ChelseaOilman
- Mar 27, 2001
Is there much benefit to running 2 tasks per GPU?
yes.Are two tasks running on each GPU?
I hear it's a good card for mining. Might help pay that huge electric bill you get each month.Gilthanis What project(s) benefit most from AMD GPUs? Specifically the RX580.
fastgeek everything okay with your servers? Noticed your last couple WCG updates have been really, really low. Hope nothing bad happened. I remember you posting something about them not getting work when you fired them up. Is that still the issue?
Kindle Fire HDX 7" - 16 GB WiFi Only. It may be generation 3? It has 2.2 GHz Quad Snapdragon 800. It is warm enough you can tell it is crunching but not to the point where you would consider it hot or be concerned.
phoenicis you and I think a lot alike. I believe you check the FBDash board often to see any red that might be about to pass us and jump on that project until the red goes away. I noticed you did it with Universe@home last week and now it seems you're on Citizen Science Grid with me right now as well. lol
Great minds think alike, eh?
Should we rename it ?I've been playing whack a mole using the dashboard for the last 2-3 weeks.
