL X2 580 8 GB OC
Samsung EVO 960 M2 256 GB
Which will be good ? If I take the second build, I may sell the card after 1 year and buy new GPU and have that very fast PCIe SSD. But Spec 1 will have me max out every game out there right now. But will the 8400 live for 3 years ? 8600k Can be overclocked in late future..... Also at 1080p CPU means more than GPU, right ? So a better CPU is good for the long run ? Thanks.
I would replace the 8400+1070 with R5 1600 + GTX 1080. Should be about the same cost.
The difference in CPUs is negligible.
However, if I had a 4570 right now the lowest CPU upgrade I would take is the 8600K.
Ryzen and 1080 is way overpriced here. 1080 is out of the question. R5 1600 cost slight more than the 8400 although ryzen mobo are cheaper. But again not so that I can stretch my budget for a 1080. And isnt 1080 more overkill for a 1080p set up ?
I'd go with the Radeon and the faster CPU, since you're at 1080; got more legs, and I don't know how much higher than 4.0GHz you'd be able to coax that 8400, but the 8600k should punch far higher, and you just keep CPUs longer.
Besides, if you're budget limited, you'll have a better chance of upgrading to a VRR monitor at a good price.
What is your current computer not doing now that you want it to do? I'd get a 1070 and put it in your current build and maybe get another 2x4GB of DDR3 RAM. Even grab a 4790k if you can find a deal. At least wait for DDR4 prices to come down. $100 for 8GB of DDR4 is silly. Heck, I have 2x4GB of DDR3 1600 I'll sell you for $35 shipped :D.
Not only that, 8 gB of main memory is already a bottleneck for some games, and it will only get worse later (and even worse if you are running anything at all other than the game in the background.)
Until you can save up for at minimum 16 gB of DDR4 + 8600k, it's an absolute waste of money to upgrade your current rig to a DDR4 platform.
Going with an AMD gpu will make you more CPU limited as well (compared to an Nvidia GPU), so you need to factor that in as well into any decision you make.
(To be clear, i am not disagreeing with kirbyrj)
the 1070 will be bottlenecked by 4570. cant find 4790k with warranty beside i use b85 board. my current setup has no warranty. if they die i get zero values. just like my r9 290 that died a few months ago. 8gb ram should be enough if i dont have anything in the background, right ?
really ? bottleneck by ram ? im not gonna run application in background though. anyway, i want ur opinion on spec 1 and 2; what do u think i should choose ? i already choose a faster cpu for the amd gpu; and 8400 with 1070. thing is that with 8400, i cant afford a ssd while with 8600k and amd gpu; i can. my current ssd is dying; has 145 bad sector for a year, i dont think it will survive much.
Depends on the game, check this site for full info about main memory usage:
http://gamegpu.com/
That's absolutely true, however, 4790k should be about equal to 8400.
CPUs that you don't overclock basically cannot die anyways.
Here is a nice video detailing the difference between i5 8400 and i7 4790k
http://hwbench.com/cpus/intel-core-i5-8400-vs-intel-core-i7-4790k
http://cpu.userbenchmark.com/Compare/Intel-Core-i7-4790K-vs-Intel-Core-i5-8400/2384vs3939
The i7 4790k is a bit too old to show up on the main charts for most of the review sites, but it does compare relatively equally to i5 8400
Instead of the 580 you can consider a 6GB 1060 and save 100W with it.
Well, if you budgeted on keeping the SSD in the one build it makes sense that you'd have to go with the other build then.
Well to give you an idea of Ryzen performance ,, the 1400 overclocked to 4.0Ghz is = to the 2500K at 4.4Ghz .. The whole R5 line up can drive that 1070GTX if you need to save on the cpu to get the 1070GTX into your budget and drop a zen 2 later on.
Ryzen 1400 isn't an upgrade from i5 4570.
The OP doesn't seem interested in upgrading CPU's later or else he would just buy the 4790k ;).
I went 4670K - R5 1600.. I don't think I would go the route of 6 cores without hyperthreading... Short term build the 8600K would be the better way to go, but also wouldn't run any less than 16GB of ram, 8GB is definitely not going to cut it.
then i can go for spec 2; ditch the ssd and buy 16 gb or ram ?
I think a haswell i5 is enough, your friend is right.
Buy a 1070, see how much of an upgrade it is, see if you like it. You can do the others later if you want, but I think you'll see good results.
(i dont see current GPU listed anywhere)
4570 is okay for most games to keep 60 fps but you will have the cpu pegged in many if not most newer games and expect some stuttering in a few games. And I certainly would not want to play the latest games with only 8 gb of system ram.
If you are bent on getting a new setup, I think I would go with an 8600K, 16GB G.Skill or Corsair ram, and a 1060... I wouldn't touch another AMD GPU if it was given to me.
Watchdogs 2, was the moment I realized I needed more than 4 cores, kind of like when Bad Company 2 came out and it made me realize I needed more than 2 cores. ALT Tab into a slide show is fucking retarded.
take a look at here,
Bottleneck is real. And dont u think, choosing a 1080p resolution will strain the cpu even more ?
My rig is 3.5 years old. If they die; I get zero valeu. So, I am in a panic. I cant buy spec one or two without the money I am hoping to get from selling my current rig. my gpu is a dead r9 290.
the 580 is kinda cheaper than 1060 here. also 1060 has 6gb of vram; i think in future im gonna need that 2 extra gb, right ?
6 core 6 thread should be enough for upcoming games. if i stick to my current 4 core, ill definitely see low performance......even with a 1070. why not make the pc good like 8600k, 16 gb ram and a cheap 580 and later when 1170/2070 comes out; i sell the 580 and buy that. after alll 580 is very decent for 1080p 60hz; right ?
Yes for 1080p go ahead and get an 8600k, 16gb of fast ram, and a 580 or 1060 then upgrade the gpu next year if need be.
Probably not, especially not at 1080p; the fairly equivalent GTX970 with 3.5GB is still very good at 1080p 60Hz, though starting to get to the point where you must watch RAM-hogging settings. At my 1440p, basically twice the pixels, it was worse...
However, the challenge is that by the time you'll actually need >6GB, your GPU simply won't be powerful enough to turn settings up.
Save the cash, put it into CPU + RAM.
I have recently found that 8GB is not enough for anything anymore and dont regret upgrading to 16GB 2133mhz DDR3. To OP, your CPU is probably fine, just upgrade the GPU unless you are doing some very CPU intensive non gaming.
I've had the opposite experience. 16GB in my rig but nearly every game keeps me around 6-7 GB total system usage. Sometimes it will eek past 8GB, I imagine over-allocation has some effect too.
I'd still aim for 16GB in any new builds, obviously.
Add me to the list suggesting just GPU + Ram upgrades for now. A CPU+mobo should be good for at least a half dozen or so years. Unless you're also able to upgrade to a significantly faster tier within a new generation upgrading the CPU more often than that's just not a good use of funds anymore.
Reactions: yowen
How you use the rest of your system makes a big difference too. Obsessively closing browser tabs so you never have more than a half dozen vs having hundreds of tabs open at once is easily several GB of ram these days; and only getting worse as web pages pile more and more stuff into themselves. On the gaming side screen resolution might matter too; never looked into it but I know higher resolutions eat VRAM like no tomorrow; if the engine is caching assets it thinks will be needed soonish in system ram that could burn more at 1440p/4k.
Start with a 1070, you can only go up from there! But the 1070 alone might just be enough. If you aren't happy, your next move would be cpu/mobo/ram. Or alternatively keeping an eye out for a -K chip that goes with your mobo, so you can overclock.
That PCIE ssd isn't worth upgrading for either. You mentioned your SSD is dying. The real world performance of a sata vs a pcie isn't that huge, if I were you I'd be fine just getting another sata ssd.
With every background task closed, I'm still in the 8-9gb range. Admittedly that's with PUBG and it's known to be unoptimized and early access. But still, I think 16gb has become the new 8. If you can get by with 8, that's fine, but if you start running into trouble, you know it's time to upgrade.
guys, i am thinking of gettting zotac 1070ti mini with asus vx24ah wqhd monitor with my existing setup; what do you think ?
A 24 inch 1440p monitor is completely pointless unless you have 20/20 vision or better and can see pixels on a 27 inch 1440p monitor at normal viewing distance (Not aliasing, i'm talking about actual pixels).
27 inch 1440p monitors already have the same PPI of a 20.25 inch 1080p monitor.
108.79 PPI is already pretty high at normal viewing distances for a monitor.
I don't think the core i5 4570 will bottleneck a GTX1070.
I'm running a GTX1070 with a Core i5 3330 and it runs great even at 4K in older games.
If I were you, I'd get the GTX 1070 first. Then if you feel the CPU is a bottleneck then you can upgrade it.
Reactions: DF-1
thing is that; the 1070 available here like gigabyte aorus or zotac amp; their price is so close to the zotac 1070ti mini; its like 15 dollar difference. so with either pricy 1070/1070ti i cant afford a 144hz monitor but that 24 inch 1440p monitor. if i get a less pricy 1070; i may get the 144hz 1080p panel but local shops are bad and i am worried i may not find a cheap 1070 like gigabyte g1 or asus dual x.....
