Hot! - Inland 1TB NVMe Premium $107.99 Microcenter
Discussion in '[H]ot|DEALS' started by SixFootDuo, Mar 6, 2019.
  1. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
    They have some weird security with their credit page, I just changed my billing address to the 'verified' address they had and it went through..
  2. DeeFrag
    DeeFrag [H]ardness Supreme
    5,638
    Jan 14, 2005
    Microcenter doesn't ship to Nigeria. :p
  3. Xerack
    Xerack Gawd
    588
    Jan 24, 2006
    I had the same issue when I ordered one. I ended up having to call them and ordered it over the phone. I received a confirmation email that I had placed the order - and I am supposed to receive another once it has shipped.
  4. Kajun614
    Kajun614 Limp Gawd
    151
    Jul 7, 2016
    Just reserved one for pickup
  5. NickJames
    NickJames [H]ardness Supreme
    6,611
    Apr 28, 2009
    Yeah tried that, I have ordered from them years ago with no issues, same address too so I have no idea why it's giving me shit all of a sudden. Guess I'll have to contact support but I am also really lazy so..
  6. 86 5.0L
    86 5.0L [H]ardness Supreme
    6,806
    Nov 13, 2006
    Honestly only the controller needs cooling, might get this and replace the silicone bands with zip ties
  7. kwatch
    kwatch [H]Lite
    77
    Sep 28, 2006
    I bought 512GB version today. Please recommend me a disk utility program to check endurance and updating firmware like Samsung Magician. Thanks.
  8. tangoseal
    tangoseal [H]ardness Supreme
    7,498
    Dec 18, 2010
    I dont think there is any out there. I could be wrong. At least not from MIcrocenter or Inland.
    I placed one on reservation to pickup at the Marietta, GA store tomorrow when I get around to going down there.
    To everyone else here is the datasheet on the drive.
    Hawk Hardcase likes this.
  9. 86 5.0L
    6,806
    Nov 13, 2006
  10. 86 5.0L
    6,806
    Nov 13, 2006
    close to what the drive is rated for, see above
    EDIT: nvm i see :facepalm:
  11. Kajun614
    Kajun614 Limp Gawd
    151
    Jul 7, 2016
    I will keep this in mind if I feel it needs more cooling.
  12. bullet-worm
    bullet-worm Limp Gawd
    129
    Oct 8, 2013
    I'm looking at this for my next gaming system build where my main goal is to cut load-screen times. Assuming you do not have serious air flow problems in your case, does the throttling only happen on large data writes (like copying a large amount of data), or is it a problem with general gaming use as well? Some of these games are taking 30-40 seconds to load on a normal Sata SSD these days, and minutes to load on a mechanical drive...
    Also, just to clarify in case I want to heatsink the drive anyway, the controller chip is the Phison chip, correct? I am thinking those Raspberry Pi heatsinks should be just about the right size to sit on just that chip and at least give it some more thermal headroom.
    I don't think I have seen anyone mention what size the cache is on this drive. How long before the drive writes slow down because the cache is full? I know this isn't a real issue for game loading, but perhaps it could be in game installs as these can hit 50+GB regularly these days...
    Finally, I'm not even certain how these people even know they are hitting thermal throttling when it could just be that the cache is simply full. My layman's understanding is that once that cache is full, any further writes have to go straight to TLC which is much slower, and that is being done at the same time as the cache being written to TLC as well, but when some cache gets freed up there is another short burst of write speed until the cache is full again. This appears to be exactly what people are experiencing on the videos I have seen that call it "throttling". I'm certainly no SSD expert though, so I could be way off there.
    worm
  13. DogsofJune
    DogsofJune 2[H]4U
    2,667
    Nov 7, 2008
    I should look at the temps of my name on my Asus board. It has a heatsink and is sandwiched between Mobo and sound.
  14. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
    Remember reading somewhere that the most heat comes from the controller, not the RAM, I totally agree.
    What this video says is that according to storage expert, the controller tends to heat up but it's rare, while the Flash RAM actually 'wants' to get hot, it experiences less wear if it is allowed to operate at higher temperatures.
    Gonna open up my machines again and do some trimming with the ol' X-Acto blade..
  15. eclypse
    eclypse 2[H]4U
    3,050
    Dec 7, 2003
    Yeah I guess I might return that cooler back to Amazon. Or just trim the pad so only the controller is touching.. be tuff since it's a dual sided cooler.
  16. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,516
    Oct 5, 2004
    Ummm, yeah SSD heatsinks raise temps, not lower them. This is with the past 3 motherboards I've owned across a few M.2 ssd's. My experience that is.
    Used an after market cooler and then the 2 that came with my Asus Hero boards. If you guys didn't know, the high end Asus boards ship with SSD coolers now, and have for the past few years.
    Also, this new Phison E12 controller uses a new .28 micron process which is ( and I think I've read this ) is industry leading? So it runs cooler than past SSD's ...
    The operating temps for these SSD is pretty high. So there shouldn't be anything to really be worried about unless you're just trying to pretty up your SSDs.
    Are some of you guys suggesting that you're taking performance hits because of thermal throttling?
    Also, this is an option if you want to put additional air flow directly across your SSD's.
    https://www.ebay.com/itm/Thermal-Se...m466dd9e712:g:FYsAAOxy9X5TW63R&frcectupt=true
    $12.99 shipped free.
    If you have deep pockets, and I've used a few of these, there are also those InWin Mars 120mm's
    https://www.amazon.com/InWin-Mars-B...MD1XAN9Y92X&psc=1&refRID=GVS8KNB5PMD1XAN9Y92X
    Lot of you will not even know these were on the market. They are pricey at $50+ each.
    Here is a video.
    Hawk Hardcase and eclypse like this.
  17. tangoseal
    7,498
    Dec 18, 2010
    I just got one from Marietta Microcenter in GA. They have bunches of them in stock.
  18. SixFootDuo
    5,516
    Oct 5, 2004
    Grats loving mine. If they drop to $120 or so I will pick another up. Will give me 4Tb solid
    state storage
    tangoseal likes this.
  19. Jim Kim
    Jim Kim 2[H]4U
    3,467
    May 24, 2012
    Mine is on its way! The great thing is it's coming by FedEx SmartPost, that way you know it gets a chance to be handled by every human on the planet only adding 3-4 days shipping time.o_O
    86 5.0L, Azrak, kirbyrj and 2 others like this.
  20. Jim Kim
    Jim Kim 2[H]4U
    3,467
    May 24, 2012
    darknite39 likes this.
  21. Xerack
    Xerack Gawd
    588
    Jan 24, 2006
    LOL - yeah, I guess I should have chosen a faster shipping method as well....ordered mine last friday...it's scheduled to arrive next thursday. (via same method)
    Jim Kim likes this.
  22. equinox654
    equinox654 Limp Gawd
    319
    Apr 7, 2005
    I picked mine up this past sunday at microcenter to put into my new Razer blade 15. None of the guys in the component area were wise to it. Guy in front of me in line got a 660p drive. I showed him the inland one on my phone and he scoffed lol.
  23. SixFootDuo
    5,516
    Oct 5, 2004
    Lot of guys do this. Even here on these forums that have read this very forum thread. They are so blind to branding, they will literally lose money, time and performance out of ignorance.
  24. tangoseal
    7,498
    Dec 18, 2010
    Here is my 960 Pro 512GB with approx 156 GB of data on it currently.
    This is the Inland Professional 1TB from Microcenter with no data on it.
    This is the Inland Professional 1TB from Microcenter with 156 GB Dummy File that I created to see how the fast the controller/nand is with the same amount of data as the 960 pro.
    Samsung 960 Pro Input Output Operations
    Inland Pro 1tb IOPS
    darknite39, Chimpee, Hulk and 4 others like this.
  25. SixFootDuo
    5,516
    Oct 5, 2004
    You can actually fill up the Inland to 87% maybe more and the read / write speed will not degrade according to one of the reviews I read.
    Chimpee, Hawk Hardcase and tangoseal like this.
  26. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
    Wonder if Inland will ever produce a 2 TB part based on the Phison E12?
  27. Kajun614
    Kajun614 Limp Gawd
    151
    Jul 7, 2016
    Ok, have the 1TB in my hand for my work pc. The fun of having work pay for a pc upgrade. then I can see how I like it for future home use.
  28. caw2007
    caw2007 [H]ard|Gawd
    1,851
    Jan 8, 2008
    STL store just got a bunch, I grabbed two for fun! I almost grabbed two 512GB last week. I'm glad I waited.
  29. Tricyclthief
    Tricyclthief Limp Gawd
    307
    Aug 12, 2011
    I had the same issue, if you have an apartment # in your address remove that from the billing address and leave it in the shipping. Mine went through fine after that.
  30. crazycuz20
    crazycuz20 [H]Lite
    81
    Oct 3, 2017
    Ugh I have to stop logging into this forum, just reserved 4 of them and ordered the Asus Hyper M.2 to go with the $88 open box Strix X399 I got yesterday. That replaced my Zenith Extreme that fried, but I bought the 2 year replacement plan so they gave me a store credit for it. Not bad a trade, spend an extra $200, get 4TB's of super high speed storage and a slightly inferior board. Instead of a measly 3 NVME, I'm upgrading to 4.5 (.5 being the stupid vertical slot) and a little less RGB. I kept all the accessories so that 10G NIC card will fit nicely into the new FreeNAS/VM build. Living 5 minutes from MC is a blessing and a curse.
  31. NickJames
    6,611
    Apr 28, 2009
    Nope just an address, I live in a home. Literally tried 3 different version of it including the verified. Same address (I had saved) I have used to purchase from MC before so they must've changed point of sale systems and now it's throwing this stupid error for no reason.
  32. tangoseal
    7,498
    Dec 18, 2010
    Just call them and place your order old school. No one thinks about this stuff anymore.
    jmilcher likes this.
  33. Damn Dirty Ape
    Damn Dirty Ape [H]ard|Gawd
    1,825
    Nov 21, 2005
    ZGot one at St Louis MO MC.
  34. DogsofJune
    DogsofJune 2[H]4U
    2,667
    Nov 7, 2008
    I was actually just thinking that. I'm sure eventually we may see something like that. Though for mass storage, I'll probably stick to regular HD's. But, I wouldn't mind seeing other options.
  35. Joust
    Joust 2[H]4U
    2,879
    Nov 30, 2017
    I couldn't find their Skype link.
  36. NickJames
    6,611
    Apr 28, 2009
    That's cause I am lazy and spoiled, if the website doesn't work then I won't put the effort lol
  37. Jim Kim
    Jim Kim 2[H]4U
    3,467
    May 24, 2012
    /beginrant
    I live in Tx. The ssd left a Mesquite TX warehouse in a fedex truck 2 days ago and crossed the street into beautiful Dallas TX where it is now;
    Status
    Pre-Shipment
    March 20, 2019
    Pre-Shipment Info Sent to USPS, USPS Awaiting Item
    /endrant
    fml
    :D
  38. eclypse
    eclypse 2[H]4U
    3,050
    Dec 7, 2003
    I just went today to return my new 979 evo that I bought at the time i bought my upgrade as they didnt have that bad ass drive in stock at the moment.
    Here on the recipet showed I didnt pay for the Samsung 970 evo. The guy tried to keep saying the women didnt ring me up for it.. and hes gona keep it.
    I'm like no. I might of bought it on newegg or Amazon so I think I'll take it home and check. ;)
    Seriously.. it's not my fault the women was too busy trying to sell me on the warranties for the 9900k cpu, evga 2080ti ftw3 ultra GPU and asus maximus z390 formula mb to miss scanning the 970 1t drive.
    Free drive.. I got the inland 1t drive from there web site as well.. hope I can use both drives!
  39. SixFootDuo
    5,516
    Oct 5, 2004
    Would you please take pictures for us of all the drives, the Asus card and benches? Many of us are very interested in this. You should see 10k to 12K reads and writes. Also, some load times, etc
    crazycuz20 likes this.
  40. equinox654
    319
    Apr 7, 2005
    I live in the dfw. There is nothing beautiful about Dallas. All the roads are shitty and they have those concrete dividers everywhere. Every time I drive through that place I wish for the aliens to come vaporize 1/2 the people on the road.
    86 5.0L, CruisD64 and Hawk Hardcase like this.
