How big is your Gaming screen?
Discussion in 'General Gaming' started by Susquehannock, Nov 29, 2017.
  1. Vader1975
    Vader1975 Gawd
    822
    May 11, 2016
    The height of my 34inch is = to my old 27 inch non widescreens. It just has more horizontal realistate so I can see the edges better. It is about as much as I actually used in the past. So for our comment. If you want a specific vertical size then you want to figure out what 21:9 retains that much height. I would usually times whatever you have by 1.26 and you will have the equivocal height in 21:9. For example: Your 30's would need to be 37.8 inch for Ultrawidescreen to have the same vertical footprint on your desk.
  2. Elf_Boy
    Elf_Boy 2[H]4U
    2,337
    Nov 16, 2007
  3. Dan_D
    Dan_D [H]ard as it Gets
    54,452
    Feb 9, 2002
    I had 27" 2560x1440 monitors that replaced my 30" 2560x1600 monitors and I found the lack of vertical real estate unacceptable. That's a relatively minor decrease in vertical pixel height and it was still too much of a change for me. I'm at 3840x2160 now, but I think I can go back to 1600 for a good enough monitor in other respects. I still use my 30's on the test bench so I'm used to it.
  4. Comixbooks
    Comixbooks Ignore Me
    13,453
    Jun 7, 2008
    I'm really interested in those Dell glossy monitors that are geared for gaming. Mentioned on tft central. 24" 1080P and 27" 1440P I figure they will look like your typical glossy laptop screen only better because of the size. Some of those antiglare coating just wreck the screen. I know tv panels are almost all glossy but too big for me to focus on.
  5. Commander Shepard
    Commander Shepard 2[H]4U
    3,752
    Apr 12, 2016
  6. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,346
    Jun 13, 2003
    I got over it; use 32" 1440p (just swapped out 27" 1440p) after coming from 30" 1600p for years myself. I have a 32" 4k next to it on one side, and a pair of stacked 24" 1080p on the other side. Most monitoring tools go to the 4k, web pages go to 1080p, and any current work goes central be that gaming or otherwise, and adjust as needed. Working great so far.
  7. bluesynk
    bluesynk Limp Gawd
    206
    Oct 5, 2014
    Just started using my 55" Q7F as a 4k60 HDR monitor. Had to move my desk a few feet from the wall, but it is very nice.
  8. t1k
    t1k n00b
    41
    Apr 16, 2017
    I'm using an LG 24UD58-B 24" LED 4K monitor. I've considered getting a bigger 4K OLED like the LG C8, but I'm not sure there's any clear adavantage for me sitting further away from a big screen as opposed to closer to a small one since I'm not a gamepad/couch gamer and am glued to mouse/keyboard for the games I play. I also mostly play VR games anyway. The LG has been easy to manage and clean. I've also whacked it quite a number of times with a Vive controller, yet it shows absolutely no sign of scratching/wear so far as I can see, which is remarkable. I'm satisfied with my setup for now. My vive pro with gear vr lens mod and a customized face liner definitely entertains me more than my desktop monitor.
  9. Dan_D
    54,452
    Feb 9, 2002
    I don't know why people always say things like this. It doesn't make any sense. There is nothing that says you have to sit further away from a larger screen. The reason for getting a larger display in a given space is to have a bigger screen that fills more of your peripheral vision. The larger size allows you to see things in greater detail and enjoy a more immersive experience.
  10. t1k
    t1k n00b
    41
    Apr 16, 2017
    You make a good point Dan_D. I guess I was thinking I'd have to swivel my head around more as opposed to just my eyes, but I guess that's kind of the point and would probably add more immersion. But hell, if I'm looking for that kind of immersion I'll probably just turn to vorpx and my vive.
  11. Dan_D
    54,452
    Feb 9, 2002
    There is certainly a sweet spot for these things. For me, a PC gaming display can be upwards of 49-55". This gives good immersion but doesn't require head turning. At least, not for me. Your height, chair height, desk height, monitor mounting options, etc. all factor in here. I'd like to drop my monitor a couple inches to make it a bit better. At normal desk viewing distances this works pretty well. For productivity I think 43" is perfect and 48"-49" is pushing it. People with better eyes sometimes go upwards of 55", but I find the pixel pitch is too shitty at that point.
  12. jbean7457
    jbean7457 Gawd
    601
    Mar 6, 2005
  13. Boulder
    Boulder n00b
    36
    Aug 21, 2018
    27" 1440p for my PC and a 65" 4k for my Xbox
  14. renswic
    renswic [H]ardness Supreme
    4,468
    Nov 28, 2004
    17in screen on my ROG laptop, 55" Samsung TV for the PS4
  15. wizzi01
    wizzi01 2[H]4U
    2,143
    Apr 25, 2008
  16. MrMitch
    MrMitch Spinning Drives Rule!
    2,581
    Dec 13, 2004
    49" Samsung Ultra wide. While not a great general purpose gaming monitor, it is amazing in the right applications
    Porter_, revenant and Denpepe like this.
  17. Mojo3k70
    Mojo3k70 [H]ard|Gawd
    1,194
    May 24, 2002
    27" @ 1080p 1ms BenQ for PC
    50" @1080p Toshiba LED TV for consoles
    My vision is not what it used to be so 1080p still suits me well. A little extra AA when sitting close to monitor and i'm set.
    I also enjoy the fact my overclocked 980ti will carry me until Ray Tracing matures.
  18. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,821
    Jan 1, 2008
    40 inch 4K for the PC
    100 inch 1080P front projection for the consoles
  19. Bigbacon
    Bigbacon [H]ardForum Junkie
    15,771
    Jul 12, 2007
    21.5
    Anyrhing bigger is just too big for pc
    Tv consoles are either 50 in plasma for 32in lcd.
  20. 4saken
    4saken [H]ardForum Junkie
    10,836
    Sep 14, 2004
    55" 4k TV here for main screen. I sit 3 ft away, its amazing.
    Ocellaris likes this.
  21. Bigbacon
    15,771
    Jul 12, 2007
    Even 21.5 is pushing it fir me. Feel like i need to look around the screen to see everything.
  22. Ocellaris
    18,821
    Jan 1, 2008
    I thought this too. Then I tried a 40 inch display and ooommmggg it’s so nice.
  23. 4saken
    10,836
    Sep 14, 2004
    I don't even think i could live with a 21.5 for a work screen at this point.
    John721 likes this.
  24. Bigbacon
    15,771
    Jul 12, 2007
    For work i have 3 monitors.
  25. nEo717
    nEo717 Limp Gawd
    317
    Jun 2, 2017
    34" Curved LG gSync 166Hz 2560x1080
  26. sleepybp
    sleepybp Limp Gawd
    389
    Feb 5, 2014
    32" HP Omen 1440P with 1070ti. Great display for the price, especially when on sale ($250 Black Friday)
  27. NamelessPFG
    NamelessPFG Gawd
    515
    Oct 16, 2016
    My Eizo FG2421 is a bit over that at 23.5", and even that seems rather small for my usual viewing distance a few feet away.
    I'm wishing for a 27" or 32" on this desk already, but the budget for such a monitor with 144 Hz G-SYNC and a non-TN panel is just way out of my reach at the moment.
  28. John721
    John721 [H]ard|Gawd
    1,623
    Mar 8, 2006
    Currently using a 34" monitor, and it's quite enjoyable, but, I might just go back to a more typical aspect ratio 32" for my next display.
  29. jegbus
    jegbus n00b
    53
    Nov 23, 2016
    Currently 27" 2560x1440 (Asus PB277Q LCD). Before that I used a 32 inch 720p Samsung TV which I downgraded to when I moved everything to a desk environment from a living room environment where I had used a 42" 1080p Samsung TV for years. (42" is still in use for media on a stand above my monitor. Sits pretty high but nice view from bed.)
    I guess I'm not overly picky because I've found them all to be acceptable, even surprisingly the 32" with all those pixels up in my face! Have to say I love this Asus monitor though.
  30. Staples
    Staples [H]ardness Supreme
    7,825
    Jul 18, 2001
    24" at 1080p and 55" 4k for consoles.
  31. Niner21
    Niner21 Limp Gawd
    147
    Aug 26, 2018
    27" Samsung CF591 curved at 1080P. 55" 4k for consoles
  32. Rvenger
    Rvenger [H]ard|Gawd
    1,741
    Sep 12, 2012
    32 inch Philips 326M freesync, Sceptre 32" 1080p for movie watching, 32inch Dell 1080p for work. will not go smaller now that I went to 32"
  33. g00z13
    g00z13 [H]Lite
    121
    Sep 15, 2018
    24in 1440p, maybe get another monitor in the future but 24 widescreen is good enough for now.
  34. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,516
    Oct 5, 2004
    Wow, you guys really think 21" is "pushing it?" ... LMAO ... wow.
    That's like looking at a cell phone screen for me.
    49" KS8000 here being pushed by a 2080 Ti. Nothing better.
    I have friends tell me it's too big. I tell them, no, it's no different than when someone uses 3 x monitors .. the difference is, I don't have bezels lol. It always shuts them up.
    revenant and g00z13 like this.
  35. wyqtor
    wyqtor Limp Gawd
    399
    Dec 30, 2011
    Samsung CFG70, 23.5 inch VA Quantum Dot 1080p 144 Hz FreeSync. I won't be buying anything less than VA 144 Hz with Quantum Dots ever again.
    If only it were 1440p or 4K @ 27 inches and GSync, then it would be the perfect monitor for me!
  36. ganesh21
    ganesh21 2[H]4U
    2,344
    Jan 22, 2006
    Samsung 43" for gaming
  37. HDriscoll
    HDriscoll Limp Gawd
    416
    Jun 18, 2012
    I use three Dell 27" U2717D 2560x1440, they are a slight upgrade from my three 27" 1080P displays (also from Dell)
    27" is the largest display my triple monitor stand will support
  38. dthree
    dthree n00b
    28
    Apr 5, 2016
    24" monitor and 20" monitor
  39. kirbyrj
    kirbyrj [H]ard as it Gets
    24,388
    Feb 1, 2005
    Ditto, although, my GF needs a TV, so I might end up swapping this out for a G-sync or Freesync monitor to try it out.
  40. Hulk
    Hulk [H]ardness Supreme
    5,893
    Nov 4, 2005
    Dell 17-inch CRT Monitor.
