quakelive is where it's at
Yep! I have been playing that a lot more since I got into a 120 Hz monitor setup. I just wish there were closer servers than Chicago or Toronto, though my ping isn't too bad.
Those with a perfect Panel should try Gamma at "Power" looks best in my opinion.
I think i will end up getting a CX240 which has a lot less IPS Glow than my current EV2436W.
This FG2421 is really hit and miss and from my personal experience far from EIZO quality. It's surely not worth the 500 euros compared to my EV2436W.
What is the EV2436W like as a gaming monitor?
Does anyone know what causes this problem and why pure black is completely unaffected?
On the UFO test, turbo240 dramatically decreases motion blur, but it does increase the amount of ghosting. The actual UFO is incredibly sharp though, even at very high speeds.
The monitor has a bit of smearing going on too. I don't know if it's noticeable in games, but it's definitely there on the UFO tests on most background colors.
nice, I live in Toronto so my ping is about 15 there
My qlive nick is Julios, mainly play FFA and occasional duel.
I received my monitor yesterday, but I'm probably going to return it.
The box says Eizo - Stockholm, Sweden.
Mfd. 2013.09.24
Black looks perfect with no significant clouding, dark grey looks not so great. The right side of the screen is a bit worse than the left. The darker the color gets the more pronounced the effect is. It's actually noticeable on this website on the post backgrounds.
The effects are a bit exaggerated in the pictures (partially because I had messed with the black level setting prior to taking the pictures - it was at 40):
<snip>
The motion clarity is just a tad worse than 10% Lightboost, but the god-like blacks, contrast, overall image quality and good viewing angles in portrait surround MORE than make up for any small deficiencies.
Yeah, that edge glow is what most of us have been discussing / having issues with. What are your brightness/gamma levels at? Mine got noticeably better after making some adjustments..
I wish I could say the same thing about mine.. The glow or bleeding or whatever it is is significant enough that I would probably prefer my U2412M for most things except fast paced shooters. At least glow is only a problem with blacks on the Dell..
Do you have perfect uniformity on all your displays with the following picture in a dark room?
http://i.imgur.com/DWFc5dO.png
The stock web setting seems pretty good at exposing the monitor's problems with this specific picture, at least on my sample.
I'm on user1, fairly close to stock except for low brightness. I see no significant change when using your settings though, unfortunately. I think all you can do is really shif the problem around a little.
Maybe I am just lucky!
http://i.imgur.com/dOezfUl.png
(very dark grey)
http://i.imgur.com/V7DavQy.png
(very dark red)
Mine is around 60 usually for Toronto (I live in Michigan). My nick is phillyboy on there and yeah, been mainly FFA but I definitely enjoy CTF as well.
Vega its not the blacks we are worried about. We have already established the blacks are decent and uniform.
We want shots of dark grays and browns, these colours bring out the worst.
Ok, but brightness 50 in a dark room, you trying to go blind you know how bright that is on three screens lol. WIll do later tonight, but I think that would be an exagerated mode as I would never use those settings. Not sure how well any monitor would do that bright in a pitch black room with that image..
@phillyboy
Yes, the more people post a picture with this pattern the best estimation we can make about the proportion of affected panels (though the conditions to take the picture can make comparisons difficult, hence why it is good to give some details like brightness and gamma for the screen setting, and at least iso and exposure time for the camera).
I can't remember if it was in this thread or another forum I've read someone suggesting that the fg2421 could use rejected panels from the much more expensive version for satellite imaging. I just fear this could be true as it would make sense. Keep the best panels for the very expensive monitor and create a gamer screen to get rid of those panels that didn't pass the quality test. I wouldn't accept to pay for this then, knowing an almost gamma-shift free fg2421 could be possible but we don't have this because it is made with the worst panels Sharp delivers to Eizo.
For a gaming monitor 500 is not cheap and even if I can understand the best panels are used for the expensive satellite imaging monitor it doesn't mean the gamer version shouldn't have a minimum quality requirement also. At least I know this gamma shift is the main thing preventing me from buying this monitor. I know I couldn't stand having that much light at each side in dark scenes after I have used for 1 year an ips that doesn't have this issue at all (and crt before that).
Setting brightness level is something misleading because it takes a long time (several minutes) for the eyes to adjust to the lower brightness.I don't know if our monitors have differences, but i usually play in a dim or pitch black room, and i use 50 brightness with turbo on (i tried lowering it to 45 and 40, but it was too dim). I didn't even test lower than 30 brightness with turbo on initially because it simply seemed so unreasonably dim that noone would use it.
When I come from let say 20 brightness on my monitor and then set it to 12 because I know that's the good level for me I tell myself it is waaaay too dim at the moment I do the adjustment. It is so dim I even wonder how I could have found this level was suitable for me. But after 5min I don't even think about it, and after 10min I find it is even still too bright.
So you should not hold with the impression you have at the moment you adjust the brightness. Either do the adjustement and try using it for a while, or do it by very little steps every 2min.
Also idk for the fg2421 but with the fs2333 if you cut the pwm (brightness max + reduced gain levels) then despite the screen brightness is lower the OSD is displayed with full brightness, which makes brightness adjustment even more misleading as you compare the result with the OSD displayed at full brightness.
I adjusted it a few steps each day so each settting was in effect 24h. i could live with 45, 40 was too dim, but i turned it back up to 50 since it felt best.
AwesomeOwl
Better send that unit back...I couldn't play with this kind of distracting defect...It looks ugly as hell.
Gamma shift is called gamma shift because viewing from angle affects gamma level making it lower at sides and lower gamma will make dark gray brighter while black will remain black. Mind that lack level is affected on some VA displays only because they don't display true black panel can do.
So its not really any 'bleed' but normal ordinary gamma shift.
Vega made photos from much larger distance than most photos showing single displays so it is no brainer that gamma shift was less visible.
