- Jun 25, 2003
w00t! GMG just sent the key to me and bunch of friend's verified that they have received their keys. Getting closer!
w00t! GMG just sent the key to me and bunch of friend's verified that they have received their keys. Getting closer!![]()
Now if they would just update a list or something to say which damn phones will work and fit in the pipboy.
Any smartphone can run the app. The foam inserts included with the Pipboy fit these phones:
iPhone 6, iPhone 5, iPhone 4, Samsung Galaxy S4, Samsung Galaxy S5
If your phone is a similar size to any of these, it should fit in the insert. If it's much bigger than an S5, it probably won't fit. It's known that the iPhone 6+ and the recent Galaxy Notes are too large to fit in the holster.
got my gmg season pass key but not for the main game yet.
I have a windows phone, Lumia 920 and I have no clue.
its should fit, as the phone is roughly GS4 size, slightly thicker. the real issue is whether there will be an App, which I am not holding out hope for. Maybe after WM10 and universal apps, but prior to that....
Edit: Holy crap there is one. Props to Bethesda for actually making a WM app.
Pretty sure that when the FBI seizes your site they don't put their logo on it and a maudlin soundtrack ... most likely you get a site unavailable message![]()
Theorycrafting: Is it better to start with one of your SPECIALs at 10 so you can get a bobblehead and take it to 11? Otherwise all of your stats will max out at 10, with the game having an unlimited level cap it might be useful end-game to be able to take one to 11 instead. Eventually you'll make up for that "lost" skill point.
Having the stats at 11 will really only show their advantage once you have literally obtained every other perk in the game. Or at least the ones that you want.
Otherwise I assume 1 perk point is more valuable than 1 SPECIAL point. But yes going from 10 -> 11 will increase some of your stats related to that SPECIAL. And if you pick-up a bobblehead with anything less than 10 points in that SPECIAL, you have permanently blocked yourself from reaching 11. Just a thought.
Probably a good idea to start with INT at 10+1 for maximum XP.
Depends on where the Bobblehead is ... some SPECIAL Bobbleheads in FO3 were unattainable until late in the game ... if you can't get to a Bobblehead for 15-20 levels then it might be worth putting points into a SPECIAL later ... hopefully some of the reviews on Monday will start to give more info on leveling and experience
Bull some were hard but you could get to them at anylevel
I'm so upset, I dont have a single system at home that I can play this game on and spending a bunch of money to play one game is a really tough call to make.
There are 70 total SPECIAL points in the game (7 stats with 10 points each). You start the game with 28 total (1 point in each stat along with 21 to spend) which means you need to be level 43 to have them all maxed out. Seems kinda rough.
Might I ask, how?
Preload on PC is supposed to start today at 9PM GMT.
The INT one in Rivet City can be grabbed only a few minutes after leaving Vault 101 if you know how to get there through the Metro tunnels.
Not even. Just swim down the river.
I'm having a rough time trying to figure out a SPECIAL combo for a sniper build.
The sniper perk in P just doesn't seem worth the 4 extra points in P to get there.
Ideally I'd like to have a long range high damage build with high charisma for speech checks.
