- Oct 7, 2000
While supplies lasthttps://nvidia.custhelp.com/app/answers/detail/a_id/5657/~/doom:-the-dark-ages-geforce-reward-redemption-instructions
Verdant skin for Free which is Ironic since the game is FPS.
Eternal was about 14 hours for me.20 hours?...seems really short, at least compared to Doom: Eternal...Eternal seemed like a long game...I replayed Eternal with both Ancient Gods DLC's back-to-back last year and it seemed really long...or maybe I just like taking my time with games and exploring everything so most games take me longer to play than the average gamer
I wouldn't know. It was all I could do to struggle through the main campaign as I hated the platforming. Once I finished it, I never looked back.Eternal DLCs were crap.
Those with 8-10 gb gpu's should stick to a 1.5(1536MB) or 2 gb (2048) texture pool.Only played the first 4 missions, but it is silky smooth on my end at QHD (1440p), max settings, DLAA, frame gen off and Reflex on with 5070ti and 5800x3D. My FPS is in the 80-110 range most of the time, but it feels smoother than most other games at similar frame rates. Game seems to be well optimized for responsiveness, but the RT only approach might be an issue on weaker GPUs.
Performance issues could be a machine to machine thing or a VRAM issue. My money is on 8GB card owners pushing their settings too high. The game uses 9.4-9.7GB of VRAM with my settings and typically 5-5.5GB available as windows and background stuff uses around 1GB. Basically on a 10GB GPU you generally want to try to stay below 9GB in the game and on an 8GB GPU you probably need to close down as many background applications as possible, play around with texture cache etc. and turn down a few settings. Wouldn't be surprised if a lot of people don't understand VRAM limitations and try to run everything max on an 8GB GPU, which could easily cause issues.
I meant they get access to the game early. I don't mean Steam Early Access. But fine, if Valve wants to officially call it "Advanced Access" then whatever.Advanced access, not early access.
That's what it seems like to me. I'm going to get it but I'm not spending the $100 on the deluxe edition.But from what I've read and seen, Dark Ages looks like a return to form and something I'll really enjoy.
well shit, didnt even see that...Minimum spec cpu listed is an 8 core. Might be time to retire my 8700k.![]()
nice. i can live with 1080p high or maybe 1440p med....Yeah, I missed the cpu req also. Pc gamer said that they recommend 12 threads at least so there's that. The 5600x that they tested seemed to do ok.
https://www.pcgamer.com/hardware/do...d-even-a-cheap-gaming-laptop-copes-just-fine/
load times maybeRequirements list nvme storage, but I’m running off a normal SSD and it seems fine. I wonder if there is any real benefit.
I got one of the first-gen 3080s with 10GB and always regretted it. Never understood it as it was a downgrade from the 11GB of my 1080 Ti. Now it looks like 16GB is the new standard.Those with 8-10 gb gpu's should stick to a 1.5(1536MB) or 2 gb (2048) texture pool.
yeah i heard that mentioned in a few of the vids. not sure what happened last year (i think thats when they said) but they have parted ways...I thought that Hulshult may have worked on the music this time around, but it was done by a group that has done a lot of recent game soundtracks called Finishing Move Inc.
https://en.wikipedia.org/wiki/Finishing_Move_Inc.
Med Details and you should be good. I am hoping for 60-90FPS 1440P and high details on my 4070 Super and 5700x3dDamn I don't think my 4070 will be able to run this at 4k 144hz. The game not that optimized? Looks like theres not much difference on the presets from low and ultra nightmare. We need lower settings for lower end cards.
I'm listening on the Surround mix with Atmos for headphones enabled and the mix isn't that bad, but the impact sounds seem to definitely be lacking some of that meatiness they should have.The sound design in general is the weakest point of the game right now for me. The music is OK, but that's about it. However, the larger issue is there are a lot of elements like the NPC's talking where it's just really low-quality stuff, and the general mix of the audio doesn't sound that great either.
From the developer:Played a bit more, and still no crashes on my end, and I still refuse to update the driver for now.
Users with NVIDIA GPUs running the latest drivers who have AMD Ryzen CPUs may experience persistent crashes at launch.
To prevent or resolve this issue, either disable the integrated GPU in Windows Device Manager[www.elevenforum.com] or download and install AMD driver version 25.4.1.[www.amd.com]
It's free if you buy a graphics cardwhy is it 70$![]()
Because you'll pay $70why is it 70$![]()
haha my 4070 super is doing just fineIt's free if you buy a graphics card![]()
still 10 dollars cheaper than the next mario kartwhy is it 70$![]()
why is it 70$![]()
Because AAA games are usually that expensive these days.
