CrimsonSky
- Jun 14, 2003
cgrant26 said:Nice!
Just a couple quick questions:
I'm noticing a lot of the aluminum framework you use is pre-formed. Are you using aluminum door thresholds for stock?
What power tools do you employ to get the clean cuts on your aluminum parts? If I had to guess, I'd say mainly a drillpress and a chop-saw, but I'd like to know for sure.
In that first pic, is that a Foredom I see in the background? (for those who don't know; Dremel tools bow down to the mighty Foredom)
hey thanks for the replies folks--Unfortunatly i wasnt able to make it to QuakeCon, as you may have guessed and as I stated earlier in the thread--I have been really busy this year with other projects and just would not be happy "rushing" this case at the last minute to make the event--also, I'm never shipping a case by common courrier (UPS, FedEx, et al) ever again--only specialty art handling will do--I've had too many close calls and full blown nightmares shipping my work in the past. Art shippers carefully load your box onto a truck and treat it with respect from door to door. These shipments go out on truck "shuttles" a few times a month, so its not like you can do rush service.
Cgrant26, those are indeed extruded alum parts found in home improvment stores--they are inexpensive and are really handy for creating odd shapes and mechanisms. I use alum door saddles (or threshhold) and molding a lot as you can see. I cut on a Delta bandsaw and clean up with files and buffing machine.
and yeah!--thats a heavy duty Foredom in the background. I have to keep it across the room from the little Dremel because it always picks on it and kicks its ass after school.
