Ruiner
- Aug 22, 2000
Geralt very uncharacteristically laughs, then toasts Zoltan, who farts.
Though AMD's performance is yet again a bit subpar, with Fury X matching only a 970, but nothing a good driver update can't fix.
flyvpn is working for me they got hammered pretty hard, 6 minutes to unpack it.
Private internet vpn New Zealand server is hammered too but working
Are these services you all pay for? I'm trying to do this myself but no luck so far.
Please keep this on Hardforum only.
I use the free option. All the steam client needs to do is verify that you are connected to a certain country IP and it will decrypt, no real bandwidth usage per se.
Ended up going with the name Grace
Does this game have forced vsync? I'm seeing 60fps capped.
One of the devs on Twitter said PC framerate is as high as your hardware will go.Gamebyro physics are dependent on 60hz.
Run the game with LOW GOD RAYS. I don't see a difference between Low and Ultra, not even slightly. But it cuts fps nearly in half.
The god rays option should have been a toggle... On (Low) or Off. Everything else is GPU suicide.
"Low" enables Nvidia's Volumetric Lighting, so yes there's a HUGE difference between the two. And it looks amazing.Leave it to Nvidia Gameworks to throw in some incredibly taxing effect that isn't even needed.
http://m.ign.com/articles/2015/11/09/fallout-4-review
IGN says a GTX 970 will run between 40-60 frames all day on ultra settings.
At 4K?
The OSD in MSI Afterburner isn't working for me for some reason. How bout you guys?
