mashie said:You can still use a PCI videocard to drive the LCD with though (if space permits).
Ya thats what i would do just use like a PCI FX5200 or something like that.
mashie said:Nope, that is one of the remaining big bugs. You can still use a PCI videocard to drive the LCD with though (if space permits). Just a very annoying solution though considering the 6800s provides 4 DVI outputs together...
Thats the 77.62 beta driver, heres a link to the 80.40 beta driver:HilRam said:And you can download the beta here.
MONKEYVILLE said:/any ideas when about it'll be finished?![]()
CrimsonSky said:yeah August 11, come see it at QuakeCon.![]()
cgrant26 said:I'm going to be happy and sad at the same time when this is finally finished.
Amazing work as usual Crim.
BoySetsFire said:have you looked nito using 'memory metals' for some things?
zoggy said:Are you coming to QuakeCon? Bringing your case to show off?![]()
