Justintoxicated
- Apr 10, 2002
Got my SE from Costco last week.
Absolutely flawless, no sub pixel defects, screen is bright and uniform with no streaking, etc.
It does appear brighter on the edges sometimes, but thats due to how close I am sitting when I'm leaning on my desk and the viewing angle difference between the center and the edges being different. If I sit back about a foot further it evens out.
The only issue I have is the auto detection of W4207 and 1080i, took some playing around and repeating things to get it to go to 1080p.
Another also minor issue is legacy text modes show up like they are stretched to 16:9 but only the 4:3 portion shows, resulting in several columns of text cut off on both sides. This affects BIOS, POST, XP logo, full screen command prompt, etc. This only occurs with the DVI and HDMI port, VGA shows up correctly as 4:3 with no stretching or clipping. Before the SE I had a non-SE that I had to return due to an entire row of bad pixels. I used the left hand side solo DVI port and text modes scaled correctly without clipping while the port next to the HDMI on the non-SE did the same thing. So I'm sure it's the display.
Can anyone else confirm if this is an issue with the display or the video card? I'd rather it be the video card as I usually upgrade that twice a year, but I plan to keep this display for a long time. It's not a big deal, as I can fall back to VGA if I need to run anything fullscreen in text mode but it's still something that bugs me as being only 99.9999% perfect heh.
It's definately not a matter of viewing angle on my SE's They are brighter on the right hand side (facing me) on both screens. it's mostly noticable on a white background. I thoguht it was viewangle at first untill I had the image spanned across both screens. It's most noticable where the image is divided by the boarders, like when I have a window centered and it is divided (transfering from right side of westy one to left side of westy 2). I thought it just needed adjustment at first but then I noticed if I drag the box around it gets darkers on both screens as I move it towards the left side.
It's not too noticable if at all if you span the image across the entire screen, the change is too suttle left to right, you could notice this much of a shift due to viewing angles, however they both have much better contrast over all on the right hand side of the screens no matter where I am sitting...
Maybe I'm expecting too much from these? My second westy developed a stuck pixle I touched it and it seemed to have fixed it but it has come back one time already....I guess at least it's not dead pixel like the other screen but it's more annoying because it is right in the middle.
