AMD T-type
- Aug 26, 2002
So I'm no Monk expert but take a look at your character on d3up
http://d3up.com/b/664299
Every point into crit chance is like putting 30 dex or 30 avg damage
Every point into crit dmg is like putting 5 into dex or 5 avg dmg
It looks like you're over allocating on dex, so you might think it's going to cost an arm and a leg to make any significant upgrades. In reality, sacrificing dex for crit/critd will yield better returns in dps for now.
Lets take your amulet for example. A search for 5crit, 50critdamage, and socket showed me this for 15,000 gold (buyout) only
6.5 crit
63 crit damage
socket
Drop in a basically free flawless square, and that will increase your dps by 10k, all that for gold that can be found in under a minute.
For 132k, i found a ring
80 dex
3.5 crit chance
33 crit damage
79 vitality
31 min damage
giving another 6k dps at the cost of only 1.7k ehp
With 90k+ DPS, I dont think MP1 should be a problem (again I'm no monk expert). With that, dropped gold alone should be enough to start buying better gems. Go for star emerald on your skorn first. After that, you can look at upgrades in the 250k range. The way the gear works, gear is multiplicative: It's better to upgrade a lot of pieces of gear with 250k each, than to drop 4 mil only on one item while the rest is crap. Dont aim for the 100mil+ items yet. If you get lucky, good for you, but you still have a lot you can upgrade without ever relying on RNG.
Thanks for the advice!
