whats the contraption over the cards? i have the case but i dont have that thing.
Viperlover
Quote:
Originally Posted by toxygen View Post
http://i221.photobucket.com/albums/dd211/t0xygen/DSC02604.jpg
What is the thing holding up your 2 HDD's?
Thanks for the kind words.. Speaking about clean wires, i decided to cut out a window.
Here are some pics. Haven't finished yet. I had to order some black rivets online. So far I cut out the hole. Sorry bout the quality. Ghey cell phone.
Specs:
C2D e6600
Corsair pc8500
Abit IP35 Pro
Evga 8800 GTX
SilenX fans throughout - no side window yet
Swiftech H20-Compact [perfect for this case - 31 Idle / 40 Load]
Corsair 620W
Seagate 250 (OS)
Seagate 320 (Data/Apps)
Seagate 750 (Media)
Anyone get the Drill Top Blowholes option from performance-pcs with their window modded case? How does it look? I wish the window had an intake fan, but i think adding that one top blowhole is good enough too. Then maybe add GS-01 or GS-03 blower too.
Dannyd, what are the dimensions on your window? I just ordered a window from performance pcs that's a little smaller than 12x12 and your window looks to be close to that dimension.
Hey, I just got my performance-pcs pc-a05b in last week and parts come to go inside it tomorrow. I'll post pics of how the blowhole worked out once i get all my parts, but its basically just a circular cut hole with no grill. I just took the grill from the back of the case and moved it up to the top so theres not a gaping hole on the top of my case. Also, the window isn't quite as boxy as it looks, the edge is beveled so it isnt just a piece of plastic slapped on top of the panel.
Cool thanks iceroid, would really help in my decision, I just don't have the tools to make my own blowhole.
So it has a fan and round hole there attached, just no grill? or was it just a empty round hole and you had to drill screws for the fan and attach one?
If anyone is interested, I have a few items for sale on ebay that would go well with this case.
1. AC Ryan 1x120 radgrillz - New
2. Scythe SFF21E Fan - New
3. 10"x10" Clear window kit - New
http://search.ebay.com/_W0QQsassZddavila1986
Wow, that guy installing the harddrives is an idiot
The A05 is the same design, you install 4 screws with 4 grommets, and slide it in... I figured it out just by looking at the bags of parts and inside the case, I had no idea they had this style of installation. It was quick painless and very easy... user stupidity should not be a factor in reviewing a case...
Whatever haha... I need a bigger tower... or bigger harddrives![]()
The B25 is almost perfect. What's up with 80mm intake fans?? Higher cfm with lower dba on 120mm's..... blows my mind!
I am interested aswell.Has anyone removed the top panel by popping the rivets? I plan on making a 2x120 fan blowhole, which will one day serve for a 2x120 radiator and was wondering if I can remove the top panel to do the job.
Yep, I just drilled them out and replaced them with screws and nuts, no problem, it just slid right off.
Uh the link is for the B25, not the A05.
I realize that, same installation style as the A05 though. It looks even easier on the B25 because with the left panel off you have the whole HDD bracket to stick the drives in... all the cables are hiding behind their too...
Well you all made me do it and here it is. I havent posted much but thatks to everyone here for getting me interested in this case. Just waiting on Q6600 tomorrow and 120 extrere (backorder from tank guys), EVGA 7950GTKO will go in when the quad arrives.
Already modded with 2 Yate Loon top side and window.
