Got my Westinghouse LVM-37W3 37" 1080p display today!
Discussion in 'Displays' started by 5150Joker, Aug 15, 2006.
  1. w1retap
    w1retap [H]ardForum Junkie
    11,933
    Jul 17, 2006
    Must be your graphics card then. Update your video card drivers? And.. confirm that your 1900xtx is indeed HDCP certified.
  2. duce3
    duce3 Gawd
    524
    Dec 13, 2006
    Well I have had mine for a week Tomorrow and all I can say is wow. Just wall mounted it Friday night and had a headache figuring out how to remove the base, but once you figure it out it moves smooth. Love having this thing on the wall! As for picture quality it looks amazing. Had my laptop hooked up to it and it looked like ass! I think that it was the laptops fault completely and due to running off of a weak video card through VGA. I have my xbox 360 as the only source hooked up to it and I think it looks amazing. Games that can be upscaled are brilliant and games that can't still look great but a little washed out but not much, but you can edit your settings in the monitor to correct it. I love that you can set your settings for each connection separately for the best results on this thing so leaving my xbox hooked up through VGA and correcting them from there will have no affect when I build my new PC and run it through DVI-1. What I would like to see is an HDMI cable for the 360 and an update that allows you to tweak visual settings from the dashboard. Once I get my new pc ordered and built I will post pictures.
  3. JayD
    JayD Limp Gawd
    339
    Jul 27, 2004
    Driver is up to date and my x1900xtx is HDCP compliant. Anyone else have any ideas? Is there a process to enable an HDCP handshake of some sort?
  4. duce3
    duce3 Gawd
    524
    Dec 13, 2006
    Could it be the cable that you are using?
  5. w1retap
    11,933
    Jul 17, 2006
    Did you even try playing the HDDVD.. or are you just using the test program to see if you are compliant? If you go to play a HDDVD.. what does it do on your PC? Any error message.. post a screenshot?
  6. altdelete47
    altdelete47 n00b
    22
    Jun 27, 2006
    huh? No offense, but this sounds like bullsh*t to me. It makes no sense at all, and I have never heard of a product version number counting down. Does that mean that if they change something now, the version would be 0.9?
    Sounds like something a support rep would say on the phone to make you feel better, and so they don't have to come out and update your firmware.
  7. theTIK
    theTIK Gawd
    757
    Jul 3, 2003
    I heard someone say that it went from 1.1-1.8 and 1.8 is the same thing as 1.0. I dunno
  8. Starfox
    Starfox 2[H]4U
    2,220
    May 6, 2002
    How do I get high definition channels from an antennae to work on this TV?
  9. jester55
    jester55 [H]Lite
    116
    Jan 26, 2007
    No offense to you, but if you would have read the thread, you would know that 1.0 is final! No other revisions will be made!
    Here is one of many quotes w/ page to back it up....
    page 77
    Next time do your research before calling bullsh*t!!!!
  10. duce3
    duce3 Gawd
    524
    Dec 13, 2006
    I got a quick question do you guys leave your westy in the sleep mode or do you turn it off for the night?
  11. facesnorth
    facesnorth Limp Gawd
    240
    Feb 5, 2007
    What do you mean by this? Your VISA card doubles warranty's on electronics equipment? Or the store doubles it if you use a certain VISA? Give us the scoop on this.
    Ryan
  12. facesnorth
    240
    Feb 5, 2007
    I've read the entire thread and there's a lot of debate about what the final firmware revision is. I've yet to see someone provide a truly authoritative source.
    Besides, it's unreasonable to suggest that any revision is final. That would cause me to lose interest in this product. It would be arrogant to assume that no further revisions will ever be necessary.
    Ryan
  13. facesnorth
    240
    Feb 5, 2007
    Speaking of firmware, can you guys who have recently ordered from mwave let us know what firmware revision you are receiving?
    Ryan
  14. facesnorth
    240
    Feb 5, 2007
    One more thing, I'd like to ask anyone who is pretty familiar with LCD's, not just the budget ones, but the $2k+ ones as well (most people seem to compare it with other budget models). How does the 37w3 compare with other 37-42" LCD's (of all price ranges) in the following:
    optimal viewing angles
    SD picture quality
    use as TV
    use as X-360 display
    use as PC monitor
    color quality
    deep blacks
    ghosting/banding/etc
    any other misc observations
    Ryan
  15. facesnorth
    240
    Feb 5, 2007
    One last question.
    Most people I read about here seem to have some fancy 8800, 9500, etc gfx cards. I presently use an evga geforce 6600 gt (pci express) w/ a 21" NEC MultiSync FE 1250+. They suit me fine for my needs. I am interested in the 37w3 primarily as a tv and for playing my 360. However, it would be nice to hook the PC up as well. Will I run into problems using my 6600 gt? If not, what would be the cheapest upgrade on a pci express card that can pump this baby?
    Ryan
  16. facesnorth
    240
    Feb 5, 2007
    I do have to mention the fact that most people use this as a PC monitor does cheapen it in my eyes. It makes it less desirable to me to use as a TV. I can't imagine your budgets. You people using this for a PC monitor, dare I ask what you use for a TV?
    Ryan
  17. Ryom
    Ryom [H]ard|Gawd
    1,615
    Oct 11, 2006
    I use an HP MX70 17" CRT as my TV.
  18. Nor Gitram
    Nor Gitram n00b
    22
    Sep 5, 2004
    cameltoe.....thanks for taking the time to run that Cyberlink advisor test. I talked to westinghouse support and they suspect my HDCP handshake issue is with the monitor and to ship it to them for testing..repair or replace. He also said, that he believed firmware 1.8 was the latest and that the firmware versions only effect the menu system.
  19. evanisthecoastie
    evanisthecoastie [H]ardness Supreme
    4,706
    Nov 14, 2006
    why only think of using the westy as one type of screen? i recall someone split screening it as a tv/computer monitor. or why not just toggle it the way you want to use it?
  20. board2death986
    board2death986 [H]ard|Gawd
    1,404
    Aug 13, 2005
    Well yea, i split it up between my HTPC, digital cable, xbox 360, xbox, and my old vcr/dvd combo player.
  21. tygirwulf
    tygirwulf n00b
    39
    Aug 19, 2006
    Anyone see the March PC Gamer review on the Westy? They recommended it over the 30" Dell and a 30" HP (I think). My boyfriend keeps taking it to work so I haven't really had a good look at the magazine yet.
    My bf and I spend more time together now thanks to the Westy. We can watch movies, play split screened games, or just watch each other play games. I think for a wedding present I will get my parents to buy us another one of these things. lol
    My only real complaint is not any fault of the Westy's. A lot of sites don't work well with large text and few games have text sizes large enough to read easily when you are sitting 4.5 feet away. I was just trying out Eve Online and the largest text size is 12pt, which is ridiculously hard trying to read from the couch. Sheesh.
  22. BATMAN33
    BATMAN33 n00b
    26
    Nov 16, 2006
    the new is 1.8
  23. evanisthecoastie
    4,706
    Nov 14, 2006
    quick question:
    Hows the non native LARGE res work out on this bad boy?
  24. w1retap
    11,933
    Jul 17, 2006
    What would that be...? Of course you get fuzzy text with non one-to-one pixel mapping, just the same as any other LCD.
  25. DrewRosenHouse
    DrewRosenHouse Limp Gawd
    391
    Jan 12, 2007
    Wait is the new firmware 1.8 or 1.0? You say 1.8 and everyone else says 1.0 , can anyone actually confirm this or is everyone just giving there own opinions.
    Also how do I find out which version of firmware I have, is it written on the box?
  26. [H]ump
    [H]ump [H]Lite
    119
    Jun 22, 2003
    Let me know about the bestbuy thing, they have a great warranty walk in and basically they replace.
  27. cameltoe1009
    cameltoe1009 n00b
    42
    Feb 7, 2007
    My firmware version is 1.8.
    I have a stuck pixel as well..damnit. Its off to the side so I cant see it unless I go looking for it.....I think I can live with it.
  28. DrewRosenHouse
    391
    Jan 12, 2007
    Bestbuy doesnt carry this model in any of there stores, you can only price match items in-store I believe.
  29. Ohgami
    Ohgami n00b
    56
    Jan 22, 2007
    This is a Monitor as has been stated 9827394870431 times in this thread. You'll need an external tuner such as a HD Cable box, HD Sat tuner ot a OTA Set top Tuner.
  30. g0dM@n
    g0dM@n [H]ardness Supreme
    5,182
    Nov 18, 2005
    how's this monitor do at 1080i or 720p for up-conversion DVD players, and also for Digital TV Channels???
  31. evanisthecoastie
    4,706
    Nov 14, 2006
    HD tuners should not ever be needed, you order HD service, you get HD tuners from your tv company
  32. KENNYB
    KENNYB 2[H]4U
    3,139
    Jul 26, 2004
    I use this monitor primarily as a HDTV. I don't care how well it does or does not display SD. If the TV/Monitor is less desirable to you because of how OTHER people use it then maybe you're the one with the problem, not us.
  33. w1retap
    11,933
    Jul 17, 2006
    Already been answered.. DVD upconversion does nothing but stretch out a 720x480 DVD and apply image sharpening filters. Your image is only as good as your source. I own a pretty nice LG upconversion DVD player... trust me, its not worth the money. Invest in a better solution such as HDDVD, Bluray, and HD cable if you want real HD.
  34. BATMAN33
    BATMAN33 n00b
    26
    Nov 16, 2006
    1.8 is the new firmware.ps3 work well with 1.8 no handshake problem.if u think that a lie
    go to avs forum and read about it.1.6 1.5 1.0 have handshake. not 1.8;)
  35. cameltoe1009
    cameltoe1009 n00b
    42
    Feb 7, 2007
    i have v1.8 and have the blinking problem...need to unplug the hdmi and plug it back it...
  36. facesnorth
    240
    Feb 5, 2007
    There's no need to bring hostility onto a forum post about electronics equipment.
    In my area, and on my budget, sadly, I will only have access to a small handful of HD channels. Many of the channels I enjoy watching (and pay for) only come in SD. So I do care about the quality of how those will appear. Since I don't have access to one of these to try out before purchasing online, I would like some input on how this monitor displays SD as compared to other LCD's (in any price range).
    Ryan
  37. theTIK
    theTIK Gawd
    757
    Jul 3, 2003
    They do broadcast HDTV over the air that you can pick up for free if you have an antenna and HD tuner. It is just the major networks but still.
  38. Voltron
    Voltron Limp Gawd
    137
    Mar 9, 2006
    Yeah, makes me wish I lived in a bigger city :(
    Regular TV actually looks pretty good coming from my Happague (sp?) TV card. Of coarse I've never watched HDTV so I don't know what I'm missing. :p
  39. [Retaliation]
    [Retaliation] Limp Gawd
    505
    Dec 7, 2004
    again...ill post this for the new ppl..the issues with the ps3 and hdmi have nothing to do with Westinghouse...or any other hdmi tv/lcd...its the ps3 and hdmi thats the issue
  40. facesnorth
    240
    Feb 5, 2007
    Do ALL LCD tv's have an issue w/ ps3 over HDMI? Are there any LCD's w/out this problem over HDMI?
    Ryan
