- Aug 5, 2013
I don't know what you mean... I transferred my toons from live.Hardcore on PTR lol.
All of my best gear is still HC so it's easier to test the cube, especially with no queues.
I see they removed the duration buff in Archon, darn.
I was hoping you could get parma-Archon with the new set.
Queues are short on hardcore.
Casuals.
Finally got into the PTR last night on HC. Found a new shrine... a Bandit shrine. Clicking on it spawns a goblin pack, lol...
I was only able to get into HC ptr. I forgot that you can't change difficulty in HC and I created a Normal game. So I played about 30 minutes of normal and then left game.
I left my computer in queue for the softcore PTR all night (about 11 hours) and didn't get into a game. Had mouse move going so I wouldn't go away.
That's silly. If you can't change the difficulty, have they at least tweaked it to be a decent experience? or could you play with your eyes closed for the first hour?
I set mine to at least hard difficulty in HC last night. Got the cube and ran a set of Act 1 bounties. Found in order to use the cube you will have to run all the bounties in each Act to gather the bounty specific cube mats from the caches.
They have also gone back to having one of the bounties be a boss fight though with a nice addition. Act 1 I had to kill the butcher. When I finished killing him it spawned a "Diabolic Chest". Chest gave me about 3 legs and alot of other loot.![]()
New PTR patch just popped up on the CDN.
Should be out sometime today I assume. Datamine coming shortly.
Yes, you can edit d3prefs.ini to use any aspect ratio you want within your 4K panel resolution. Just change the X/Y pixel size.
I believe it requires Windowed Mode but I've never actually gone Fullscreen in D3.
The wider your AR, the more you can see.
Viewing angle-wise, you're better off with 3x 1080p than a single 4K, as it's natively wider.
Well the left to right are always good enough for me. Its the up and down that is the problem the 1080p part. If I can get that 1080 to 2160 it will be amazing.
Even when using triple monitors, which I do, going up and down sucks. Chargers will still charge me from outside of my viewing range up and down.
1080p Surround is capable of 5760 horizontal (3x 1920).Well the left to right are always good enough for me. Its the up and down that is the problem the 1080p part. If I can get that 1080 to 2160 it will be amazing.
Well played some more with the PTR, did my first cube recipe. I had a calamity which I wasn't using so I extracted the marked for death from it. You can have a weapon, armor and a jewelery power active it looks like. Activated the MFD and far as I can tell my sentries are also applying the MFD when they fire.![]()
You apply the affix to the cube itself.When you extract the MFD, what item do you put it on? Can you put affix's on any item?
You get the max affix roll in the cube, too.Going to make it nice when you have a poor rolled leg but you really want that power... can see extracting the EA from a bad Kridershot as well....
Wow, this actually greatly increases the utility of crafting.
Just a question, does it matter if the original passive came from an Ancient or a normal leg?
Edit: also does the weapon type have to match? Like would I be able to put say a Furnace passive onto, I don't know, a 1h DH crossbow?
The max mats you earn per cache is 4. Im being told that happens on t6 t7 or t8, not totally sure.I like the new cube, but damn is it going to be a bitch farming those bounties again. Act V is pretty bad, but damn I think Act 3 was designed by someone who hated Diablo players. Huge levels + low density. Adria on T9 wasn't the most enjoyable fight either, 62 billion health and that's just solo.
I never played D2
So if you have a shitty Furnace but an amazing crafted 2H, you can cube the Furnace for 50% elite and get better base stats from your crafted weapon.
It greatly simplifies the gearing curve especially for weapons.
why not ? were u in the army back then living in a cave or...![]()
