Hot! - Inland 1TB NVMe Premium $107.99 Microcenter
Discussion in '[H]ot|DEALS' started by SixFootDuo, Mar 6, 2019.
  1. compgeek89
    compgeek89 Limp Gawd
    142
    Nov 30, 2018
    Haha... I mean, am I missing anything? Is there any reason at all I would spend over twice as much for a 970 EVO Plus????! These seem like an amazing find, and you can grab em on Amazon.
    tangoseal likes this.
  2. Lateralus
    Lateralus More [H]uman than Human
    14,489
    Aug 7, 2004
    I've been pretty loyal to Samsung SSDs over the years, but for me personally, I don't think I could justify the price increase over these.
    Thinking about buying one of the 2TB versions if they approach the price parity per GB of the 1TB version.
    compgeek89 likes this.
  3. eclypse
    eclypse 2[H]4U
    3,050
    Dec 7, 2003
    I have a free Samsung 970 evo plus and wondering how much slower it is compared to these drives?
    Need to install the drive today as it's still unopened.. but planned on selling it and just buying another one of these drives but the wifes likes not spending money if not needed.
  4. Nenu
    Nenu [H]ardened
    18,843
    Apr 28, 2007
    Long time user opinions are valued too ;)
  5. compgeek89
    142
    Nov 30, 2018
    Feel like you have an easy $100 on your hands if you sell that and get one of these.
  6. eclypse
    eclypse 2[H]4U
    3,050
    Dec 7, 2003
    Yup but I'd also have to drive an hour total for it. Today on fathers day.
  7. Maxx
    Maxx [H]ard|Gawd
    1,460
    Mar 31, 2003
    There's a couple of differences with regard to hardware. First, the Samsung drives are always single-sided, utilizing two NAND packages. The E12 drives like this one are single-sided up to and including 480/500/512GB with some exceptions (e.g. Silicon power P34A80). At 1TB and up this drive is double-sided with four NAND packages. This has some consequences, with single-sided drives being preferable in mobile/SFF machines and generally being more efficient and easier to cool. At 2TB the single-sided drives have to use denser NAND (512Gb vs. 256Gb) due to only having two packages (16DP x 2 = 32 dies).
    This is less of a problem with the EVO Plus (vs. regular EVO) because the EVO Plus utilizes 96-layer NAND. The E12 drives (so far) rely on 64-layer NAND which is a bit less performant. Not an issue with lesser workloads either way. The 970 EVO Plus uses the same controller as the 970 EVO/Pro which is an upclocked version of the Polaris (960 EVO/Pro), although all SSD controllers are basically ARM Cortex-R with some differences like ECC. This is a penta-core controller vs. the (newer) quad-core Phison E12/E16, both of which can handle heavier workloads quite well. The E12 is more efficient (power usage) under these loads generally. Both have the same amount of DRAM (typical 1GB:1TB ratio).
    From a design perspective the 970 EVO Plus has static + dynamic SLC caches (6 & 42GB, respectively, at this capacity) while the E12 drives have just a dynamic (30GB). This mostly influences write performance consistency especially at edge cases (e.g. fuller drive). Generally speaking I consider the E12 drives to be "budget 970 EVO" as they have a somewhat similar performance profile as compared to the SM2262/EN drives. However, in real world terms, the E12 is often better than the 970 EVO, but the 970 EVO Plus (with its 96L NAND) tends to pull ahead across-the-board. It's a faster drive thanks to the NAND. Worth noting is that the E12/E16 controllers (and SM2262/EN) support 96L NAND just fine and do quite well with it.
    But since your question specifically asks about the Inland Premium vs. 970 EVO Plus: the Plus is going to be the faster drive. In every day terms I don't think you'd notice a difference. If you can actually use the sequential performance the EVO Plus will be faster. If you're doing heavy workloads, the Plus will be faster. The Plus to me is the real 970 Pro alternative/replacement drive and it's priced accordingly. I just don't think most people need that extra bump in performance.
  8. eclypse
    eclypse 2[H]4U
    3,050
    Dec 7, 2003
    Said screw it and hit the store for that hour round trip+ drive and snagged another one and some water fittings.
  9. eclypse
    eclypse 2[H]4U
    3,050
    Dec 7, 2003
    Thanks for all that info! Yeah it's just gona be a game drive so I guess I wont notice the speed difference of the 2 so go with the cheaper inland. ;)
  10. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,346
    Jun 13, 2003
    If you were able to notice a difference using either as a game drive, you'd have a defective part on your hands ;)
    Jim Kim likes this.
  11. Maxx
    Maxx [H]ard|Gawd
    1,460
    Mar 31, 2003
    Should have roughly the same load times, yeah. You generally won't see much gain there even when comparing a SATA SSD, although some games do see a boost with NVMe for me (e.g. Unity engine games). But even then it's 15% at the maximum. (and that has nothing to do with sequentials - I compared it to a 3xSATA SSD RAID-0/stripe as well; it's the boost to random read performance)
  12. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,517
    Oct 5, 2004
    I heard a rather tasty tidbit .... Microcenter is going to be carrying a 2TB E12 drive and it's expected to cost around $169 or so. The guy said it's a "rumor" for now.
  13. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    28,322
    Oct 29, 2000
    What kind of source was that?
    Jim Kim likes this.
  14. jubalskeiki
    jubalskeiki Limp Gawd
    452
    Jan 27, 2005
    How hot does this thing get? I had a Mushkin https://www.amazon.com/gp/product/B07CYJ4GS3/ drive die a couple months back in my laptop from overheating. I read these sticks can get pretty warm. Really tempted, because I think the other drive in the laptop might be starting to go too...starting to get random disk usage spikes. (it's not an SSD, just a regular HDD). So I'm really looking to replace the NVMe drive now, but don't want to lose another drive after only a few months.
  15. tempertantrum
    tempertantrum Limp Gawd
    327
    Apr 19, 2009
    Check out the drive health using HD Sentinel or a similar tool. You might want to stop using it until it's replaced. (I've had so many clients who thought, something's wrong, I need to think about replacing that soon, but they always wait too long, and by the time you've started to notice real slowdowns from drive errors, it's usually too late to get a clean copy!)
  16. jubalskeiki
    452
    Jan 27, 2005
    Well thankfully (or unfortunately depending on how you look at it) everything I needed to rescue I had to attempt to do so when my OS drive crashed and I was forced to install the OS on this drive. I couldn't remember if it would require a full format of the drive first (I'd only done an install on a clean disk in the first place), so I partitioned off a section of the drive, but backed up the important information first just to be safe. Also, the disk itself isn't running slowly, yet. I'm just getting odd disk usage spikes. Which my research is telling me could be indicative of a drive getting ready to fail. If that does happen before I'm able to replace one (or both) of the drives I can always reinstall the old, tiny, NVMe SSD the computer came with. I just don't want to have to take all of the screws out more times than I have to. Less risk of stripping them out.
    tempertantrum likes this.
  17. Maxx
    Maxx [H]ard|Gawd
    1,460
    Mar 31, 2003
    You had a Mushkin Pilot overheat? Then you definitely don't want one of these. The Pilot uses the SM2262 which generally runs cooler than competing controllers. I've never had mine (I have 3) get even within 10C of throttling (70C) let alone a critical temperature (80C+). If you're set on NVMe for that laptop I would suggest a single-sided, "budget NVMe" (check my guides/spreadsheet) at the maximum. But honestly if you're having that many drive issues then something is wrong.
  18. AXm77
    AXm77 Limp Gawd
    133
    Jun 4, 2012
    Back to $119.99 :(
  19. jubalskeiki
    452
    Jan 27, 2005
    I wasn't running heat measuring software, but I was able to pull some semi-vital info off the drive by setting it on a clay icepack. I wasn't even thinking about heat being a problem until it crashed and disappeared from the BIOS, and I started doing research. It could be that I just got a bad card. I'm really not sure. The drive that came with the laptop was only 128GB, which was OK for JUST the OS, but very little else. I upgraded to the 500, because I figured it would give me some breathing room (and it wasn't significantly more expensive than the 256, so for twice the space it was worth it, it was on sale). I'm thinking it's just bad luck with the drive problems. The HDD is 18 months old, so if it's also a lemon...unless there's a fault on the motherboard. Something that's literally killing drives. Although for the first 9 months or so that I used the smaller SSD I didn't have any issues with it. It's still functional. Just very small. So I was always playing a space management game with applications. (also sorry for the off-topic)
  20. Kardonxt
    Kardonxt 2[H]4U
    2,933
    Apr 13, 2009
    I just game on my home PC but so far the drive has been fine stuffed on the backside of my ITX mobo with no heatsink or airflow.
  21. jubalskeiki
    452
    Jan 27, 2005
    It's still 95 dollars at Amazon.
  22. IdiotInCharge
    11,346
    Jun 13, 2003
    Just bought a 660p for a laptop, lower intensity load, but I'd grab one of these for my desktop- it's just enough space.
  23. AnIgnorantPerson
    AnIgnorantPerson Limp Gawd
    179
    Jan 10, 2019
    I am actually highly interested in those 2TB models. So i am avoiding the urge to buy the 1TB in hopes the 2TBs come soon
    Lateralus likes this.
  24. doublejack
    doublejack Limp Gawd
    446
    Apr 13, 2015
    The price hasn't changed at my local MC, still $97.
    You don't want this drive, or any Phison E12. Do yourself a huge favor and go for the Intel 660p. You want a single sided drive because it will be cooler and more power efficient, both keys for your use case. The 660p is a QLC drive which has further power savings, and quite good 4k performance. If I were shopping for an NVME for my laptop that's the one I'd want.
  25. Gorilla
    Gorilla [H]ardness Supreme
    6,019
    Sep 14, 2007
    Do you mean the slower "Professional" model? Because the Premium that this thread is about is $105 on Amazon.
  26. SixFootDuo
    5,517
    Oct 5, 2004
    The same guy that told me about these drives 2 or 3 weeks before the store had them. He said that ( this ) drive was a rumor as well.
    Who knows but ... it's not like they couldn't do this if they wanted. A 1.9TB E12 drive is already on the market and has been for many months.
    The logic supports the rumor however. These 1TB NVMe Premium drives can't possibly be the last drive ever from Inland!? So if not, then what's next?
    As these drives continue to age and drop in price what can Microcenter add to this "Premium" lineup that will continue to make money for the company? Surely the margins are shrinking. Healthier margins with larger 2TB and higher priced NVMe 2TB Premium drives?
    What do you guys think? What's next? I do know there are LED / Micro LED NVMe drivers about to hit the market and or have hit the market. Maybe an RGB LED NVMe Premium drive is next.
  27. Nenu
    Nenu [H]ardened
    18,843
    Apr 28, 2007
    Whats next are PCI-e 4.0 NVME, double the speed again.
    Phison announced up to 6.5GB/s next year, the first appearing in quarter 1.
    https://www.pcgamer.com/uk/phison-says-ssds-will-hit-65gbs-speeds-next-year/
    On the face of it this will only help large file transfers.
    I would like to see them tackle 4K byte transfers faster, with less heat and less CPU use.
    Oh and handle 512 byte sector emulation instead of just 4K.
    One can wish.
  28. erek
    erek 2[H]4U
    2,591
    Dec 19, 2005
  29. YeuEmMaiMai
    YeuEmMaiMai [H]ardForum Junkie
    14,805
    Jun 11, 2004
    time for a thread title change... I used to have 97 problems, now I have 119 :p edit scratch that, the price is back at 97.99
  30. YeuEmMaiMai
    14,805
    Jun 11, 2004
    yeah until the drive gets half full and the performance tanks...
  31. OFaceSIG
    OFaceSIG [H]ard|Gawd
    2,019
    Aug 31, 2009
    I'm really happy with what I'm seeing from Microcenter in the past decade. They are REALLY trying to be competitive with online retail. If I need to buy a new processor/mobo and both are carried at Microcenter locally, it's almost always cheaper then online (at least in the parts choices I've been making) and I can pick it up that day. Over the past few years their inland drives are really starting to make a splash now too, as we've seen with this thread.
    It's good to see a local place not buckle under online competition. I grew up in Los Angeles and really used to love going to Fry's. I live in Texas now (thank God) and even though Fry's is here too, it sucks now. It's been nearly a decade since I've been in a Fry's for a good special that I was excited about.
    eclypse likes this.
  32. InfeKtioN
    InfeKtioN [H]Lite
    113
    Aug 31, 2006
    Still showing 97.99 on the web store /shrug
  33. doublejack
    446
    Apr 13, 2015
    Performance won't tank with the drive half full unless you are dropping 75GB of data on the 660p at one time. Then it will need time to fold up the data and free up some SLC cache.
    For most use cases, performance will remain good until the drive is nearly full.
    But it is your money, you do you. If you'd rather have much shorter battery life and a mobile lap warmer, then go ahead and put an E12 drive in a laptop.
  34. YeuEmMaiMai
    14,805
    Jun 11, 2004
    lol desktops do not run on batteries did you just assume what i am computing with?
  35. coynatha
    coynatha Limp Gawd
    285
    Jun 9, 2004
    Context. Quit being all butt-hurt and starting shit.
    doublejack likes this.
  36. YeuEmMaiMai
    14,805
    Jun 11, 2004
    joke
    you...
    point is drive is great for what it will be used for...
  37. doublejack
    446
    Apr 13, 2015
    For a desktop I'd probably go with the Phison E12 drive, although it is not a no-brainer because the 4k performance of the 660p is pretty impressive. Both are good drives in their own way. However, my reply was to someone asking about an NVME for a laptop.
  38. IdiotInCharge
    11,346
    Jun 13, 2003
    Got the 2TB 660p in my ultrabook... third install of Windows going on, looks like on this laptop (an ASUS) transfers are a no-go due to security, and I say that to say that I've pretty much reamed this drive with bulk transfers and it's both still kicking and not overheating. I think it's cooler under load than the Sandisk SATA SSD that the 660p replaced.
  39. dhp318
    dhp318 n00b
    17
    Aug 18, 2011
    Is there any word on a 2 TB version other than the sort of vagueish rumors earlier in this thread?
  40. Zarathustra[H]
    28,322
    Oct 29, 2000
    I'm not convinced there is much value in Gen4 x4 m.2 drives. We are already so far into diminishing returns territory with Gen3 X4 that it is silly.
    Where Gen4 sounds more interesting to me is to be able to use 2 lanes instead of 4, so you can stretch the lanes further.
