- Sep 2, 2004
The quests are better in BL2 and you actually have builds in BL2.
Agree to disagree about the quests I guess, but as for "builds"...sure, you can have just one ultimate "build" in FO4... if you play for 600 hours.
bleh, running all on ultra with af 16x and aa off, aa makes it all blurry and i like sharp textures. it usually looks a lot better but in this pic theres the time of the day involved as in fucking up the light up i guess, the point of that pic was to show all that im building in this game, three generators and the teleport station, fuck this shit, maybe on the next run.![]()
There is no excuse for you not to have TAA turned on:
http://www.tweakguides.com/Fallout4_1.html
Run with a post sharpening filter which returns the sharpness to the textures, but maintains the smooth foliage.
Alternately you can just use SMAA from the same tool, which does not blur textures.
What is a spoiler tag and how do I use it? This isn't reddit, not everyone wants to know the ending here.
I was being sarcastic with that towards the post above mine.![]()
I put over 200 hours into Skyrim by the end of 2011 and here we are 2 weeks after FO4's release and I'm completely done with it.
Hopefully I will be able to clock another 100 hours into the game within a year or two when there are more mods out. I'm not sure that will happen since I never re-visited FO3 or NV after their releases.
I still need to finish FO4's campaign, though. I stopped when I reached the faction choice.
I do have high hopes for TES VI. Hopefully we get a new engine and much bigger scale, a true 'next-gen' sequel.
Was that vanilla Skyrim? Are you sure that was without any of the dlc or mods?
I'm not burned out, I've finished the game. I've discovered every location and explored every square inch of the map. There's nothing left to do except collect magazines.No kidding. The mods are what made me play the crap out of Skyrim and FO3. Both did a ton to improve the game. Even with all the mods, couldn't fix FONV enough to make me want to play it. Setting just sucked.
Further logging in 100+ hours in less than 3 weeks? It is no surprise he burned out.
I made a tutorial for building multi story structures the proper way in settlements. This doesnt use any prefabs, and leaves no weird gaps or issues in the building. Once you place your first floor tile, everything locks up afterwards. It's just a basic structure to get the point of the video across, but its the process I used to build that crazy thing on top of one of the houses that I posted earlier.
https://youtu.be/1uBUY2nQg3Y
(Im editing the speed so it plays at 2x so it cuts down from the 7 min time, but its still processing the edit)
Killed a legendary deathclaw at lvl 18 Had him chasing me around a tree. After around half the fight he got stuck and died! Bahahaha.
Killed swan at lvl 13 or so too.
On survival.
Also if you search "advanced building" or something like that there are a lot of other cool tricks people have tutorials for. Like the foundations, you can put the foundations into the ground unlike other pieces. I didn't know that until recently, it basically allows you to build a nice flat level foundation on any type of terrain. Really helpful.
Unlimited levels you should eventually be able to have max levels in all of the perks... and i dont know if it lets you go to 11 but it does count as having taken a level as in you get the star point as if you leveled it.Quick question to you all.
I know bobblehead Special boosts all count towards perk requirements, but does it also count for the stat boosting perk?
For example, if I have perception 9, and I pickup the PER bobblehead, I will avail of the 10 PER-k (you didn't see what I did there), but would I be able to pick up that last PER training perk?
Also, just checking "You are SPECIAL" doesn't boost any stats above 10, right?
Just trying to min-max stats, if Bobblehead does prevent me from going over 10, I will need to restart, again...
Still not sure if the stores generate caps or how much they generate. It does say theyre supposed to and it's based on the settlements population. I'm going to try skipping through 24-48 in game hours without touching my cap amount and see if any are added over the time frame.
LoL, I just built a little bar for the drink store you can create so it didnt look so dumb by itself on the sidewalk, and wouldnt you know as soon as I finished it half my settlers came to populate it. Pretty funny...
Texture mod, seems pretty good.
http://www.dsogaming.com/news/fallo...surfaces-uses-less-vram-realistic-lights-mod/
