w1retap
- Jul 17, 2006
Put some 5 cent molding around that.. the rough cut looks terrible on such a nice case.
That's some sick work... I hope he does a work log! I would love to see how he pulled it off!This might be of interest to some since it is often talked about if Lian li would combine the best of the PC-V600 and PC-A05B this is my attempt.
http://www.hardforum.com/showthread.php?t=1324926
This is my extremely quiet storage/browsing rig. 400 RPM fans, sound damping material, passive video card, and suspended Green Power and laptop hard drives make it completely silent 99% of the time, even to my sensitive ears. The switch on the front is a DPDT switch. It changes power between the two drives, effectively giving me two completely separate systems in one.
Nice and clean...AND quiet!
What foam did you use and did you notice any difference in noise or vibrations after applying the foam?
Thanks!
Well, I originally didn't intend to use any sound damping foam, but when I got everything set up, there was an intermittent high-pitched ringing sound coming from my computer, only audible because everything else was so quiet. I set up everything outside the case, and after lots of careful listening, found that there were a few places on the motherboard making buzzing noises whenever there was any sort of load on the rig, especially websites with flash animations. At a longer distance, like outside of the case, the buzzing became a very high-pitched ring. I couldn't be positive if it was the motherboard making the noise, or the video card or ram. It was driving me so insane, I thought I was getting tinnitus.
The foam helped a little, but I can still hear the noise when its quiet out. Now that its summer though, its never quiet. Its part 8614K82 and 8614K811 at Mcmaster.
I'm currently using some old UV lights...thinking about replacing them some other color. I really don't want to get blue just because they're overdone but they'd match so perfectly with the blue power LED and the Lian Li temperature sensor. What do you guys think?
EDIT: Sorry for the crappy lighting...I didn't notice how grainy the images came out.
Finally got mine up!
I'm very pleased with the S-Flex SFF21E's yet again. (The 4 120mm fans in my V1000 are all SFF21E's.) My old A05B had Yate Loon D12SL-12's, which compared to the S-Flex are more noisy and weaker on airflow. I am an S-Flex fan for life.![]()
snip
upgrade time![]()
One of the few Fatality boards still running.
i have a fatality an8 sli board in my gaming pc.. works great.
was there an issue with em or something?
Hey guys, amazing thread here! Inspired me to get a PC-A05B too! Anyway I just want to know if its worth spending $20 on those rad grillz to have 2 120mm exhaust fans or should I just stick with a single 120mm blowhole on the top? Would it make much of a difference cooling my 8800GTS G80?
Bsport said:Hi was reading the PC-A05B thread, and see you removed the top did you just drill out the rivet, cut the blowhole and re-rivet it?.
regards
Bsport
so i got my case yesterday and just finished the first blowhole. now I want to make another one but I want it to line up with a 240mm swiftech rad. anyone got measurements for that? heres a pic:
snip..
i posted pics few pages back here. Yes you have to take the fan out and you need 90° sata/power plugs too. i modded my fan so its mounted on the inside of the case but sticks outide the case (just cut part the the fan shroud). if you go that route its best to drill a hole in the front for optimal airflow. most people like the clean front of the a05 but if you want the best cooling its the way to go. i tested alot with cardboard panels with fans and found this to be the best. i also drilled 2 holes in the side.Quick question for those of you who reversed your hard drives (I posted this on the v600/a05b hybrid thread too):
Did you have to take your front exhaust fan out in order to fit the reversed hard drives? My hard drives won't fit in reverse--they just run into the front fan.
