- Sep 29, 2001
I like the Gem conversion. I play mainly DH and always run out of gems.
uh what do u do with all gems ?
I put my Krider on and it didn't seem to work with the belt when using an Elemental as a generator.
It does speed up the normal generators though.
Blizz confirmed that it was working as intended and was never designed to work with Krider.
Zepher what is that chest that spawned after skeleton king?
Did they change the rewards for farming the bosses?
Curious what these changes will bring. I don't know if I will do seasonal characters though. I just don't want to keep starting over.
How active is this game? I always log in every few months just to see what's up but I rarely ever see any public games going on. I only have hardcore characters and when I scan the public games I only see about 3-4 people playing on all Torment difficulties combined. Unless I'm seriously one of the only five people in the world playing hardcore difficulty, I don't understand why there are so few public games going on. Anyone else have a similar experience or maybe my network settings are blocking all the public games somehow?
Non-Seasonal Hardcore is DEAD.Yea, I have the expansion with a few max level characters but I've literally never seen more than 3-4 people playing in public games. I know hardcore isn't as popular but I find it hard to believe only a handful of players in the world are playing it at any given time which makes me wonder if there's some network shenanigans going on.
How many people do you typically see playing normal games? I don't have a normal character so I can't check but I might roll one if it means there's an actual playerbase to play with.
Two new bits of info from the PTR.... hold on to puzzle rings and those Bovine Polearms....
Drop a puzzle ring by itself into the cube and it opens a Treasure vault portal....
Drop the Bovine Polearm in and it opens a Cow Portal....![]()
any word on when the patch should transition to the live servers? i dont want to play without the new patch.
So the last time I really played this game was before they released the Greater Rifts. I tried it out for the first time today and it's pretty tough so I'm guessing I need to gear up my character a bit more. Are the regular rifts still worth doing? Are there any other new things they've introduced since the Greater Rifts?
I just picked up these games with the recent sale and started playing last night.
I'm getting the micro-stuttering that so many others seems to have trouble with. Been googling to find a solution but all of the threads I find are at least 3-6 months old. Are there any viable fixes for this?
What lvl of Greater Rifts did you try?
If you're having trouble on Torment 6 and tried a GR45... no surprises you had trouble
Regular rifts are still good for full-clear in order to find gear.
I got the greater rift keystone off the regular rift guardian and tried it out. It put me in some "test run" where it awarded me a lvl 21 keystone. I used that on the obelisk and it took me a minute to just kill the first couple mobs so I just noped on out of there since I wasn't gonna finish the greater rift in time.
I figured since I hadn't played since the patch before they introduced the greater rifts, it's probably a combination of my gear and build being outdated. So I just ran the regular rifts a couple times to get used to the game again. I'm wondering if they've added anything new to the game since then other than Seasonal stuff.
Greater Rifts will drop legendary gems, which can be socketed only into rings and necklaces. These gems can be leveled up. At rank 25, they unlock a secondary legendary ability. Normal rifts are fine to gear up. Greater rifts will give you more currency to gamble things from Kadala.
When 2.3 goes live, you don't have to do trials anymore for greater rifts. You just select the level from a drop down menu.
EDIT: Torment 6 is equal to greater rift 25. If you struggled on greater rift 21, try doing normal rifts on torment 4 or torment 5. I believe torment 5 is equal to greater rift 20. Torment for is equal to greater rift 15.
2.3 will have torment level 10, which is equal to greater rift 45.
It has something to do with V-sync. I believe the solution is to turn V-sync off and use the in-game frame limiter instead. That is what I do and I don't get any microstutter.I just picked up these games with the recent sale and started playing last night.
I see, thank you for the explanation. My guy can only handle Torment 2 comfortably and at a decent pace right now so your breakdown makes sense.
What character are you playing as? I wouldn't mind running with you to make gearing faster. If DH or Barb I will drop whatever you want.
