The NBA Street demo on the 360 is NATIVE 1080p.. and one other EA game coming out soon. I'm not sure of anything else.
Actually it's EA's NBA Street and Sega's Virtua Tennis that are the 1st Native 1080P for 360.
works fine for me...only "no" i get is for hd dvd and blue rayThanks for replying...I read that on there site, that's why I'm trying to see if someone with this monitor can test it with Cyberlink's Advisor. If there monitor passes the test, then my HDCP chip is probably faulty.
As it stands now I can't view any HDCP content through both DVI or HDMI ports on my monitor.
Thankyou ....I believe I have a faulty HDCP chip then.[Retaliation];1030652122 said:works fine for me...only "no" i get is for hd dvd and blue ray
Hi, I just got my monitor in and got everything working at 1080p on my pc but having problems with my Original Xbox through components(white/red/yellow). It seems I am not getting any color (grayscale) and the picture quality is really bad. In xbox it is at 780 x 480i, is that the problem? If it is the problem how do I change this resolution setting through the westy remote? I got to the resolution display by pressing the i but do not know how to change the setting. Any help would be much appreciated
Just got mine works great no dead pixels. Only problem is there's a horizontal tearing line whenever I watch 1080p movies through the xbox 360 vga cable. Anyone else have this issue? Not sure if its the connection, don't think its the westy. Doesn't appear in games or through any other input including my pc.
err, your 1900xtx is HDCP certified right? Why not just plug the Xbox 360 HDDVD drive up to the pc and use it through there with PowerDVD 7 HD/BD edition?Just got mine works great no dead pixels. Only problem is there's a horizontal tearing line whenever I watch 1080p movies through the xbox 360 vga cable. Anyone else have this issue? Not sure if its the connection, don't think its the westy. Doesn't appear in games or through any other input including my pc.
Well I've had my westy for a few days now and there are several factors that may be getting in my way of truly appreciating this set.
1. My HD BOX (Explorer 3250HD - TimeWarner) is connected via the issued Component cables - I purchased a DVI cable but the picture looked washed out (even worse). As it stands with the standard issue component cables, SD channels look shite but Ive read that is to be expected. DiscoveryHD channel and NBC seem to be the best channels thus far and HBO/Showtime are meh. I also changed the boxes defaulted output of 1080i to 720p and in advanced settings changed the picture output to "Pass Thru". I think i read that this is the best thing to do (not sure)
1Q - Why would the DVI output quality seem lower than through the component? Would better component cables really make a difference with the picture quality from the HDBox?
2. I don't have a worthy PC to actually hook this thing up to but it is in my future. Vision was to use this is my PC monitor, play Next-GenHD gaming and upscale Movies while the fight continues of BR/HD. I purchased an XBOX360 and the faded blacks/washed blacks kinda bug me but i will say that the Need for Speed demo looked WOW as hell. Really impressed. Gears of War is alright.
3. The viewing angle for this thing seems to be really really crappy. If I stand up and look down on it, it fades, if I move a slightly to the left and right away from center of it, I see a fade. Is this normal? The monitor stands on a shelf that is 21inches high puting the top of the monitor at around 4feet from the ground. Is there an ideal height for this thing?
4. How long does it take for the westy to "warm up". I noticed some green tint to the blacks today when i first powered it up with the xbox360 that I hadn't noticed last night.
5. What all should I do (without a pc) to test this monitor to make sure mine is not faulty?
6. What are the ideal settings for the VGA portion of the menu (PC?) I have no idea what those settings are for but since my XBOX360 is hooked up via VGA, the option is accessible and the more I can tweak the better.
7. Are upconverting DVD players worth it for this Monitor? Will the picture look equal to/better than DVD on standard displays?
your responses would be appreciated.
No. Upconverting does nothing. Your picture quality is only as good as your source. Upconversion players only stretch out the 720x480 DVD image and apply sharpening filters. For HD movie viewing, I suggest getting the Xbox 360 HDDVD player, a standalone HDDVD player, or a Blu-ray player. It looks amazing and its well worth it.7. Are upconverting DVD players worth it for this Monitor? Will the picture look equal to/better than DVD on standard displays?
neocvera, what firmware does your monitor have?
Just ran that Cyberlink advisor..I get 2 no's. Blue Ray player and software player. Monitor passes.
Where can I find the best deal on this monitor.
Was your pc and monitor hooked up through DVI ?
i havent seen a single person in this thread....nor am i aware of any way to flash your display...the hdmi issue with the ps3 is well documented as being a serious issue with the PS3...one of the reasons they continue to sit on store shelvesI actually talked to a Westinghouse customer service rep about the handshake issue, they said they are still working with Sony regarding this handshake issue as of just 1 week ago.
Also they said it is entirely on Sony's side (hdmi 2.0 not being backwards compatible or something), and Sony will be releasing a system update to patch it (or they are currently working on a system update to patch it)
This contradicts what I heard before from someone else, that Westinghouse has to send out someone to flash the firmware of your tv.....which one is correct? I dont know, but I want it freggin fixed already.
still looking for a canadian dealer. Still havnt found one yet that carries this monitor
Bahhh My hopes were set too high..
PowerDVD is telling me that the westy is not HDCP compliant through the DVI input. Does it have to be on DVI input 1? I have it on DVI-2 right now. Is there a display driver I have to download?
