KumbBa
Here is the install order:
DEF_UI/DEF_INV (single install package) ==> Gold Kit ==> Item Sorter ==> IconLibs
AceGoober
I screwed up updating this somehow. This is what I'm getting. Where did I go wrong?
KumbBa
AceGoober
Customizing HUD
The default installation above will install a vanilla HUD configuration. You can also download presets that other users
have customized and published on the Nexus. If you would like to customize your HUD:
1) Open your game Data folder and navigate to Data\interface
2) Run HUDMenuSet.exe
3) Customize your HUD settings. Instructions are located within the utility.
4) Once you are done customizing, press CTRL+S and save the file as Data\interface\DEF_CONF\DEF_HUD.xml
5) Exit the program and play the game.
Customizing INV Options
The default installation above will install the standard DEF_INV options. If you wish to customize DEF_INV behavior (ie.
tag/icon replacement, font size, etc):
2) Run Settings.exe
3) Customize your INV options.
4) Once you are done customizing, press CTRL+S and save the file as Data\interface\DEF_CONF\DEF_INV.xml
I think I am level 11 now in this game. Quests are somewhat interesting. However, I feel threatened actually going out in the wild. Unlike FO3 and FONV where after level 5 or so there was little to no threat, in this one, I actually feel tense.
Not bad. Are there multiple maps to the game or is it just one map. The current starting map I am on, seems a bit small for a Fallout game.
Another stupid question. Where do I find concrete. I need to put up water in the starting area but can never seem to find concrete and rubber.
Fallout 4 1.7 Update live on PC, Xbox One and PS4 coming soon (Updated)
- Bethesda Game Studios
- August 2, 2016
(Updated 08/04/16)
The 1.7 Update is live for everyone on Steam today. Xbox One and PS4 will go live in coming weeks.
NEW FEATURES
FIXES
- Support for Nuka-World
- New store art type for Workshop settlements
- Ability to delete Add Ons without doing a full uninstall (PS4)
MODS FIXES
- General optimization and stability improvements
- Jun and Marcy Long are no longer essential after completing "Sanctuary"
- Vendors can offer large shipments of Ceramic, Copper, Rubber, Steel and Wood
- Improvements to accuracy and control with picking up and placing objects (not Workshop mode)
- Grenades and molotov cocktails can now be used with the Junk Mortar (Contraptions)
- Fixed issue with companions unequipping clothing when fast traveling with player
- Fixed an issue with player animations not loading properly after reloading a saved game
- Fixed issue where certain dog armors would not equip properly on Dogmeat
- Fixed an issue where objects from Add Ons would not scrap correctly or would not be stored properly
- Fixed infinite load that would occasionally occur while logging off while downloading a mod
- Fixed a crash related to investing in a store while trading
- Fixed issue where "Quartermastery" would send player to erroneous locations
- Fixed performance issues related to dropping certain weapons
- Fixed issue where melee weapon would not properly after dying and reloading the save
- Fixed a rare issue where Sturges and Mama Murphy would stop moving
- Fixed snapping issue with Surgery Center in Workshop mode
- Fixed issue where Mods images would stop displayed while scrolling through Mods menu
- Disable All Mods now works properly when offline
- NPCs that are changed in a Mod will update changes like hairstyles properly
- Fixed animation error related to NPCs changed in Mods who have died, and reloading the save without the Mod activated
- Fixed issue where sneaking would turn player invisible while running with Mods
- Localization strings moved to Interface archive
- Minor UI improvements to Mods menu and Mods Detail menus
Where all the sweet Vault 88 build pics at?
Right?
I would have figured some of our regulars in here would have blown us away with underground metropolises and who knows what else?![]()
Sorry, been busy turning Starlight Drive In into the finest arena/Soylent Green factory in the Commonwealth.... You'd think the Gunners would get the idea to stay away, but no.........
Was going to return to play this game, then easily remembered why I stopped to play and why I hate it sometimes.. and it's the stupid loading screens, specially in the financial district where one have to enter/exit several times from buildings.. certainly I can not hate it enough.. =)..
Install it on an SSD. That's one of the reasons why I don't have HDD's anymore, way too slow even for games.
Even on SSD they are long.. it's really annoying... I think my Samsung 840 Pro is good enough, but even installed there you have 15+ secs load screens on some areas. much more worse is the experience with mods... I used to have over 160 mods on skyrim and it wasn't anywhere close to FO4, Loading screens were still instant..
That sounds awesome.
Believe me, on my regular hard drive that I have F4 on currently I would do cartwheels in the street to see 30 seconds or less. With a couple of dozen mods I can go to 2-3 minutes on initial loads after I load up a save on my "normal" Western Digital hard drive.
Skyrim was roughly comparable.
If I loaded it up in 15 seconds I'd be doing cartwheels in the street.
It was for me the same way in my first installation on the HDD, the game was new I never knew about the ridiculously long load screens the game was fine at the start through the first missions.. but as soon as you go to dense areas load screens were over 1 and half minute.. damn, immediately installed on SSD but still in those areas load screens go beyond 15secs specially with mods which is insane for a 2015-2016 game.. it make really annoying where you have to go inside and outside several times, for me it's a game breaking as I get bored fast between load screens.
Skyrim was only the first load screen when opening up the game, then everything else on SSD was instant..
Hopefully I'm doing this right.....Pics?![]()
What is the cleanest way for me to get everything on to Drive 2 (or even Drive 1) given all of that? Thanks to any and all who might answer this. I really don't want to create a nightmare for myself.
In short - an immediate method of doing this is to use NTFS Junction Points
NTFS junction point - Wikipedia, the free encyclopedia
It's a very simple method to allow you to redirect directories. I've used it many times to move things around my computer or you could use junction points to create a single directory structure, with content distributed around various media - and stuff like that.
Obviously it's sometimes not the best long term solution, but you can clean things up and/or move things around again as and when your hardware changes.
Wouldn't it just be easier to set up a steam library on the other drive and tell steam to install the files there instead?
Not really.
They're different approaches to the same end result.
Using junction points allows me for example to move an installed steam game right now, without having to do anything else at all other than move the directories and create the junction point. I'm moving the data at the file system level and it means I don't need to do anything at all within steam.
i.e. I can move an already installed game (and redirect its location using a junction point) and there's no re-installation or anything else required.
Basically I'm a "horses for courses" kind of person. I'm not saying my method is better than your suggestion - just it's another option and it's a very simple one, that is easy to implement and doesn't require anything else.
Use whatever method you think is most appropriate in your own situation![]()
You can use the Steam Backup function, then delete the game then restore it. You don't need to download it again. But I fully admit I'm lazy and I'd just download the entire thing again... Did I mention I have fiber to the home? It really affects the way you think about downloading things from Steam.
I'm not saying your approach is bad, it isn't. But you do have to be careful using junction points because Windows Explorer and a lot of other tools don't treat them properly. It's fully possible to delete files off of one drive when trying to delete them from another. I've accidentally done a few stupid things with them in
the past. I'm a KISS type of person, less things to potentially go wrong.
Nuka World looks crazy I think they strike a balance between a theme park and Radiation but not sure if I would want to spend time in a videogame to play it. I like Automatron but haven't played the last two DLCs from lack of interest.
