- Jul 24, 2008
Sounds like you got hit with the multi-core bug, this should fix your issue.So a little bump here.
Played FO3 for quite a bit. I got pretty far into it. Then I got hammered CTDs. I couldn't go 5m without it crashing. Sucks, because I was having a decent time with it. What's the story on FO4? I hear mixed things about the game being buggy. I read thing about people asking if the game still has issues, and they get laughed at for "asking a stupid question". So I'm guessing that's still the case? Or do the above patches do a decent job cleaning everything up?
Open your Documents folder, and inside, look for a folder called My Games. Inside should be a folder called Fallout3. Open this.
- In this folder, open the file FALLOUT.ini with Notepad. Make sure the file is not read-only.
- In the configuration file, search for the header called [General]. It will be at the very top of the file.
- Go to the bottom of the [General] section, just before the [Display] header. The last line of the section should be sLanguage=ENGLISH, or whatever your language is.
- Below this line, copy and paste the following two lines:
bUseThreadedAI=1
iNumHWThreads=2
- Save your changes.
