bloodhawke83
I Strike Fear into the Hearts of the Masses
- Oct 8, 2010
Belt feed would be for the assault rifle...
on what they gave us, yes. but if they gave us something new, that would be nice.
I'm a dumbass...
Decided to make Starlight Drive-in my permanent home with only a simple two-story shack to live in. At least until CK is released and mods are available.
I'm getting objects set-up, making things comfy as can be, set the Bobblehead Display so it can be seen from the ground and arranging lighting. I'm experimenting with various types of lights and didn't like the placement of one of the lights so I go to scrap it. Yeah, bad time to have a hand spasm...
[IG]http://img.photobucket.com/albums/v210/AceGoober/Game%20ScreenShots/Fallout_4/AceGoober_FO4_0022.jpg[/IMG]
[IG]http://img.photobucket.com/albums/v210/AceGoober/Emoticons/FacePalm.gif[/IMG]
Anyone else get this bug? For some reason now when I'm underwater all the water seems to be totally clear / no filter over the viewpoint. Example:
http://images.akamai.steamusercontent.com/ugc/644375363423605248/D307A608270E1664FF65D89F44B2C9D8C7372319/
did you change the setting for depthoffield in the INI or add a mod that did it?
I'd say leave it.. you get to see all the nice touches they aded under the water.
I'm so happy SLI is finally working in 359.06! About time!![]()
So I can't seem to get this game to run for more than 20-30 minutes without crashing directly to the desktop? Anyone know if I have any chance of getting a refund? I purchased on steam and have 4.5 hours of intermittent gameplay plagued by bugs due to poor 21:9 support and general buggy shittiness of the game. Is there a way to go directly to Bethesda for a refund?
You can try to get a refund from Steam anyway if you explain your issues. They used to be pretty lax with the rules if you could thoughtfully explain your situation. I don't know if they have gotten more strict since first implementing the policy, though. In my opinion, you probably just need more RAM. The Gamebryo/Creation engine doesn't have very good memory management, and it's made worse with all the persistent objects in the world.The game topped out around 11GB for me after around 5 hours of continuous playing with 32GB of RAM.So I can't seem to get this game to run for more than 20-30 minutes without crashing directly to the desktop? Anyone know if I have any chance of getting a refund? I purchased on steam and have 4.5 hours of intermittent gameplay plagued by bugs due to poor 21:9 support and general buggy shittiness of the game. Is there a way to go directly to Bethesda for a refund?
Also another possibility. I've read about people having issues with FO4 and these drivers that a rollback fixed.Lemme guess...you're running the AMD Crimson drivers...aren't you?
can you confirm that SLI now works on with fallout 4 right out the box without driver tweak?
Might be worth trying out that texture mod that has been highly publicized recently. The game's textures are all uncompressed from what I understand, so VRAM might be an issue, and this mod compresses the textures while improving their look. I see 3.7GB of VRAM usage on my Titan X at 2560x1440, just to give you an idea since I know it's going to be different between video cards (Ultra preset with Medium God Rays and High Object Detail Fade), and I experience no stuttering or hitching.It's working for me with just an install of 359.06 (and an update of Geforce Experience for good measure).
Took me from ~42 fps at 3440 x 1440 to 60 fps with each card showing equal utilization (according to MSI Afterburner).
I haven't had a chance to test it for bugs, but from just fast traveling around the map really quickly before I had to leave this morning I didn't encounter any anomalies. You still get the odd hitching, but I believe that is related to the game more so than a drop in frame rate.
Sorry, I had to go digging with archives since I can't get to gaming sites at work. This is the one:
http://www.nexusmods.com/fallout4/mods/1769/
Thank you bought for the feedback. I appreciate it.
Have you tried it on a 120hz monitor to see if it uses GPUs at 100% and push framerate over 60fps?
PCGamingWiki is always a good start.Installed the game last night and I will be firing up this evening for the first time.
Would anyone be willing to summarize the "must change" settings based on general consensus? I intend on reading through most of this thread in time, but it's a daunting task.
Thank you!
I think I will try this when I get home, give the game one last chance. Hopefully I can play for longer than 30 minutes without crashing. If I can't then I will push for a refund.
Yeah, it doesn't say to create it, but it references "Fallout4Custom.ini" several times. You just have to create it yourself in your documents folder where the other .ini files rest. In Explorer you can navigate to the folder, right-click, create text document, change the name to the above, and change the file extension from .txt to .ini.Thank you Armenius!
I didn't see any reference on the PCGamingWiki page to creating a separate custom .ini file as you mentioned. I'd like to read up a little more on that.
Pretty good article on PCgamer about F4.
"But as a role-playing experience Im finding it disappointingly weakto the point where I wouldnt even call it an RPG. An open-world action game with role-playing elements would be a more accurate description..... It's more like an FPS than an RPG: a series of rooms linked with corridors, filled with enemies waiting patiently for you to kill them."
I agree with the points in this piece. Most of the quests are pretty bad and repetitive and if it wasn't for the interesting exploration/gunplay and prospect of insane mods from the community I would have already uninstalled. This seems to be a Fallout game that is clearly designed for the COD generation.
F4 just feels so shallow as an rpg.
Just a quick test with the "High" preset with the new drivers and I'm rock solid 60 everywhere I've run through for about 15 minutes now. Before it was more 40-50's.
Now to start tweaking with mods and settings to eke the most out of these drivers.![]()
Most people with moderate systems can get a locked 60+fps in most areas. Where performance takes a shit is the city/urban areas of the game. The creator of ENB stated that the engine gets overloaded by "draw calls" in these instances and is the cause of the issues and he wasn't optimistic of Bethesda being able to fix the problem. You can turn shadow distance to medium in these areas to fix part of the problem. Or use the mod on Nexus that changes the shadow distance dynamically in the problem areas.
Still haven't seen any comments.....
Is there any mod out there to allow you to go between a controller and keyboard/mouse?
I really....really.... hate that I can't set my controller down and use my k+m during firefights.
