HTC hinting at Ver 2?
Discussion in 'VR & Head-Mounted Displays' started by Hakaba, Jan 6, 2018.
  1. Hakaba
    Hakaba I Think I am Funny, but I'm Not
    321
    Jul 22, 2013
    https://mobile.twitter.com/htcvive
    If the info has already been posted my apologies, but the whole screen door/off center lense effect from “New Year’s” to a clear and easily readable “Resolution” makes me think something new/upgrades may be heading our way.
  2. Maddness
    Maddness Gawd
    802
    Oct 24, 2014
    I saw that today. I was actually about to by an HTC Vive. If this could be a true 4k VR experience and out between now and the middle of the year, then I will hold off.
  3. bobzdar
    bobzdar [H]ard|Gawd
    1,409
    Jun 6, 2003
    Not exactly a subtle hint...
  4. LurkerLito
    LurkerLito [H]ard|Gawd
    1,956
    Dec 5, 2007
    OK I am ready :). I hope it has the knuckles controller also because I really really want those just about as much as I want better PPI.
  5. Krazy925
    Krazy925 epeen +10
    2,528
    Sep 29, 2012
  6. Maddness
    Maddness Gawd
    802
    Oct 24, 2014
  7. Krazy925
    Krazy925 epeen +10
    2,528
    Sep 29, 2012
    A lot of people thought that. I’ll be surprised if it’s a 4K Vive.
    That doesn’t mean anything though.
  8. Maddness
    Maddness Gawd
    802
    Oct 24, 2014
    At least we will know soon enough one way or the other.
    Krazy925 likes this.
  9. Gorankar
    Gorankar [H]ardForum Junkie
    14,386
    Jul 19, 2000
    4k vive? When is the next gen of vid cards dropping?
    RogueTadhg and Kyle_Bennett like this.
  10. Maddness
    Maddness Gawd
    802
    Oct 24, 2014
    Hopefully, in the next 6 months.
    Gorankar likes this.
  11. dr.stevil
    dr.stevil [H]ardForum Junkie
    12,472
    Sep 26, 2008
    https://web.archive.org/web/2018010...endigt-vive-pro-und-vive-wireless-adapter-an/
    Supposedly the Vive "pro" will have a 2160x1200 "3K" display and integrated audio (like the deluxe audio strap).
    They're also supposed to be announcing an adapter for wireless later in the year using Intel's WiGig technology.
    If the lenses and FOV are improved on as well, I will likely be selling my OG Vive for a Pro. If not, then I'll likely hold off until the next generation.
    {NG}Fidel, Maddness and heatlesssun like this.
  12. heatlesssun
    heatlesssun Pick your own.....you deserve it.
    48,654
    Nov 5, 2005
    Wonder if this headset would be fully compatible with existing lighthouses and controllers. Hopefully that's the case then all that's needed is the headset.
  13. dr.stevil
    12,472
    Sep 26, 2008
    Yeah, I believe that the new hardware (controllers/headsets) is compatible with the original lighthouses, but not vice versa. So 2.0 lighthouses will only with with 2.0 hardware, but 1.0 lighthouses will work with everything.
    heatlesssun likes this.
  14. MavericK
    MavericK Zero Cool
    30,702
    Sep 2, 2004
    We'll see on the price. Kind of sounds like a marginal upgrade, so not something I would be paying a huge amount for.
  15. Maddness
    Maddness Gawd
    802
    Oct 24, 2014
    2880x1600 :)
    dr.stevil likes this.
  16. Creig
    Creig Gawd
    739
    Sep 24, 2004
    From an article posted on a German VR site, VRNerds.de which was apparently posted before the NDA expired and then pulled:
    So it looks like a minor bump in resolution and the Deluxe Headstrap being included as standard.
  17. Creig
    Creig Gawd
    739
    Sep 24, 2004
    heatlesssun and Maddness like this.
  18. odditory
    odditory [H]ardness Supreme
    4,709
    Dec 23, 2007
    In for a Vive Pro + Volta GPU
    Maddness likes this.
  19. bobzdar
    bobzdar [H]ard|Gawd
    1,409
    Jun 6, 2003
    no price...so integrated upgraded audio, wireless adapter coming summertime, smaller and lighter with higher 2880x1600 res. Not bad but nothing revolutionary. Headset only (upgrade) package shipping this quarter, full setup later.
  20. heatlesssun
    48,654
    Nov 5, 2005
    Time to start saving up!
  21. admiralperpetual
    admiralperpetual Limp Gawd
    327
    May 7, 2015
    so will they finally drop the price on the V1 Vive? it's still nearly 2x the price of the Rift here, especially if you include the audio strap
  22. Krazy925
    Krazy925 epeen +10
    2,528
    Sep 29, 2012
    I really wanted this to be a bigger upgrade.
    I guess I’ll wait for v3.
  23. Maddness
    Maddness Gawd
    802
    Oct 24, 2014
    I think the resolution upgrade looks to be more than enough for any current GPU's on the market. Also wireless coming soon is a great feature. By the sounds of it, this will all launch in the first half of this year.
  24. KazeoHin
    KazeoHin [H]ardness Supreme
    7,250
    Sep 7, 2011
    That's nearly double the OG vive resolution, I would imagine the screen door effect will be drastically reduced.
    Even rendering an upsampled image, that alone is a huge benefit.
    dr.stevil and Maddness like this.
  25. misterbobby
    misterbobby 2[H]4U
    3,187
    Mar 18, 2014
    It's 78% better resolution so that will help quite a bit overall but won't even be remotely close to getting rid of the screen door effect.
  26. Rizen
    Rizen [H]ardForum Junkie
    9,041
    Jul 16, 2000
    I feel like that's a frivolous point right now because the GPU hardware to power a resolution high enough to completely eliminate the screen door effect does not exist.
  27. KazeoHin
    7,250
    Sep 7, 2011
    You don't need to render at native resolution to eliminate the SDE, the effect is tied to the screen's pixel pitch. Even if you run a 720p image upsampled to a much higher resolution screen with a small enough pixel pitch, you'll eliminate the screen door entirely.
    That's what the Chinese HMD does. It up scales a 1440p image to a 4k screen, because the pixels pitch is so tight, the image is solid and unbroken.
  28. Rizen
    9,041
    Jul 16, 2000
    Interesting, I didn't know that. Thanks!
  29. sharknice
    sharknice [H]ard|Gawd
    1,262
    Nov 12, 2012
    All I've been waiting for is higher resolution, so I'm pretty excited.
  30. Maddness
    Maddness Gawd
    802
    Oct 24, 2014
    Same here. I was about to pull the trigger on the Vive. But now i will hold off. Hopefully these will retail in the next 6 months.
  31. Hakaba
    321
    Jul 22, 2013
    Happy about the screen upgrade, hope I can remove provided headphones, wireless device looks awfully big but it’s receiving a lot of data.
    Wonder what the price will be, 1K for the headset?
  32. dr.stevil
    12,472
    Sep 26, 2008
    I had REALLY hoped for some better optics and/or a wider FOV, but the resolution bump is pretty nice. Should do quite a bit for texture detail and text legibility.
    God I hope not. For the headset alone, I would hope it wouldn't exceed $3-400 considering the cost of an individual controller and lighthouse. Anymore than that and I'd likely wait for PiMax's offerings (or another competitor that uses the lighthouse tech).
    As for the headphones, IIRC they do detach
  33. swiftwind
    swiftwind Gawd
    949
    Nov 3, 2004
    I'm debating if it's worth upgrading from a first gen HTC Vive.
    Considering I can still make my GTX1080 choke with super sampling turned way up, I'm wondering if I should wait for Volta first so I can actually take advantage of that higher resolution. Thoughts anyone?
  34. RanceJustice
    RanceJustice [H]ardness Supreme
    5,418
    Jun 9, 2003
    Overall I'm glad for the upgrade, but I have to admit I'm comparing this primarily to the Pimax 8K. The Pimax 8K has higher resolution but also higher FOV I think...but it is a "no name" Kickstarter project out of Asia so what's good on paper may not be so much in practice. Their first headset was not acclaimed but who knows perhaps the 8K will truly be worthwhile. I'm glad to see an upgrade to the Vive but I rather wish it was a larger one in terms of resolution/FOV and a few other features - like controllers! Most believe that the Oculus Touch controllers are some of the better ones, so I figured the next gen Vive would enhance and overhaul the controller design, but it seems pretty similar on the Pro? Likewise, other features like eye tracking (and FOV-ated rendering as part of the SDK), a hand-motion module, and other elements would be nice to see.
    Edit: I'm a bit curious why they're still running USB 3.0 and DisplayPort 1.2 on a new device. Come on now, if they're pushing a relatively high priced device like this and want it to hang around a few years like its predecessor (which is not a bad thing) then they should use the latest standards. Full on USB 3.1 at least, plus DP 1.3 or 1.4. This kind of thing would actually allow me to come to the next feature that I really wanted to see - upgrade ability. It would be nice if the Vive was modular so that users could upgrade as many components as possible. Pimax and devices like the OSVR have that kind of thing in mind, so bringing it to the Vive would mean more connectivity, more accessories and upgrades thanks to higher bandwidth.
  35. bobzdar
    bobzdar [H]ard|Gawd
    1,409
    Jun 6, 2003
    Yeah, just turn super sampling down some. You won't need as much super sampling with more pixels, you can render at the exact same effective resolution and get the benefit of reduced SDE while maintaining your current image quality.
    As to whether it's worth it, based on Samsung Odyssey reviews I'd say probably not unless it's cheap (ie under $300).
  36. sharknice
    1,262
    Nov 12, 2012
    Pimax uses LCD instead of OLED. It doesn't matter how high resolution it is when it has vommit inducing motion blur.
  37. swiftwind
    swiftwind Gawd
    949
    Nov 3, 2004
    I usually run it with super sampling turned down but I guess what I'm asking is if I can't Max out the graphics now, what's the point of getting something with higher resolution? Get Volta first? Vive pro later?
  38. pj-
    pj- Limp Gawd
    222
    May 7, 2015
    I don't think it really makes sense to make everyone pay for options that very few will use. Especially if they add weight, cost, or power consumption. Two years into the vive, how many people use the USB jack on the headset? How many of the those are using it for something more than powering little fans to blow cool air on their face? I'd wager basically none. Also I believe the USB jack on the current vive is 2.0, not 3.0, so it is somewhat of an upgrade.
    Wireless VR is going to be a big deal in the future so I think high bandwidth USB based headset accessories will not be a priority since bandwidth will be at a premium. Not that there is any pressing demand for those types of things anyway.
    Lens/screen upgrades, even if available, would be limited to resolution only, not FOV, and would likely involve levels of cost and disassembly that would turn off most users.
    Judging by the (complete lack of) popularity of the OSVR, I think HTC is right to ignore what they are doing.
  39. Stryker7314
    Stryker7314 Limp Gawd
    157
    Apr 22, 2011
  40. ronan_zj
    ronan_zj n00bie
    53
    Feb 27, 2009
    but samsung Odyssey still has SDE.
Tags:
