Scrumtrulescent
- Aug 24, 2007
Running a NH-D15 with the 3900x at 4.0ghz (all core) and 1.16875v. The temps are in mid 60's C full load. Stock clocks would push ~4.05ghz (all cores) at ~1.32v full load with mid 70's C temps so I manually tuned it for lower heat/power draw. I don't care much for single core boost right now.
I also need to play around with a different thermal paste application (currently using noctua paste that came with the cooler applied on the spreader in an X. Will try the 3 dots next time.)
I'd go custom loop if you want to push this cpu because the voltage/heat ramps up quick when you get above 4.1-4.2ghz all core.
fyi, for anyone carrying over a noctua from an older build, it took 2.5 weeks to get the free AM4 mounting hardware kit from Noctua (shipped from Europe to USA).
